Orchestrate a local Hermes AI agent on NVIDIA DGX Spark
Explore persistent AI runtime architecture on NVIDIA DGX Spark
Build the DGX Spark AI runtime foundation
Deploy Hermes Agent as an orchestration runtime
Add local LLM inference to Hermes Agent
Build persistent semantic memory for Hermes Agent
Add semantic retrieval and contextual reasoning to Hermes Agent
Add autonomous workspace cognition to Hermes Agent
Update Hermes to add proactive behavior
In this section, you’ll add autonomous workspace cognition to Hermes Agent.
In the previous section, Hermes could answer a question by retrieving relevant memory on demand. You’ll now add proactive behavior: Hermes will periodically review stored workspace memory, identify recurring themes, and write a summary without waiting for a user query.
For example, if the workspace contains notes about CPU orchestration, GPU inference, and semantic memory, Hermes can generate a scheduled workspace summary that explains those themes and how they relate to the current local AI runtime.
The runtime can already ingest documents, build semantic memory, and answer questions using retrieved context. You’ll now add a periodic cognition workflow that reviews stored memory and generates a workspace-level summary.
The workflow becomes:
-> scheduled cognition loop
-> Hermes aggregates summaries
-> Ollama analyzes recurring themes
-> workspace-summary.txt
This is the final stage of the Learning Path. Hermes becomes a persistent autonomous local AI runtime that can monitor, remember, retrieve, and periodically reason about workspace state.
Understand autonomous cognition
Autonomous cognition means the runtime performs useful reasoning without waiting for a new document or explicit query.
Hermes continues watching workspace/inbox/ and ingesting supported files into semantic memory. It continues answering questions from /workspace/query.txt and also periodically generates a workspace-level summary, writing the result to /workspace/memory/workspace-summary.txt. Runtime behavior is controlled by a policy file at /workspace/config/runtime.json.
The runtime remains local-first. Files, models, vector memory, and summaries stay on the DGX Spark system.
Create the runtime configuration directory and policy file
Create the configuration directory if it doesn’t already exist:
mkdir -p ~/dgx-hermes-agent/workspace/config
Create and edit the file ~/dgx-hermes-agent/workspace/config/runtime.json.
Add the following content:
"summary_interval_hours": 8,
"supported_extensions": [
".txt",
".md",
".log"
"retrieval_limit": 3,
"summary_output": "/workspace/memory/workspace-summary.txt"
The policy file controls runtime behavior without rebuilding the container.
| Policy | Purpose |
summary_interval_hours | Controls how often Hermes generates a workspace summary |
supported_extensions | Controls which file types Hermes ingests |
retrieval_limit | Records the intended semantic retrieval depth for the runtime policy |
summary_output | Defines where Hermes writes the workspace summary |
The verified code in this section keeps semantic retrieval at limit=3, matching the listed policy values. The policy file makes this setting visible for later hardening, where the retrieval function can load it dynamically.
Add autonomous cognition to Hermes
Open and edit the file ~/dgx-hermes-agent/hermes/agent.py.
Replace the file with the following version:
import os
import json
import uuid
import time
import ollama
from datetime import datetime
from qdrant_client import QdrantClient
from qdrant_client.models import (
Distance,
VectorParams,
PointStruct
from watchdog.observers import Observer
from watchdog.events import FileSystemEventHandler
WATCH_DIR = "/workspace/inbox"
CONFIG_PATH = "/workspace/config/runtime.json"
COLLECTION_NAME = "workspace_memory"
OLLAMA_HOST = os.getenv(
"OLLAMA_HOST",
"http://ollama:11434"
QDRANT_HOST = os.getenv(
"QDRANT_HOST",
"qdrant"
client = ollama.Client(host=OLLAMA_HOST)
qdrant = QdrantClient(
host=QDRANT_HOST,
port=6333
def ensure_collection():
collections = qdrant.get_collections().collections
names = [c.name for c in collections]
if COLLECTION_NAME not in names:
qdrant.create_collection(
collection_name=COLLECTION_NAME,
vectors_config=VectorParams(
size=768,
distance=Distance.COSINE
print(f"[Memory] Created collection: {COLLECTION_NAME}")
def load_runtime_config():
with open(CONFIG_PATH, "r") as f:
return json.load(f)
class WorkspaceHandler(FileSystemEventHandler):
def on_created(self, event):
if event.is_directory:
return
filename = os.path.basename(event.src_path)
# Ignore hidden files
if filename.startswith("."):
return
ext = os.path.splitext(filename)[1]
config = load_runtime_config()
supported_extensions = config.get(
"supported_extensions",
[".txt"]
if ext not in supported_extensions:
return
print(f"\n[Agent] New file detected:")
print(event.src_path)
process_file(event.src_path)
def generate_summary(content):
response = client.chat(
model="qwen2.5:7b",
messages=[
"role": "system",
"content": (
"You are a local AI workspace assistant. "
"Summarize the document in 3 concise bullet points."
