Fine-tune SmolVLA for SO-101 on NVIDIA DGX Spark
Understand the SmolVLA fine-tuning workflow
Install LeRobot and prepare a Python environment
Connect the SO-101 and cameras
Calibrate and teleoperate the SO-101
Record and validate a pick-and-place dataset
Fine-tune SmolVLA with the recorded SO-101 demonstrations
Evaluate the fine-tuned SmolVLA model
Prepare the software environment
The tested workflow uses LeRobot v0.6.0, Python 3.12.3, and PyTorch 2.11.0 with CUDA 12.8.
Check that git, ffmpeg, and uv are installed:
git --version
ffmpeg -version
uv --version
If one of these tools is missing, follow the LeRobot installation documentation .
Create an isolated environment
Clone the official LeRobot repository and check out the tested revision, then create a virtual environment:
git clone https://github.com/huggingface/lerobot.git
cd lerobot
git checkout 30da8e687a6dfc617fcd94afc367ac7071c376ce
uv venv --python 3.12 .venv
source .venv/bin/activate
uv pip install -e ".[core_scripts,training,feetech,smolvla]"
The extras install the robot command-line tools, training dependencies, Feetech motor support, and SmolVLA dependencies.
Verify LeRobot and CUDA
Print the core versions and confirm that PyTorch can see CUDA:
python -c "import platform, torch; from importlib.metadata import version; print({'python': platform.python_version(), 'lerobot': version('lerobot'), 'torch': torch.__version__, 'cuda': torch.cuda.is_available()})"
The output from the DGX Spark is similar to:
{'python': '3.12.3', 'lerobot': '0.6.0', 'torch': '2.11.0+cu128', 'cuda': True}
Verify the commands that you’ll use later:
for cli in lerobot-calibrate lerobot-find-cameras lerobot-find-port \
lerobot-record lerobot-rollout lerobot-teleoperate lerobot-train; do
command -v "$cli" > /dev/null || exit 1
done
The loop exits without output when all commands are available.
Authenticate with Hugging Face
Sign in to Hugging Face interactively:
hf auth login
hf auth whoami
Follow the browser or terminal prompt to complete authentication.
You now have a Python environment with CUDA, LeRobot’s SO-101 tools, and SmolVLA dependencies. Keep this terminal active.
Next, you’ll connect the two arms and cameras to the DGX Spark and identify their device paths.
