Encode and decode mnemonics and operands
You can now disassemble the binaries to check for Scalable Matrix Extension 2 (SME2) instructions.
Return to the project directory and select the example binary:
cd "$HOME/arm64-extension-inspection"
BIN=sme2-positive
Assemblers encode Arm Instruction Set Architecture (ISA) mnemonics and operands into 32-bit words. A disassembler decodes those words to recover the mnemonics and operands.
Use the example program that you created earlier to explore assembly and disassembly. When you wrote the source, you included the following line:
fmopa za0.s, p0/m, p0/m, z0.s, z1.s
The mnemonic is fmopa. The assembler converts fmopa and its operands into the following four bytes:
00 00 81 80 -> 0x80810000 -> fmopa za0.s, p0/m, p0/m, z0.s, z1.s
The operands identify the ZA tile, predicate registers, and vector registers.
Create a filter for SME and SME2 instructions
awk is a command-line tool for processing text. This awk script filters disassembly output by checking instruction names and operands. It recognizes the state-control, ZA access, matrix-operation, and SME2 predicate instructions.
Create strict-sme2.awk:
cat > strict-sme2.awk <<'EOF'
function has_pn_operand(text, mnemonic, pattern) {
    pattern = "(^|[[:space:]])" mnemonic "[[:space:]]+" \
              "pn(8|9|1[0-5])(\\.[bhsd])?([[:space:],]|$)"
    return text ~ pattern
function is_strict_sme2(line, text) {
    text = tolower(line)
    if (text ~ /(^|[[:space:]])(smstart|smstop)([[:space:]]|$)/)
        return 1
    if (text ~ /(^|[[:space:]])msr[[:space:]]+svcr(sm|za|smza)([[:space:],]|$)/)
        return 1
    if (text ~ /(^|[[:space:]])(bfmopa|bfmops|fmopa|fmops|smopa|smops|umopa|umops)([[:space:]]|$)/ ||
        text ~ /(^|[[:space:]])(sumopa|sumops|usmopa|usmops|bmopa|bmops)([[:space:]]|$)/)
        return 1
    if (text ~ /(^|[[:space:]])fmla[[:space:]]+za([0-9]|\.)/)
        return 1
    if (text ~ /(^|[[:space:]])(ld1|st1)[bhwdq][[:space:]]+\{[[:space:]]*za/)
        return 1
    if (text ~ /(^|[[:space:]])zero[[:space:]]+\{[[:space:]]*za/)
        return 1
    if (has_pn_operand(text, "ptrue"))
        return 1
    if (has_pn_operand(text, "whilelt") &&
        text ~ /(^|[[:space:],])vlx(2|4)([[:space:],]|$)/)
        return 1
    return 0
is_strict_sme2($0) { print }
EOF
The filter accepts ptrue only when its first operand is pn8 through pn15. It accepts whilelt only with that register range and a vlx2 or vlx4 operand. It rejects ordinary Scalable Vector Extension (SVE) forms such as ptrue p0.s.
Note
This filter recognizes the instruction forms that are used in the example binaries. It doesn’t detect every SME or SME2 instruction. Check the instruction reference and test any additional matching rules against binaries with and without the instructions.
Decode with otool
The otool command selects the arm64 slice and disassembles its main executable code section.
Apply the filter to decoded text rather than scanning raw bytes or strings:
otool -tvV -arch arm64 "$BIN" | awk -f strict-sme2.awk
The output is similar to:
        0000000100000424  smstart
000000010000042c  ptrue  pn8.s
0000000100000430  whilelt  pn8.s, x0, x0, vlx2
0000000100000434  zero  {za}
0000000100000438  fmopa  za0.s, p0/m, p0/m, z0.s, z1.s
000000010000043c  smstop
Instruction addresses can change when you rebuild the program. When comparing disassembler output for the same binary, check that the addresses match.
Cross-check with llvm-objdump
The llvm-objdump disassembler can show four bytes of each instruction. The --mattr option enables decoding of SME and SME2 instructions:
xcrun llvm-objdump -d --macho --arch=arm64 --mattr=+sme,+sme2 "$BIN" |
        100000424:  7f 47 03 d5  smstart
10000042c:  10 78 a0 25  ptrue  pn8.s
100000430:  10 44 a0 25  whilelt  pn8.s, x0, x0, vlx2
100000434:  ff 00 08 c0  zero  {za}
100000438:  00 00 81 80  fmopa  za0.s, p0/m, p0/m, z0.s, z1.s
10000043c:  7f 46 03 d5  smstop
The tools display leading zeros differently, but the instruction addresses match. Compare the addresses, bytes, and decoded instructions:
Instruction addressExecutable bytesDecoded instructionPurpose
0x1000004247f 47 03 d5smstartEnable streaming mode and ZA
0x10000042c10 78 a0 25ptrue pn8.sInitialize an SME2 predicate-as-counter
0x10000043010 44 a0 25whilelt pn8.s, x0, x0, vlx2Create an SME2 two-vector predicate
0x100000434ff 00 08 c0zero {za}Clear ZA matrix storage
0x10000043800 00 81 80fmopa za0.s, ...Update a ZA tile with an outer product
0x10000043c7f 46 03 d5smstopDisable streaming mode and ZA
Both disassemblers identify the same instructions in the same binary. This confirms their presence, but it doesn’t show whether they run.
Inspect the complete function
Use the function symbol to display all its instructions, from the label through the ret instruction:
  sed -n '/_sme2_fixture_kernel:/,/ret/p'
0000000100000428  ptrue  p0.s
0000000100000440  ret
The function contains setup instructions, matrix operations, and cleanup instructions. Their presence doesn’t mean that the application calls this function.
Check the comparison binaries
Apply the same disassembler and filter to both comparison binaries:
for CONTROL in string-only-control plain-arm64-control; do
  printf '%s: ' "$CONTROL"
  HITS=$(otool -tvV -arch arm64 "$CONTROL" | awk -f strict-sme2.awk)
  if [ -n "$HITS" ]; then printf '%s\n' "$HITS"; else printf 'no strict hits\n'; fi
done
The expected output is:
        string-only-control: no strict hits
plain-arm64-control: no strict hits
The string-only comparison binary still contains the SME2-related string and symbol that you found earlier. The filter finds no matching instructions because it checks disassembled code rather than strings or symbol names.
You’ve verified SME and SME2 instructions in the binary by examining their bytes, operands, addresses, and surrounding code.
Next, you’ll combine these checks in a reusable script and adapt the method to other instruction groups and binary formats.