"role": "user",
"content": content[:4000]
return response["message"]["content"]
def generate_embedding(content):
response = client.embed(
model="nomic-embed-text",
input=content[:4000]
return response["embeddings"][0]
def store_memory(path, content, summary, embedding):
point_id = str(uuid.uuid4())
qdrant.upsert(
points=[
PointStruct(
id=point_id,
vector=embedding,
payload={
"path": path,
"summary": summary,
print(f"[Memory] Stored document: {path}")
def search_memory(query):
print("\n[Memory] Searching semantic memory...")
embedding = generate_embedding(query)
results = qdrant.query_points(
query=embedding,
limit=3
).points
memories = []
for result in results:
payload = result.payload
memories.append({
"path": payload.get("path"),
"summary": payload.get("summary")
return memories
def query_workspace(question):
memories = search_memory(question)
context = "\n\n".join([
f"Document: {m['path']}\nSummary:\n{m['summary']}"
for m in memories
model="qwen2.5:7b",
messages=[
"role": "system",
"content": (
"You are a persistent AI workspace assistant. "
"Answer questions using the retrieved workspace memory."
"role": "user",
"content": (
f"Question:\n{question}\n\n"
f"Relevant workspace memory:\n{context}"
answer = response["message"]["content"]
print("\n[Workspace Query]")
print(question)
print("\n[Retrieved Memories]")
print(context)
print("\n[AI Response]")
print(answer)
def generate_workspace_summary():
print("\n[Cognition] Generating workspace summary...")
results = qdrant.scroll(
limit=10,
with_payload=True
)[0]
summaries = []
summaries.append(
payload.get("summary", "")
combined = "\n\n".join(summaries)
model="qwen2.5:7b",
messages=[
"role": "system",
"content": (
"You are an autonomous workspace cognition agent. "
"Analyze the workspace summaries and identify "
"important recurring themes and insights."
"role": "user",
"content": combined[:6000]
workspace_summary = response["message"]["content"]
output_path = config.get(
"summary_output",
with open(output_path, "w") as f:
f.write(
f"Workspace Summary\n"
f"Generated: {datetime.now()}\n\n"
f.write(workspace_summary)
print("\n[Cognition] Workspace summary updated:")
print(output_path)
def process_file(path):
try:
with open(path, "r", encoding="utf-8") as f:
content = f.read()
print("\n[Agent] Running summarization inference...")
summary = generate_summary(content)
print("\n[Agent] AI Summary:")
print(summary)
print("\n[Agent] Generating embeddings...")
embedding = generate_embedding(content)
store_memory(
path,
content,
summary,
embedding
except Exception as e:
print(f"[Agent] Error: {e}")
if __name__ == "__main__":
print("\n[Hermes Agent] Starting workspace watcher...")
print(f"[Hermes Agent] Monitoring: {WATCH_DIR}")
ensure_collection()
observer = Observer()
observer.schedule(
WorkspaceHandler(),
WATCH_DIR,
recursive=False
observer.start()
last_summary_time = 0
try:
while True:
time.sleep(5)
summary_interval_hours = config.get(
"summary_interval_hours",
8
interval_seconds = (
summary_interval_hours * 3600
current_time = time.time()
# Periodic autonomous cognition
if (
current_time - last_summary_time
> interval_seconds
last_summary_time = current_time
# Interactive semantic retrieval
if os.path.exists("/workspace/query.txt"):
with open("/workspace/query.txt", "r") as f:
question = f.read().strip()
os.remove("/workspace/query.txt")
except KeyboardInterrupt:
observer.stop()
observer.join()
Understand code trace
Hermes reads /workspace/config/runtime.json using load_runtime_config() at multiple points in the runtime loop. File filtering now uses the supported_extensions list from that config rather than a hardcoded constant, so you can update the list without rebuilding the container.
generate_workspace_summary() collects stored memory using qdrant.scroll() with limit=10 and with_payload=True. Hermes reads recent stored summaries without performing a semantic search. The combined summaries are sent to qwen2.5:7b with a system prompt requesting recurring themes and insights. The result is written to the path defined by summary_output in the config.
The main loop reloads config on every iteration and checks elapsed time against summary_interval_hours. Any edit to runtime.json takes effect at the next loop tick without restarting Hermes.
Understand runtime behavior considerations
Runtime configuration is reloaded inside the main loop on every tick, so changes to /workspace/config/runtime.json take effect without rebuilding the Hermes container. If the JSON file is malformed, Hermes will fail when it tries to reload, so validate the syntax after any edit.
Workspace cognition uses qdrant.scroll() to collect stored summaries for workspace-level analysis, which differs from qdrant.query_points() used for question-driven semantic retrieval. The scroll() call is not semantically guided — it reads stored records in insertion order.
