Automate Windows on Arm builds with GitHub Arm-hosted runners
Introduction to GitHub Arm-hosted Runners
Automate the Build of Windows Applications
Configure the job to run on a GitHub Arm-hosted Windows runner. Update the workflow so the job selects the Arm-hosted Windows environment instead of a different runner type.
Open the workflow run and check the job details, which list the runner that executed the job. The logs and summary page identify the runner environment so you can verify it used an Arm-hosted Windows runner.
Use the toolchain that matches the project’s existing build files. To choose the correct build step, follow the guidance for the rotating 3D cube application referenced in the Learning Path.
The
Optimize Windows applications using Arm Performance Libraries
Learning Path provides the rotating 3D cube application and its build instructions. Use that resource for detailed build steps.
The workflow shows a successful job status and the logs indicate a completed build. The run contains the Windows build outputs for the sample application. Any configured artifacts appear on the run’s summary page.
