Why adapt for customer support?
In the previous section, you built a fully offline voice assistant by combining local speech-to-text (STT) with vLLM for language generation.
You can transform that general-purpose chatbot into a task-specific customer service agent designed to deliver fast, focused, and context-aware assistance.
Unlike open-domain chatbots, customer-facing assistants must meet stricter communication standards. Users expect direct answers, not verbose or vague explanations, with fast responses and no long pauses. The assistant should remember previous questions or actions to support multi-turn interactions.
These needs are especially relevant for password resets (“I forgot my account password and need help resetting it”), order tracking (“Can you track my recent order and tell me when it will arrive?”), billing issues (“Why was I charged twice this month?”), and subscription management (“I want to cancel my subscription and avoid future charges”). Such queries need language generation, structured behavior, and task memory.
What you’ll build in this section
You’ll enhance your assistant with three critical upgrades:
  1. Role-Specific System Prompts
Define your assistant’s personality and responsibilities (support agent, coach, guide) through system messages. Learn how prompt engineering influences tone, detail level, and actionability.
  1. Multi-Turn Memory
Enable the assistant to recall recent interactions and respond within context. You’ll manage a rolling history of messages while avoiding token overflow.
  1. (Optional) Secure Knowledge Retrieval
Explore how to integrate local company data using vector search. This allows the assistant to answer questions based on private documents, without ever sending data to the cloud.
This prepares your system for high-trust environments such as:
  • Enterprise customer support
  • Internal help desks
  • Regulated industries (healthcare, finance, legal)
By the end of this section, your assistant behaves like a real support agent. It can respond quickly, maintain context, and optionally access internal knowledge to resolve complex requests.
Control AI behavior with system prompts
To make your AI assistant behave like a domain expert (such as a support agent or tour guide), you need language generation and instructional control.
In OpenAI-compatible APIs (like vLLM), you can provide a special message with the role set to “system”. This message defines the behavior and tone of the assistant before any user input is processed.
A system prompt gives your assistant a role to play such as a polite and helpful customer service agent, a knowledgeable tour guide, or a motivational fitness coach. By customizing the system prompt, you can shape the assistant’s language and tone, restrict or expand the type of information it shares, and align responses with business needs such as short and precise replies for help desks.
Define the system prompt behavior
To turn your general-purpose voice assistant into a focused role-specific agent, you must guide the language model’s behavior. This is done by defining a system prompt that acts as a task instruction.
For example:
Support Agent:
You are a professional customer support assistant. Always prioritize clarity and solve customer issues politely and efficiently.
Fitness Coach:
You are a friendly and motivational fitness coach. Offer helpful workout tips and health advice.
Tour Guide:
You are an enthusiastic travel guide. Recommend popular tourist destinations and answer cultural questions.
This Learning Path uses customer service as an example. Add the following at the top of your script:
SYSTEM_PROMPT = """You are a professional customer support assistant.
Respond politely and concisely.
Focus on solving the user's issue.
Do not include unnecessary apologies or long explanations.
If required information is missing, ask a clear follow-up question."""
This prompt guides the model to respond effectively, even when the user’s input is vague, by reducing ambiguity, maintaining a consistent tone, and helping the assistant stay on topic and solution-oriented.
Inject the role instruction into the user message
Instead of sending a separate “system” role (which may cause vLLM to return a formatting error), you can prepend the role instruction directly into the user’s message. This keeps control over the assistant’s behavior while maintaining compatibility with vLLM’s expected message format.
Locate the following code in your previous Python script:
"messages": [
    {"role": "user", "content": user_text}
Add SYSTEM_PROMPT at the beginning of the messages:
messages = [
    {"role": "user", "content": SYSTEM_PROMPT + "\n\n" + user_text}
This line embeds your desired assistant role (like customer support) directly into the input and ensures that vLLM treats the message as valid by alternating roles correctly between user and assistant. By combining prompt and question, the assistant behaves like a helpful agent without triggering message formatting errors.
Choose the right response length for each role
Different assistant roles require different response styles. A customer service agent should be concise and focused, while a tour guide or teacher may need to provide more elaboration.
