Orchestrate a local Hermes AI agent on NVIDIA DGX Spark
Explore persistent AI runtime architecture on NVIDIA DGX Spark
Build the DGX Spark AI runtime foundation
Deploy Hermes Agent as an orchestration runtime
Add local LLM inference to Hermes Agent
Build persistent semantic memory for Hermes Agent
Add semantic retrieval and contextual reasoning to Hermes Agent
Add autonomous workspace cognition to Hermes Agent
Update Hermes to turn memory in Qdrant into a reasoning source
In this section, you’ll add semantic retrieval to Hermes Agent.
In the previous section, Hermes stored document summaries, embeddings, and metadata in Qdrant. You’ll now turn that stored memory into an active reasoning source: Hermes will accept a question, retrieve relevant memories, assemble them as context, and send that context to the local model.
The runtime can already ingest documents, summarize them, generate embeddings, and store semantic memory in Qdrant. You’ll now add a query workflow so Hermes can search memory and use retrieved context to answer questions.
The workflow becomes:
/workspace/query.txt
-> Hermes embeds the question
-> Qdrant returns relevant memories
-> Hermes assembles context
-> Ollama generates a grounded answer
This is the first stage where Hermes uses memory as reasoning context instead of only storing it.
Understand contextual retrieval architecture
The retrieval pipeline uses all three runtime services:
| Component | Responsibility |
| Hermes Agent | Detects queries, generates query embeddings, assembles context |
| Ollama | Generates embeddings and contextual answers |
| Qdrant | Searches stored semantic memory |
The runtime keeps the same fixed memory configuration:
| Component | Value |
| Embedding model | nomic-embed-text |
| Vector dimension | 768 |
| Qdrant collection | workspace_memory |
| Retrieval limit | 3 |
Hermes watches for a query file at:
When the file exists, Hermes reads the question, deletes the query file, searches memory, and prints the answer in the container logs.
Add retrieval functions to Hermes
Open and edit the file ~/dgx-hermes-agent/hermes/agent.py.
Replace the file with the following version:
import os
import uuid
import time
import ollama
from qdrant_client import QdrantClient
from qdrant_client.models import (
Distance,
VectorParams,
PointStruct
from watchdog.observers import Observer
from watchdog.events import FileSystemEventHandler
WATCH_DIR = "/workspace/inbox"
SUPPORTED_EXTENSIONS = [
".txt",
".md",
".log"
OLLAMA_HOST = os.getenv(
"OLLAMA_HOST",
"http://ollama:11434"
QDRANT_HOST = os.getenv(
"QDRANT_HOST",
"qdrant"
COLLECTION_NAME = "workspace_memory"
client = ollama.Client(host=OLLAMA_HOST)
qdrant = QdrantClient(
host=QDRANT_HOST,
port=6333
def ensure_collection():
collections = qdrant.get_collections().collections
names = [c.name for c in collections]
if COLLECTION_NAME not in names:
qdrant.create_collection(
collection_name=COLLECTION_NAME,
vectors_config=VectorParams(
size=768,
distance=Distance.COSINE
print(f"[Memory] Created collection: {COLLECTION_NAME}")
class WorkspaceHandler(FileSystemEventHandler):
def on_created(self, event):
if event.is_directory:
return
filename = os.path.basename(event.src_path)
if filename.startswith("."):
return
ext = os.path.splitext(filename)[1]
if ext not in SUPPORTED_EXTENSIONS:
return
print(f"\n[Agent] New file detected:")
print(event.src_path)
process_file(event.src_path)
def generate_summary(content):
response = client.chat(
model="qwen2.5:7b",
messages=[
"role": "system",
"content": (
"You are a local AI workspace assistant. "
"Summarize the document in 3 concise bullet points."
"role": "user",
"content": content[:4000]
return response["message"]["content"]
def generate_embedding(content):
response = client.embed(
model="nomic-embed-text",
input=content[:4000]
return response["embeddings"][0]
def store_memory(path, content, summary, embedding):
point_id = str(uuid.uuid4())
qdrant.upsert(
points=[
PointStruct(
id=point_id,
vector=embedding,
payload={
"path": path,
"summary": summary,
print(f"[Memory] Stored document: {path}")
def search_memory(query):
print("\n[Memory] Searching semantic memory...")
embedding = generate_embedding(query)
results = qdrant.query_points(
query=embedding,
limit=3
).points
memories = []
for result in results:
payload = result.payload
memories.append({
"path": payload.get("path"),
"summary": payload.get("summary")
return memories
def query_workspace(question):
memories = search_memory(question)
context = "\n\n".join([
f"Document: {m['path']}\nSummary:\n{m['summary']}"
for m in memories
model="qwen2.5:7b",
messages=[
"role": "system",
"content": (
"You are a persistent AI workspace assistant. "
"Answer questions using the retrieved workspace memory."