On startup, the cognition cycle runs immediately because last_summary_time is initialized to 0. This is expected and confirms that the pipeline can read memory, call Ollama, and write the summary output before any interval has elapsed.
The current implementation handles file creation through the on_created() event handler. Existing files and file modifications don’t trigger ingestion. Handling file modification events is a natural extension for a more robust runtime.
The retrieval_limit value in runtime.json is a visible configuration placeholder. The retrieval code still uses limit=3 in search_memory(). Treat it as a forward-looking entry for later hardening.
Rebuild Hermes
Rebuild the Hermes container:
cd ~/dgx-hermes-agent/compose
docker compose build hermes
Restart the runtime:
docker compose up -d
Follow the logs in the terminal:
docker logs -f hermes
Leave this terminal open with the log stream running and open a second terminal for the next step.
On startup, the first cognition cycle runs immediately because last_summary_time starts at 0.
The output is similar to:
[Hermes Agent] Monitoring: /workspace/inbox
This startup behavior is expected and validates that the cognition pipeline can read memory, call Ollama, and write the summary file.
Validate Hermes autonomous cognition
After adding autonomous workspace cognition to Hermes, verify that it works as expected.
Verify workspace summary output
In the second terminal, view the generated summary on the host:
cat ~/dgx-hermes-agent/workspace/memory/workspace-summary.txt
The output is structured similar to:
Workspace Summary
Generated: 2026-05-20 22:53:29.539079
### Recurring Themes and Insights:
1. **Semantic Memory in Persistent AI Systems:**
- Semantic memory utilizes a vector database to store embeddings and metadata.
- This approach allows for context-based retrieval rather than relying solely on exact keyword matching.
- The system can recall relevant past contexts based on meaning, enhancing its reasoning capabilities.
2. **GPU Utilization:**
- NVIDIA GPUs are crucial for speeding up local model inference processes.
- They enhance tasks such as token generation, summarization, and embedding generation.
- These GPUs also improve the performance of contextual reasoning workloads locally.
3. **Arm CPUs in Persistent AI Runtimes:**
- Arm CPUs handle orchestration by managing various operational tasks including:
- Filesystem events
- Runtime scheduling
- Container services
- They also process document parsing, metadata handling, and vector database operations.
- These tasks are essential for maintaining the overall functionality and efficiency of the persistent AI runtime.
### Summary:
The key insights from the workspace summaries revolve around how semantic memory enables context-based recall in AI systems, the role of NVIDIA GPUs in accelerating model inference tasks, and the multifaceted responsibilities of Arm CPUs in orchestrating various operational aspects of a persistent AI environment. These themes highlight the interdependence of different hardware components and their specific roles in enhancing the performance and effectiveness of AI systems.
The summary content will vary because it’s generated by the local model from stored memory.
Validate event-driven ingestion
In the second terminal, create a new file. Write it outside the inbox first and then move it into workspace/inbox/ so Hermes reads a completed file:
cat > /tmp/autonomous-runtime-note.txt <<'EOF'
Autonomous workspace cognition allows a persistent AI runtime to analyze
stored memory on a schedule. This helps the system identify recurring
themes, summarize activity, and maintain awareness of workspace state.
EOF
mv /tmp/autonomous-runtime-note.txt \
~/dgx-hermes-agent/workspace/inbox/autonomous-runtime-note.txt
Watch the first terminal running Hermes logs for the Hermes log output.
[Agent] AI Summary:
- Autonomous workspace cognition enables an ongoing AI analysis of stored data at scheduled intervals.
- The system uses this analysis to detect recurring themes and summarize activities within the workspace.
- It maintains scheduled awareness of workspace state from stored memory.
[Memory] Stored document: /workspace/inbox/autonomous-runtime-note.txt
The new document is added to semantic memory and can be included in future workspace summaries.
Revalidate semantic retrieval
Autonomous cognition adds scheduling and workspace-level summaries, but it doesn’t break the interactive retrieval workflow from the previous section. Validate semantic retrieval again to confirm that Hermes can still process /workspace/query.txt when the cognition loop is enabled.
In the second terminal, create a query:
echo "What is autonomous workspace cognition?" \
> ~/dgx-hermes-agent/workspace/query.txt
Watch the first terminal running Hermes logs.
[Workspace Query]
Document: /workspace/inbox/autonomous-runtime-note.txt
Summary:
Document: /workspace/inbox/memory-test.txt
Summary:
- Persistent AI runtimes require memory to incorporate past workspace activities into future reasoning.
- Semantic memory in AI systems retains embeddings and metadata to store relevant context.
- This stored information allows for retrieval of pertinent context, enhancing the runtime's ability to reason effectively.
Document: /workspace/inbox/cpu-orchestration-note.txt
Summary:
- Arm CPUs manage orchestration in persistent AI runtimes.
