In this Learning Path, you’ll build, configure, and run robotic simulation and reinforcement learning (RL) workflows using NVIDIA Isaac Sim and Isaac Lab on an Arm-based DGX Spark system. The NVIDIA DGX Spark is a personal AI supercomputer powered by the GB10 Grace Blackwell Superchip. The system couples an Arm CPU cluster with a Blackwell GPU and a unified memory architecture to accelerate simulation orchestration, sensor preprocessing, physics, rendering, and RL training.
NVIDIA’s Isaac Sim and Isaac Lab tools together provide an end-to-end robotics development workflow:
This section introduces both tools and explains how DGX Spark supports high-performance robotic simulation and RL experimentation.
Isaac Sim is a robotics simulation platform built on NVIDIA Omniverse. It provides GPU-accelerated physics and rendering to enable high-fidelity robot simulation.
Core capabilities include:
| Capability | Description |
| Physics simulation | High-fidelity rigid body, articulation, and soft-body physics powered by NVIDIA PhysX |
| Sensor simulation | Simulated cameras, LiDAR, IMU, and contact sensors that generate realistic data streams |
| Photorealistic rendering | Ray-traced rendering for vision-based tasks, domain randomization, and synthetic data generation |
| Parallel environments | Run thousands of simulation instances simultaneously on a single GPU for massive data throughput |
| Python API | Full programmatic control of scenes, robots, and simulations through Python scripting |
Isaac Sim lets you prototype and validate robot behavior in a controlled virtual environment before physical testing.
Isaac Lab is a reinforcement learning framework built on top of Isaac Sim. It provides pre-built RL environments, training scripts, and evaluation tools for common robotics tasks such as locomotion, manipulation, and navigation.
Isaac Lab supports two task design workflows:
| Workflow | Description | Best for |
| Manager-Based | Modular environment components (observations, rewards, terminations) defined through separate manager classes | Structured environments with reusable components |
| Direct | A single class defines the entire environment logic, similar to traditional Gymnasium environments | Rapid prototyping and full control over environment logic |
Isaac Lab integrates with multiple reinforcement learning libraries, including:
| RL Library | Supported Algorithms |
| RSL-RL | PPO ( Proximal Policy Optimization ) |
| rl_games | PPO, LSTM, vision-based policies |
| skrl | PPO, IPPO, MAPPO, AMP (Adversarial Motion Priors) |
| Stable Baselines3 (sb3) | PPO |
In this Learning Path, you will use RSL-RL, a lightweight and efficient PPO implementation commonly used for locomotion training.
The NVIDIA DGX Spark combines the Grace CPU and Blackwell GPU through a unified memory architecture, making it uniquely suited for robotics simulation and training workloads.
| DGX Spark feature | Impact on robotics workflows |
| Grace CPU (Arm Cortex-X925 / A725, 20 cores) | Manages environment orchestration, reward calculation, and sensor data preprocessing with high single-thread performance |
| Blackwell GPU (CUDA cores + 5th-gen Tensor Cores) | Accelerates physics simulation, parallel environment stepping, and neural network forward/backward passes |
| 128 GB unified memory (NVLink-C2C) | Eliminates CPU-GPU data transfer bottlenecks; simulation state and model weights share the same address space |
| NVLink-C2C (900 GB/s bidirectional) | Enables near-zero-latency communication between CPU-driven orchestration and GPU-driven simulation |
| Compact desktop form factor | Run data-center-class robotics workloads on your desk without remote cluster access |
Traditional robotics development requires separate machines for simulation, training, and deployment. DGX Spark consolidates these into a single platform. The unified memory is especially valuable for Isaac Sim, where physics state, rendered sensor data, and RL training tensors all reside in GPU-accessible memory without explicit copies.
A typical robotics workflow using Isaac Sim and Isaac Lab on DGX Spark follows these steps:
The full workflow can run locally on a DGX Spark system. Running Isaac Sim in headless mode (without visualization) maximizes GPU utilization for training, while enabling visualization allows interactive inspection of robot behavior during debugging or validation.
Isaac Lab includes a large set of pre-built environments organized by task type:
| Category | Examples | Description |
| Classic | Cartpole, Ant, Humanoid | MuJoCo-style control benchmarks for algorithm development |
| Manipulation | Reach, Lift, Stack, Open-Drawer | Fixed-arm tasks using Franka, UR10, and other robots |
| Contact-rich Manipulation | Peg insertion, Gear meshing, Nut threading | Precision assembly tasks with the Franka robot |
| Locomotion | Anymal B/C/D, Unitree A1/Go1/Go2/H1/G1, Spot, Digit | Velocity tracking on flat and rough terrain for quadrupeds and humanoids |
| Navigation | Anymal C navigation | Point-to-point navigation with heading control |
| Multi-agent | Cart-Double-Pendulum, Shadow-Hand-Over | Tasks that require coordination among multiple agents |
After installing Isaac Lab in the next section, you can list the available environments using:
./isaaclab.sh -p scripts/environments/list_envs.py
You can also filter environments by keyword. For example, to list locomotion environments:
./isaaclab.sh -p scripts/environments/list_envs.py --keyword locomotion
For the complete list of environments, see the Isaac Lab Available Environments documentation.
In this Learning Path, you’ll:
By the end, you’ll have a working Isaac Sim and Isaac Lab development environment on DGX Spark and practical experience running a complete robotics reinforcement learning pipeline.
In this section:
In the next section, you’ll set up your development environment and install Isaac Sim and Isaac Lab on your DGX Spark system.
