Prepare a broken release checker
After setting up Hermes, you can prepare a broken release checker and use Hermes and Muse Glimmer to fix it.
A release checker reads test results and decides whether deployment can proceed. You’ll use a broken release checker that can approve a release despite failed tests and return the wrong exit status. The example image is a release-summary dashboard showing an incorrect deployment decision. Ask Hermes to read the image and identify the problem, inspect the code, and repair it so that the tests pass.
Image Alt Text:Example release summary showing one passed test, one failed test, and one skipped test, with an incorrect READY decisionIllustrative release-summary dashboard
Use release_tool.py and test_release_tool.py that you downloaded earlier. Copy the files into the workspace:
cd ~/muse-agent
cp test_release_tool.py demo/input/
cp release_tool.py demo/input/release_tool.original.py
cp release_tool.py demo/output/
The acceptance tests and original code are visible through the read-only input mount. The agent can edit the working copy and write notes, but it can’t change the acceptance tests.
Reproduce the initial failure from your SSH terminal:
cd ~/muse-agent/demo/output
PYTHONPATH="$PWD" python3 -m unittest discover \
  -s ~/muse-agent/demo/input -p test_release_tool.py -v
Expect four failed tests. They cover all-passed, mixed pass and fail, skipped-only, and empty test runs. Their assertions also check the exit status that a deployment pipeline would use.
Ask Hermes to read the image and repair the checker
Exit the earlier Hermes session with /quit.
Start a new session with the downloaded release-summary image:
cd ~/muse-agent
~/muse-agent/bin/hermes chat --cli --toolsets terminal \
  --image "$HOME/muse-agent/release-summary.png" \
  -q "Read the image. Report the passed, failed, and skipped counts, the displayed release decision, and whether deployment should proceed. Do not run tools or change files yet."
Hermes should report that it’s attaching the image natively. This confirms that the image is sent directly to the local model. Expect one passed, one failed, and one skipped test. The image displays READY, but the failed test should block deployment. --image attaches the file from the DGX Spark.
Keep the Hermes session open and enter the following prompt:
Use the image you just read as context. Use only the terminal tool.
Diagnose and fix /demo/output/release_tool.py.
Run the acceptance tests first:
PYTHONPATH=/demo/output python3 -m unittest discover -s /demo/input -p test_release_tool.py -v
Read the checker and /demo/input/test_release_tool.py together in one call.
Inspect the failures before editing, then make the smallest repair using
standard shell utilities. Do not modify anything under /demo/input.
Run the same tests again. Write a short /demo/output/fix-notes.md in one
command, describing the root cause, changes, and actual test result.
Read back the repaired code and notes, then give a concise final answer.
Group related commands; do not write notes one line per call.
Do not install packages or use the network.
Watch the trace for the failed test run, code inspection, edits, and successful rerun. Muse Glimmer selects actions on the GPU, while Hermes and the tools run them on the Arm-based CPU.
The exact commands and explanation can vary. If Hermes requests approval, inspect the command and its target paths before responding. For this Learning Path, writes should stay under /demo/output. Don’t approve changes to host or sandbox configuration.
Verify the repair
From the SSH session that you used to inspect the Docker container, run the same acceptance tests independently:
cat ~/muse-agent/demo/output/fix-notes.md
diff -u ~/muse-agent/demo/input/release_tool.original.py \
  ~/muse-agent/demo/output/release_tool.py
Expect all four tests to pass and OK. The diff should show the readiness check and exit-status fixes. diff returns exit code 1 when files differ. This is expected. Check that the notes match the code and test output.
Troubleshoot if the task doesn’t finish
The setup helper saves the Hermes configuration in ~/muse-agent/hermes-home/config.yaml. It calls the local model connection spark-local. That entry points to the Muse Glimmer server on Spark.
SymptomWhat to check
Hermes can’t reach Muse GlimmerKeep the server running in its SSH session. On the Spark, run curl --fail http://127.0.0.1:8000/health and check the server terminal for errors.
Hermes rejects the context lengthMatch the export --max-seq-len 65536, the server --max-context 65536, and context_length: 65536 in the Hermes configuration.
Hermes replies but doesn’t run toolsLaunch Hermes with --cli --toolsets terminal. Check that the server uses --tool-parser atem. Ensure that the spark-local configuration retains the sampling settings of the helper and null reasoning_effort override.
Hermes can’t process the imageUse the vision export and its --pos-embed-path. Check agent.image_input_mode: native in the Hermes configuration and the image path on the Spark.
The agent can’t find the code or testsCheck that the preparation commands copied the files into ~/muse-agent/demo/input and demo/output. Inspect the container mounts and ensure that they appear as /demo/input and /demo/output.
Hermes asks for command approvalRead the command before approving it. Allow edits only under /demo/output, and reject changes to host or sandbox settings.
Tests still fail after the repairGive Hermes the failing test output and ask it to revise the working copy. Keep /demo/input read-only and rerun the independent host tests.
Stop and resume Hermes
Exit Hermes with /quit. Stop the model server with Ctrl+C in its SSH session. Inspect docker ps and stop only the tool container if it remains running. Keep the reusable model export.
To resume, reconnect to Spark, activate the environment, and start the model server:
cd ~/muse-agent/executorch
export PATH=/usr/local/cuda/bin:$PATH
source ../executorch-venv/bin/activate
python -m executorch.examples.models.muse_glimmer.serving.serve \
  --model-path exports/spark-native-vision-64k/model.pte \
  --data-path exports/spark-native-vision-64k/aoti_cuda_blob.ptd \
  --pos-embed-path exports/spark-native-vision-64k/pos_embed.bin \
  --tokenizer-path exports/tokenizer.json \
  --hf-tokenizer exports \
  --worker-bin cmake-out/examples/models/muse-glimmer/muse_glimmer_worker \
  --model-id muse-glimmer-30B \
  --tool-parser atem \
  --max-context 65536 --host 127.0.0.1 --port 8000
Keep the server running.
In a second SSH session, start the agent:
cd ~/muse-agent
No repeat export or installation is needed.
You’ve verified that the agent interpreted the image and reproduced the failure. The agent repaired the checker. The repaired checker passed the read-only tests.
Next, you’ll explore ways to extend the agent with Muse Glimmer features and additional Hermes tools.