- They handle filesystem events, runtime scheduling, and container services.
- Additionally, they process document parsing, metadata handling, and vector database operations.
[AI Response]
Autonomous workspace cognition is a feature that enables ongoing AI analysis of stored data at scheduled intervals. This system uses the analysis to detect recurring themes and summarize activities within the workspace. It maintains scheduled awareness from stored memory, allowing the runtime to reason over the information it has already ingested.
This output shows that autonomous cognition was added without removing the query workflow from the previous section.
Validate runtime policy reload
Runtime policy reload is important because persistent AI systems are configurable without rebuilding containers or restarting the full stack. In this validation, you’ll temporarily change the supported file extensions and confirm that Hermes applies the new policy during its normal runtime loop.
Open and edit the file ~/dgx-hermes-agent/workspace/config/runtime.json.
Change the supported extensions so Hermes ingests only Markdown files:
".md"
Wait 5 to 10 seconds for the runtime loop to reload the policy.
Create a .txt file in the second terminal:
echo "This text file should be ignored by the current policy." \
> /tmp/ignored-policy-test.txt
mv /tmp/ignored-policy-test.txt \
~/dgx-hermes-agent/workspace/inbox/ignored-policy-test.txt
Hermes won’t ingest it because .txt is no longer in supported_extensions.
Now in the second terminal, create a Markdown file:
cat > /tmp/accepted-policy-test.md <<'EOF'
# Policy Test
This Markdown file should be ingested because the runtime policy allows
files with the .md extension.
EOF
mv /tmp/accepted-policy-test.md \
~/dgx-hermes-agent/workspace/inbox/accepted-policy-test.md
[Agent] AI Summary:
- The document discusses key strategies for enhancing local business support through AI technologies.
- It highlights the importance of personalized customer experiences as enabled by advanced data analysis and machine learning techniques.
- Recommendations include integrating chatbots and virtual assistants to improve communication efficiency and customer service.
This output validates that Hermes reloads runtime configuration dynamically.
Restore the original policy when you are done:
".txt",
".md",
".log"
Trigger a faster cognition cycle
For validation, you can temporarily reduce the summary interval.
Set a very small interval:
"summary_interval_hours": 0.001,
".txt",
".md",
".log"
This interval is approximately 3.6 seconds. With this setting, Hermes repeatedly triggers the cognition loop after only a short pause. In the logs, you’ll see [Cognition] Generating workspace summary... and [Cognition] Workspace summary updated: appear again and again when the runtime is active.
This fast interval is useful for validation, but it is intentionally aggressive. Leave it enabled only long enough to confirm that scheduling works, then restore the interval to a larger value.
In the first terminal running Hermes logs, follow the logs:
Press Ctrl+C after confirming the cognition cycles are running, then restore the interval.
Restore the interval to 8 after validation to avoid continuous summary generation:
".txt",
".md",
".log"
Validate persistent runtime lifecycle
Restart the stack:
docker compose restart hermes
Follow the logs:
Press Ctrl+C after the startup messages appear.
The workspace_memory collection remains in Qdrant because the Qdrant storage directory is persisted on the host.
Verify that the summary file still exists:
ls ~/dgx-hermes-agent/workspace/memory/
You’ll see workspace-summary.txt.
This output shows that the runtime state persists across container restarts.
Understand CPU and GPU responsibilities
The Arm Grace CPU coordinates the autonomous runtime: monitoring the filesystem, reloading runtime policy, scheduling background cognition cycles, aggregating semantic memory for workspace summaries, and coordinating the query workflow.
The Blackwell GPU accelerates summarization, embedding generation, contextual reasoning, and autonomous workspace analysis. The result is a heterogeneous local AI system where the CPU coordinates persistent workflows and the GPU accelerates model execution.
What you’ve accomplished
You’ve now completed the persistent autonomous local AI runtime on DGX Spark. The finished system demonstrates how an Arm CPU can coordinate long-running AI workflows, while a GPU accelerates summarization, embedding generation, contextual reasoning, and workspace-level cognition.
This Learning Path uses DGX Spark as the reference platform, but the architecture is reusable beyond this specific system. You can adapt the same pattern to other Arm platforms that can run containerized services, local inference backends, vector memory, and a CPU-side orchestration runtime.
The key idea is that persistent AI systems are distributed orchestration systems, not just single inference calls. Hermes coordinates workspace ingestion, semantic memory, retrieval, autonomous summaries, and runtime policy, while the inference and memory services remain replaceable implementation choices.
This implementation is intentionally a minimal version. It validates the end-to-end architecture, but it doesn’t yet handle production concerns such as repeated updates to the same file, deduplication, re-indexing, versioned memory records, or file modification events. Those hardening steps are natural extensions after the core runtime pattern is working.
