In this section, you will learn how to automate the build process of a Windows application using GitHub Arm-hosted runners. You will use the application in the Optimize Windows applications using Arm Performance Libraries Learning Path .
This section provides a basic overview of the application. For detailed build instructions, see the Optimize Windows applications using Arm Performance Libraries Learning Path .
The source code for the rotating 3D cube application, which demonstrates multiple programming approaches to performing rotation calculations, is available in this GitHub repository.
https://github.com/arm/SpinTheCubeInGDI
The application implements a spinning cube and consists of four key components:
The code has two options to calculate the rotation:
You will learn how to automate the build process for this application by using GitHub Actions with Arm-hosted Windows runners.
The
GitHub Actions workflow msbuild.yml
that automates the build process using MSBuild for Windows on Arm is included in the repository.
Below is an explanation of the steps in the workflow:
Trigger Events: the workflow runs when there is a push or pull request event on the main branch.
Job Definition: a single job named build is defined. It runs on the GitHub Arm-hosted Windows runner (windows-11-arm) as shown:
jobs:
build:
runs-on: windows-11-arm
Checkout Repository: uses the actions/checkout@v4 action to fetch the code.
Add MSBuild to PATH: adds MSBuild tools for the build process using microsoft/setup-msbuild@v1.0.2.
Restore Dependencies: runs nuget restore to restore NuGet packages required by the solution.
Create Download Directory: creates a directory to store downloaded files and verifies the Python version.
Download ARM Performance Libraries: downloads the Windows installer for ARM Performance Libraries (APL) and verifies the downloaded files.
Install ARM Performance Libraries: installs the downloaded ARM Performance Libraries using msiexec.exe with a quiet mode and logs the process.
Check Installation Success: verifies the success of the APL installation by checking the exit code and logs.
Build the Solution: runs MSBuild to build the solution with the specified configuration (Debug) and platform (ARM64).
Upload Build Artifact: uploads the built executable as an artifact using actions/upload-artifact@v4.
This workflow automates dependency management, environment setup, project compilation, and artifact storage - all using a GitHub Arm-hosted Windows runner.
To run the workflow in your own GitHub account, start by forking the repository.
To fork the repository, go to the repository page on GitHub and click the Fork button in the top right corner. This will create a copy of the repository under your own GitHub account.
You can then run the workflow in your forked repository by navigating to the Actions tab and selecting the MSBuild workflow, then clicking Run workflow.
You can view the Actions logs in the repository for each step.
You have learned how to build a Windows application and upload the result as an artifact of your workflow using the GitHub Arm-hosted Windows runner.
