Choose your technical toolkit
Isaac Lab integrates several reinforcement learning (RL) libraries.
You’ve used Robotic Systems Lab Reinforcement Learning (RSL-RL) for manipulation, RL Games for factory, and skrl for Multi-Agent Proximal Policy Optimization (MAPPO) and Adversarial Motion Priors (AMP) tasks. Now, you’ll compare why each task uses a different library.
Library choice affects the agent configuration, checkpoint format, and available algorithms. Start with a library that has an upstream agent configuration for your task, then consider algorithm support and workflow needs.
The following table summarizes four commonly used reinforcement learning libraries in Isaac Lab, with links to their repositories and the task profiles they fit best:
LibraryCore strengthBest fit
RSL-RL Efficient on-policy trainingLocomotion and many manager-based tasks
RL Games Recurrent-policy supportFactory tasks and other registered RL Games configurations
skrl MAPPO, Independent PPO (IPPO), and AMP supportMulti-agent and motion-prior tasks
Stable Baselines3 (SB3) Standardized algorithms and APIWhen the environment registers an SB3 configuration and supports baselines and prototyping
Tip
No single library is the best choice for every task. A practical strategy is to start with the tool that helps you establish a baseline quickly, then move to a more specialized training stack when the task requires it.
What you’ve accomplished
You’ve progressed from basic manipulation to workflow-level decisions for Isaac Lab on Arm. You’ve practiced task selection, library tradeoffs, MARL and AMP workflows, and when distributed training is worth considering.
Next, you can adapt these scripts as reference implementations for your own USD assets, robot models, scenes, and task constraints. Start with a single-GPU baseline, then expand only when workload scale requires it.
