Fine-tune SmolVLA for SO-101 on NVIDIA DGX Spark
Understand the SmolVLA fine-tuning workflow
Install LeRobot and prepare a Python environment
Connect the SO-101 and cameras
Calibrate and teleoperate the SO-101
Record and validate a pick-and-place dataset
Fine-tune SmolVLA with the recorded SO-101 demonstrations
Evaluate the fine-tuned SmolVLA model
Run fine-tuning
You’ll fine-tune the SmolVLA model with the SO-101 demonstrations that you recorded. Fine-tuning adapts the model to your two camera views, robot joint layout, and pick-and-place task. Training runs locally on the DGX Spark GPU and produces a model checkpoint for physical evaluation.
Use the same LeRobot environment as earlier. Keep the values of DATASET_REPO_ID and LOCAL_DATASET_ROOT from the recording step.
Choose unused paths for LOCAL_TRAIN_OUTPUT_DIR and LOCAL_TRAIN_LOG. The output directory stores checkpoints and training metadata, while the log file stores the terminal output. The command stops instead of overwriting either path if it already exists.
Export both paths and confirm that the dataset variables from the recording step are still set:
export LOCAL_TRAIN_OUTPUT_DIR="$PWD/outputs/train/smolvla-so101-pick-place"
export LOCAL_TRAIN_LOG="$PWD/outputs/logs/smolvla-so101-pick-place.log"
mkdir -p "$PWD/outputs/logs"
: "${DATASET_REPO_ID:?Set DATASET_REPO_ID before training}"
: "${LOCAL_DATASET_ROOT:?Set LOCAL_DATASET_ROOT before training}"
: "${LOCAL_TRAIN_OUTPUT_DIR:?Set LOCAL_TRAIN_OUTPUT_DIR before training}"
: "${LOCAL_TRAIN_LOG:?Set LOCAL_TRAIN_LOG before training}"
The validation commands exit with an error if any required value is empty.
After confirming, load the local dataset, fine-tune the model, and save the final checkpoint:
set -o pipefail
test ! -e "$LOCAL_TRAIN_OUTPUT_DIR" && \
test ! -e "$LOCAL_TRAIN_LOG" && \
PYTHONUNBUFFERED=1 lerobot-train \
--policy.path=lerobot/smolvla_base \
--policy.device=cuda \
--policy.push_to_hub=false \
--policy.empty_cameras=1 \
--rename_map='{"observation.images.gripper_cam":"observation.images.camera1","observation.images.workspace_cam":"observation.images.camera2"}' \
--dataset.repo_id="$DATASET_REPO_ID" \
--dataset.root="$LOCAL_DATASET_ROOT" \
--output_dir="$LOCAL_TRAIN_OUTPUT_DIR" \
--job_name=smolvla-so101-pick-place \
--batch_size=64 \
--steps=20000 \
--save_checkpoint=true \
--save_freq=20000 \
--log_freq=200 \
--wandb.enable=false \
2>&1 | tee -a "$LOCAL_TRAIN_LOG"
The key options are:
--policy.path=lerobot/smolvla_baseselects the pretrained SmolVLA model to fine-tune. In robotics, a policy is a model that converts observations, such as camera images and joint positions, into actions that control the robot.--rename_mapmaps the camera feature names in the dataset to the names expected by SmolVLA. The model expects camera inputs namedcamera1,camera2, andcamera3, while this dataset containsgripper_camandworkspace_cam. The command maps:gripper_camtocamera1workspace_camtocamera2
--policy.empty_cameras=1allows one expected camera input to be absent. The model’s third camera input,camera3, is left empty.--steps=20000sets a fine-tuning baseline of 20,000 optimization steps. The SmolVLA documentation uses this value as a starting point.--batch_size=64follows the documented starting configuration and fits within the memory available on the DGX Spark.--save_checkpoint=trueenables checkpoint saving, while--save_freq=20000saves a checkpoint after 20,000 steps. Because the training run is also 20,000 steps long, this configuration saves the final checkpoint without creating intermediate checkpoints.--policy.push_to_hub=falseprevents the trained model from being uploaded automatically to the Hugging Face Hub.PYTHONUNBUFFERED=1makes Python write log messages immediately instead of buffering them. This allowsteeto display and save the training output in real time.2>&1 | tee -a "$LOCAL_TRAIN_LOG"displays both standard output and error messages in the terminal and appends them to the specified log file.
Monitor training
Open another terminal and return to the cloned LeRobot directory. Environment variables aren’t inherited by a new terminal, so export the same log path before monitoring the run:
nvidia-smi
tail -f "$LOCAL_TRAIN_LOG"
nvidia-smi confirms that the training process is using the CUDA-enabled GPU. The log shows the current step, loss, learning rate, and timing information. Press Ctrl+C to stop following the log; this doesn’t stop training in the original terminal.
After training finishes, set MODEL_CHECKPOINT to the saved model directory:
export MODEL_CHECKPOINT="$LOCAL_TRAIN_OUTPUT_DIR/checkpoints/last/pretrained_model"
Verify that the required model, configuration, and processor files exist and aren’t empty:
for file in config.json model.safetensors train_config.json \
policy_preprocessor.json policy_postprocessor.json; do
test -s "$MODEL_CHECKPOINT/$file" || {
echo "Missing or empty: $file" >&2
exit 1
done
echo "Checkpoint files verified."
The output is similar to:
Understand how SmolVLA works
SmolVLA is a compact vision-language-action (VLA) model designed for fine-tuning on robot demonstrations. It combines a pretrained SmolVLM2 vision-language backbone with an action expert:
- Camera images, the task instruction, and the current joint state provide context.
- The vision-language backbone encodes the images and text, while a projection encodes the robot state.
- A flow-matching action expert generates a chunk of continuous future joint commands.
- During evaluation, LeRobot executes commands from the chunk and requests updated chunks as new observations arrive.
An action chunk is a short sequence of commands rather than one command.
- During training, flow matching adds noise to demonstrated action chunks and learns how to recover the demonstrated actions.
- During evaluation, the model starts from noise and iteratively produces a chunk conditioned on the live observations and instruction.
The SmolVLA research paper describes the model and its asynchronous inference design.
Fine-tuning adapts the model to the SO-101 geometry, camera viewpoints, and demonstrated behavior. With this configuration, the vision encoder remains frozen while the action expert and projection layers learn from the dataset.
Review results from the example experiment
The following results come from the experiment performed while creating this Learning Path. The results show what happened with this dataset on the DGX Spark, and they aren’t expected values for every training run.
The example run completed 20,000 steps in about 30 hours. Mean loss decreased across successive 4,000-step windows:
| Steps | Mean training loss |
| 200–4,000 | 0.1031 |
| 4,200–8,000 | 0.0472 |
| 8,200–12,000 | 0.0287 |
| 12,200–16,000 | 0.0204 |
| 16,200–20,000 | 0.0175 |
The final logged loss was 0.017, and the last 2,000 steps stayed between 0.017 and 0.018. These values show stable optimization for this example but don’t measure physical task success.
You’ve now fine-tuned SmolVLA with the recorded SO-101 dataset.
Next, you’ll connect the follower and cameras to run controlled physical evaluations.
