Before you run robotic simulations and reinforcement learning workloads, you need to prepare your DGX Spark development environment and install the dependencies required for Isaac Sim and Isaac Lab.
In this section you’ll:
The full setup typically takes 15–20 minutes on a DGX Spark system and requires approximately 50 GB of available disk space.
Begin by confirming that the DGX Spark system has the expected hardware and software configuration.
Check the CPU architecture:
lscpu | head -5
The output is similar to:
Architecture: aarch64
CPU op-mode(s): 64-bit
Byte Order: Little Endian
CPU(s): 20
On-line CPU(s) list: 0-19
The Architecture field should report aarch64, indicating that the system is running on Arm.
Check that the Blackwell GPU is detected by the NVIDIA driver:
nvidia-smi
You will see output similar to:
| NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 NVIDIA GB10 On | 0000000F:01:00.0 Off | N/A |
The GPU name should appear as NVIDIA GB10, confirming that the Grace–Blackwell GPU is available.
Confirm the CUDA toolkit is installed:
nvcc --version
The expected output includes:
Cuda compilation tools, release 13.0, V13.0.88
Isaac Sim requires GCC/G++ version 11 when building components from source. Install the required compiler version and configure it as the system default. Update the package index and install the GCC 11 toolchain:
sudo apt update && sudo apt install -y gcc-11 g++-11
Register GCC 11 as the default compiler using update-alternatives. This allows multiple compiler versions to coexist while prioritizing GCC 11 for builds. The priority value of 200 ensures GCC 11 takes precedence over other installed versions:
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-11 200
sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-11 200
Next, install Git LFS (Large File Storage). Isaac Sim repositories use Git LFS to manage large binary assets such as models and simulation data.
sudo apt install -y git-lfs
After installation, verify that the compiler and Git LFS are available:
gcc --version
g++ --version
git lfs version
The gcc and g++ commands should report version 11.x, and git lfs version should display the installed Git LFS version.
Next, download the Isaac Sim source repository and its required assets.
Start by cloning the repository. The –depth=1 option performs a shallow clone to reduce download size, and –recursive ensures all required submodules are fetched.
cd ~
git clone --depth=1 --recursive https://github.com/isaac-sim/IsaacSim
cd IsaacSim
Isaac Sim stores large simulation assets (such as USD environments, textures, and prebuilt components) using Git Large File Storage (LFS). Initialize Git LFS and download the required assets:
git lfs install
git lfs pull
Once the repository and assets are downloaded, build Isaac Sim using the provided build script:
./build.sh
By default, the build uses all available CPU cores on the Grace processor. On DGX Spark, compilation typically takes 10-15 minutes.
When the build finishes successfully, you will see output similar to:
BUILD (RELEASE) SUCCEEDED (Took 674.39 seconds)
After the build completes, configure environment variables so that your shell can locate the Isaac Sim binaries and Python runtime.
Navigate to the IsaacSim directory if you are not already there, then export the following variables:
export ISAACSIM_PATH="${PWD}/_build/linux-aarch64/release"
export ISAACSIM_PYTHON_EXE="${ISAACSIM_PATH}/python.sh"
These variables are used by Isaac Lab and other tools to locate the Isaac Sim runtime.
| Variable | Purpose |
ISAACSIM_PATH | Points to the compiled Isaac Sim binaries and libraries under the _build directory |
ISAACSIM_PYTHON_EXE | References the Python wrapper script that runs Python with Isaac Sim’s dependencies preloaded |
To make these environment variables persist across terminal sessions, add them to your shell configuration file. Run the following commands:
echo 'export ISAACSIM_PATH="$HOME/IsaacSim/_build/linux-aarch64/release"' >> ~/.bashrc
echo 'export ISAACSIM_PYTHON_EXE="${ISAACSIM_PATH}/python.sh"' >> ~/.bashrc
source ~/.bashrc
After this step, the variables will be available automatically whenever you open a new terminal.
Launch Isaac Sim to verify the build was successful. On some aarch64 systems, Isaac Sim may require preloading the GNU OpenMP runtime (libgomp) to avoid library compatibility issues. Setting the LD_PRELOAD environment variable ensures the correct library is loaded before Isaac Sim starts.
Run the following command to launch Isaac Sim:
export LD_PRELOAD="$LD_PRELOAD:/lib/aarch64-linux-gnu/libgomp.so.1"
${ISAACSIM_PATH}/isaac-sim.sh
If the installation is correct, Isaac Sim opens its viewer window (or starts in headless mode if no display is available). During startup, the console output should report initialization of the Blackwell GPU and the physics simulation engine.
Once you confirm that Isaac Sim starts successfully, stop the application by pressing:
Ctrl + C
This returns you to the terminal and confirms that the build and runtime environment are functioning correctly.
After confirming that Isaac Sim runs correctly, you can install Isaac Lab, which provides the reinforcement learning environments and training pipelines used in this learning path. Start by cloning the Isaac Lab repository into your home directory:
cd ~
git clone --recursive https://github.com/isaac-sim/IsaacLab
cd IsaacLab
Isaac Lab expects to locate an Isaac Sim installation in a directory named _isaac_sim inside the repository. Instead of copying files, create a symbolic link pointing to the Isaac Sim build directory that you configured earlier.
First confirm that the ISAACSIM_PATH variable is set:
echo "ISAACSIM_PATH=$ISAACSIM_PATH"
Then create the symbolic link
ln -sfn "${ISAACSIM_PATH}" "${PWD}/_isaac_sim"
This links the Isaac Lab repository to the Isaac Sim installation that was built in the previous steps.
Verify the symbolic link is correct:
ls -l "${PWD}/_isaac_sim/python.sh"
You should see the symlink pointing to your Isaac Sim build directory.
Next, install Isaac Lab and its Python dependencies:
./isaaclab.sh --install
This command installs the Isaac Lab Python packages, RL libraries (RSL-RL, rl_games, skrl, Stable Baselines3), and additional dependencies into the Isaac Sim Python environment.
Confirm that Isaac Lab is installed correctly by listing the available RL environments:
./isaaclab.sh -p scripts/environments/list_envs.py
If the installation is successful, the command prints a list of available environments. The output will include entries similar to:
Isaac-Cartpole-v0
Isaac-Cartpole-Direct-v0
Isaac-Velocity-Flat-H1-v0
Isaac-Velocity-Rough-H1-v0
Isaac-Lift-Cube-Franka-v0
Isaac-Reach-Franka-v0
If the environment list displays without errors, both Isaac Sim and Isaac Lab are correctly installed and ready for use.
You’re now ready to run and train RL tasks using Isaac Lab environments.
In this section you’ve:
Your development environment is now fully configured for robot simulation and RL workflows. In the next section, you’ll run your first robot simulation and begin interacting with Isaac Sim through Python scripts.
