# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/)
- [Explore persistent AI runtime architecture on NVIDIA DGX Spark](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/1_introduce/)
- [Build the DGX Spark AI runtime foundation](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/2_build/)
- [Deploy Hermes Agent as an orchestration runtime](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/3_deploy_orch_runtime/)
- [Add local LLM inference to Hermes Agent](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/4_local_llm/)
- [Build persistent semantic memory for Hermes Agent](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/5_persistent_memory/)
- [Add semantic retrieval and contextual reasoning to Hermes Agent](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/6_semantic_retrieval/)
- [Add autonomous workspace cognition to Hermes Agent](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/7_autonomous_workspace/)
- [Next Steps](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_persistent_agent/_next-steps/)
## Explore related resources
- [NVIDIA DGX Spark](https://www.nvidia.com/en-gb/products/workstations/dgx-spark/)
- [Build a RAG pipeline on Arm-based NVIDIA DGX Spark](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_spark_rag/)
- [Build an offline voice chatbot with faster-whisper and vLLM on DGX Spark](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_spark_voicechatbot/)
- [Unlock quantized LLM performance on Arm-based NVIDIA DGX Spark](https://learn.arm.com/learning-paths/laptops-and-desktops/dgx_spark_llamacpp/)
## Review frequently asked questions
### How do I know the base DGX Spark AI runtime is running correctly?
You’ll see containers for Ollama (inference), Qdrant (vector memory), and Open WebUI (browser access) running and healthy. Confirm that the persistent workspace exists and is mounted as expected.
### Where should I put documents so Hermes picks them up automatically?
Place files in `workspace/inbox/`. Hermes watches that path and handles `on_created()` events to start the workflow.
### I added Hermes but I don’t see summaries yet — what should I expect at this stage?
Not seeing summaries is expected. In its initial setup, Hermes acts as an orchestration and event layer, printing handling output but not invoking a language model until you connect it to Ollama.
### After I connect Hermes to Ollama, what result should I expect to confirm inference is working?
When you add a new document to `workspace/inbox/`, Hermes sends the content to the local model and you see an AI-generated summary in the runtime output. This indicates the inference path is wired correctly.
### How can I confirm persistent semantic memory is active in Qdrant?
Qdrant stores an embedding for each processed document. Check that new vector entries appear after Hermes handles files and are available for contextual retrieval in the workflow.
## Share