To control the response length dynamically, we calculate max_tokens using this formula:
max_tokens = min(512, max(64, len(user_text.split()) * 5))
Here’s how this formula works: len(user_text.split()) counts how many words the user spoke, multiplication by 5 estimates about five tokens per word (a rough average), max() ensures a minimum of 64 tokens to avoid short responses, and min() caps the response length to 512 tokens to avoid delays or exceeding model limits. This gives you a balanced reply size that grows with input length but stays within safe bounds.
tip
Adjust this formula based on role. Customer support needs shorter replies, so use max_tokens = 256 for snappy responses. Tour guide or teacher roles are more verbose and can use max_tokens = 384 or higher. For FAQ retrieval, adjust based on expected answer complexity.
Run the complete customer service assistant
Save the following code to a file named customer-assist.py:
import pyaudio
import numpy as np
import webrtcvad
import time
import torch
import threading
import queue
import requests
from faster_whisper import WhisperModel
from collections import deque
# --- Parameters ---
SAMPLE_RATE = 16000
FRAME_DURATION_MS = 30
FRAME_SIZE = int(SAMPLE_RATE * FRAME_DURATION_MS / 1000)
VAD_MODE = 3
SILENCE_LIMIT_SEC = 1.0
MIN_SPEECH_SEC = 2.0
VLLM_ENDPOINT = "http://localhost:8000/v1/chat/completions"
MODEL_NAME = "/models/mistral-7b"
# --- Init VAD and buffers ---
vad = webrtcvad.Vad(VAD_MODE)
speech_buffer = deque()
speech_started = False
last_speech_time = time.time()
# --- Init Thread and Queue ---
audio_queue = queue.Queue()
stop_event = threading.Event()
# --- Init Whisper model ---
device = "cpu"  # "cpu" or "gpu"
compute_type = "int8"  # "int8" or "float16", "int8", "int4"
model = WhisperModel("medium.en", device=device, compute_type=compute_type)
# --- System Prompt ---
SYSTEM_PROMPT = """ You are a professional customer support assistant.
Respond politely, clearly, and concisely.
# --- Audio capture thread ---
def audio_capture():
    pa = pyaudio.PyAudio()
    stream = pa.open(format=pyaudio.paInt16,
                     channels=1,
                     rate=SAMPLE_RATE,
                     input=True,
                     frames_per_buffer=FRAME_SIZE)
    print(" Listening... Press Ctrl+C to stop")
    try:
        while not stop_event.is_set():
            frame = stream.read(FRAME_SIZE, exception_on_overflow=False)
            audio_queue.put(frame)
    finally:
        stream.stop_stream()
        stream.close()
        pa.terminate()
# --- Start audio capture thread ---
threading.Thread(target=audio_capture, daemon=True).start()
# --- Main loop: process queue and transcribe ---
try:
    while True:
        if audio_queue.empty():
            time.sleep(0.01)
            continue
        frame = audio_queue.get()
        is_speech = vad.is_speech(frame, SAMPLE_RATE)
        if is_speech:
            speech_buffer.append(frame)
            speech_started = True
        elif speech_started:
            speech_duration = len(speech_buffer) * (FRAME_DURATION_MS / 1000.0)
            silence_duration = time.time() - last_speech_time
            if silence_duration > SILENCE_LIMIT_SEC:
                if speech_duration >= MIN_SPEECH_SEC:
                    print(" Transcribing buffered speech...")
                    audio_bytes = b"".join(speech_buffer)
                    audio_np = np.frombuffer(audio_bytes, dtype=np.int16).astype(np.float32) / 32768.0
                    segments, _ = model.transcribe(audio_np, language="en")
                    user_text = " ".join([seg.text.strip() for seg in segments]).strip()
                    print(f"\n User: {user_text}\n")
                    messages = [
                    response = requests.post(VLLM_ENDPOINT, json={
                        "model": MODEL_NAME,
                        "messages": messages,
                        "max_tokens": max_tokens
                    result = response.json()
                    if "choices" not in result:
                        print(" Error from vLLM:", result.get("error", "Unknown error"))
                        continue
                    reply = result["choices"][0]["message"]["content"].strip()
                    print(f" AI  : {reply}\n")
                else:
                    print(f" Skipped short segment ({speech_duration:.2f}s < {MIN_SPEECH_SEC}s)")
                speech_buffer.clear()
except KeyboardInterrupt:
    print(" Stopped")
finally:
    stop_event.set()
Run the assistant:
python3 customer-assist.py
The assistant will listen for your voice input and respond as a customer support agent, using the system prompt to guide its behavior.
This approach works well for single-turn interactions. You’ll extend this pattern to multi-turn conversations, storing and managing multiple rounds of user and assistant prompts.