"role": "user",
"content": (
f"Question:\n{question}\n\n"
f"Relevant workspace memory:\n{context}"
answer = response["message"]["content"]
print("\n[Workspace Query]")
print(question)
print("\n[Retrieved Memories]")
print(context)
print("\n[AI Response]")
print(answer)
def process_file(path):
try:
with open(path, "r", encoding="utf-8") as f:
content = f.read()
print("\n[Agent] Running summarization inference...")
summary = generate_summary(content)
print("\n[Agent] AI Summary:")
print(summary)
print("\n[Agent] Generating embeddings...")
embedding = generate_embedding(content)
store_memory(
path,
content,
summary,
embedding
except Exception as e:
print(f"[Agent] Error: {e}")
if __name__ == "__main__":
print("\n[Hermes Agent] Starting workspace watcher...")
print(f"[Hermes Agent] Monitoring: {WATCH_DIR}")
ensure_collection()
observer = Observer()
observer.schedule(
WorkspaceHandler(),
WATCH_DIR,
recursive=False
observer.start()
try:
while True:
time.sleep(1)
if os.path.exists("/workspace/query.txt"):
with open("/workspace/query.txt", "r") as f:
question = f.read().strip()
os.remove("/workspace/query.txt")
except KeyboardInterrupt:
observer.stop()
observer.join()
Understand code trace
search_memory() embeds the user question with generate_embedding(), then calls qdrant.query_points() with query=embedding to retrieve the three closest semantic matches. Each result’s payload is read from result.payload, and the path and summary are assembled into a list of memories.
query_workspace() joins those memories into a context string, then sends both the original question and the assembled context to qwen2.5:7b using the chat API. The model receives prior workspace memory as part of the prompt, so its answer is grounded in ingested documents rather than general knowledge.
The main runtime loop checks for /workspace/query.txt on each iteration. When the file exists, Hermes reads the question, deletes the file immediately to avoid re-processing, and calls query_workspace().
Understand runtime compatibility considerations
Use qdrant.query_points() with query=embedding when calling the vector search API. Older examples use query_vector=embedding, which isn’t compatible with current versions of the Qdrant Python client. Read each result’s payload with result.payload before assembling the retrieval context.
The limit=3 value in search_memory() is hardcoded to keep the retrieval behavior easy to inspect. You can make it configurable later.
Rebuild Hermes with retrieval functions
Rebuild the Hermes container:
cd ~/dgx-hermes-agent/compose
docker compose build hermes
Restart the runtime:
docker compose up -d
Follow the Hermes logs:
docker logs -f hermes
Leave this terminal open with the log stream running and open a second terminal for the next step.
The startup output is similar to:
[Hermes Agent] Monitoring: /workspace/inbox
Validate semantic retrieval and contextual reasoning
After adding semantic retrieval and contextual reasoning to Hermes, verify that it works as expected.
Create test memory
In a second terminal, create a few new documents so Qdrant contains useful semantic memory.
For each document, write the file in /tmp first and then move it into workspace/inbox/. This gives Hermes a completed file when the on_created() event fires.
Create a document about CPU orchestration:
cat > /tmp/cpu-orchestration-note.txt <<'EOF'
Arm CPUs are responsible for orchestration in persistent AI runtimes.
They coordinate filesystem events, runtime scheduling, container services,
document parsing, metadata handling, and vector database operations.
EOF
mv /tmp/cpu-orchestration-note.txt \
~/dgx-hermes-agent/workspace/inbox/cpu-orchestration-note.txt
Create a document about GPU inference:
cat > /tmp/gpu-inference-note.txt <<'EOF'
NVIDIA GPUs accelerate local model inference, token generation,
summarization, embedding generation, and contextual reasoning workloads.
EOF
mv /tmp/gpu-inference-note.txt \
~/dgx-hermes-agent/workspace/inbox/gpu-inference-note.txt
Create a document about semantic memory:
cat > /tmp/semantic-memory-note.txt <<'EOF'
Semantic memory stores embeddings and metadata in a vector database.
This allows persistent AI systems to retrieve relevant prior context
based on meaning instead of exact keyword matching.
EOF
mv /tmp/semantic-memory-note.txt \
~/dgx-hermes-agent/workspace/inbox/semantic-memory-note.txt
Watch the first terminal running Hermes logs until each document is summarized, embedded, and stored.
The output is similar to:
[Agent] AI Summary:
- Arm CPUs handle orchestration in persistent AI runtimes.
- They manage filesystem events, runtime scheduling, and container services.
- Tasks also include document parsing, metadata handling, and vector database operations.
