Give feedback
AI-assisted
Close
How do I choose and stick to compatible Isaac Lab, Isaac Sim, and Python versions?
Use one compatible API set throughout training. Choose either Isaac Lab v2.3.2 with Isaac Sim 5.1.0 and Python 3.11, or Isaac Lab v3.0.0-beta2.patch1 with Isaac Sim 6.0.0 or 6.0.1 and Python 3.12.
How do I know the task and RL library I picked are supported?
Check the Isaac Lab environment list for supported task–library combinations. Start with a library that provides an upstream agent configuration for your task.
How do I verify that the trained policy opens the drawer?
Confirm that the arm aligns with the handle, moves the drawer along its rail after contact, and keeps the opening motion stable without slipping or shaking.
What changes when I switch between MAPPO and IPPO for the two Shadow Hands?
With MAPPO, the critic uses shared state during training while each hand acts from its own observations. With IPPO, each agent learns independently in the same environment.
What result should I expect from AMP training?
AMP uses reference motion‑capture data to guide learning toward smoother, more humanlike motion. Successful training produces trajectories that track the reference motions more closely than a standard RL policy.
Return to Laptops and Desktops
