Give feedback
AI-assisted
Close
How do I know the robot and cameras are mapped to the right devices before calibration?
Set ROBOT_PORT, LEADER_PORT, GRIPPER_CAMERA_ID, and WORKSPACE_CAMERA_ID in the terminal that you’ll use for calibration. If you reconnect a USB device or open a new terminal, repeat device discovery and export the current paths before proceeding.
Which components do I connect where when wiring the setup?
Connect the SO-101 leader, SO-101 follower, gripper camera, and workspace camera to the DGX Spark over USB. Mount the gripper camera on the follower, and keep the workspace camera fixed to frame the follower, pickup area, rack, and the arm’s full range of motion.
What should I check during calibration so teleoperation mirrors the leader correctly?
Start each arm with its joints near the middle of their usable ranges. Move each requested joint slowly through its safe range, support the arm, and stop before reaching limits.
When is the workspace ready to start recording demonstrations?
After calibrating and verifying teleoperation, arrange the two-camera workspace. Lay the vial on the black mat, place the rack beside it within the follower’s calibrated reach, and leave enough space between them for grasping and movement.
What result should I expect after fine-tuning SmolVLA with my demonstrations?
You’ll get a SmolVLA model adapted to your demonstrations. Evaluate it with LeRobot on the Arm-based NVIDIA DGX Spark, then use it to control the robot on the vial-to-rack pick-and-place task under the recorded conditions.
Return to Laptops and Desktops