[Memory] Stored document: /workspace/inbox/cpu-orchestration-note.txt
[Agent] AI Summary:
- NVIDIA GPUs speed up local model inference processes.
- These GPUs enhance token generation, summarization, and embedding generation tasks.
- They also improve contextual reasoning workloads locally.
[Memory] Stored document: /workspace/inbox/gpu-inference-note.txt
[Agent] AI Summary:
- Semantic memory uses a vector database to store embeddings and metadata.
- This enables persistent AI systems to recall relevant past contexts based on meaning.
- The system avoids relying solely on exact keyword matching for retrieval.
[Memory] Stored document: /workspace/inbox/semantic-memory-note.txt
Test semantic retrieval
In the second terminal, create a query file:
echo "How do CPUs help persistent AI systems?" \
> ~/dgx-hermes-agent/workspace/query.txt
Hermes checks for /workspace/query.txt in the runtime loop. When it sees the file, it reads the question and removes the file. It then embeds the question, searches Qdrant, and sends the retrieved context to Ollama.
In the first terminal running Hermes logs, confirm that semantic search started.
Then confirm that Hermes printed the question and the retrieved memory context.
[Workspace Query]
Document: /workspace/inbox/cpu-orchestration-note.txt
Summary:
- Arm CPUs manage orchestration in persistent AI runtimes.
- They handle filesystem events, runtime scheduling, and container services.
- Additionally, they process document parsing, metadata handling, and vector database operations.
Summary:
Document: /workspace/inbox/semantic-memory-note.txt
Summary:
- This enables persistent AI systems to recall relevant past context based on meaning.
- Retrieval is done without relying solely on exact keyword matching.
Finally, confirm that Ollama generated a response from the retrieved context:
[AI Response]
In persistent AI systems, CPUs play a crucial role in managing orchestration tasks that are essential for the system's operation. Specifically, Arm CPUs handle several key responsibilities:
1. **Orchestration Management**: They manage the overall orchestration of the runtime environment.
2. **Filesystem Events Handling**: CPU processes and responds to events related to file systems within the AI system.
3. **Runtime Scheduling**: They schedule tasks and processes based on current needs and resource availability.
4. **Container Services**: CPUs handle services running in containers, ensuring that these components operate efficiently.
Furthermore, Arm CPUs are involved in processing various data-related operations:
- **Document Parsing**: This involves breaking down documents into manageable chunks for further analysis or storage.
- **Metadata Handling**: They manage the creation and manipulation of metadata associated with data entities.
- **Vector Database Operations**: These include storing embeddings and metadata in vector databases, which is critical for semantic memory systems. Vector databases allow persistent AI systems to recall relevant past context based on meaning rather than exact keyword matching.
These functions collectively ensure that CPUs are central to maintaining the functionality and efficiency of persistent AI systems by managing both operational tasks and data processing needs.
The exact answer will vary, but it should refer to retrieved memory about CPU orchestration, filesystem events, scheduling, and runtime coordination.
Verify contextual reasoning
In the second terminal, ask another question:
echo "Why does the runtime need semantic memory?" \
Hermes embeds the question and Qdrant retrieves relevant summaries. Hermes then assembles those summaries into context, and Ollama generates an answer grounded in the retrieved memory.
The logs include a retrieved memory from the semantic memory document that you created earlier.
[Workspace Query]
Document: /workspace/inbox/memory-test.txt
Summary:
- Persistent AI runtimes require memory to incorporate past workspace activities into future reasoning.
- Semantic memory in AI systems retains embeddings and metadata to store relevant context.
- This stored information allows for retrieval of pertinent context, enhancing the runtime's ability to reason effectively.
Summary:
Summary:
[AI Response]
The runtime needs semantic memory because it retains embeddings and metadata that store relevant context from past workspace activities. This allows the system to effectively reason by retrieving pertinent information, enhancing its ability to understand and respond to new inputs more intelligently. Unlike simple keyword matching, semantic memory uses a vector database which captures the meaning of words or concepts, enabling more accurate and contextualized recall of past events or knowledge.
Understand CPU and GPU responsibilities
The Arm Grace CPU coordinates the retrieval workflow: watching for query.txt, reading and deleting the query file, calling Ollama for the query embedding, searching Qdrant for relevant memories, parsing result payloads, assembling the retrieved context, and calling Ollama again for contextual reasoning.
The Blackwell GPU accelerates query embedding generation, contextual LLM inference, and response generation. Qdrant performs the vector similarity search and returns the most relevant memory payloads.
This retrieval workflow creates a local contextual reasoning loop using persistent memory.
You’ve added semantic retrieval and contextual reasoning to Hermes Agent. The runtime now turns a question into an embedding, searches Qdrant with query_points(...), assembles retrieved memory, and sends that context to qwen2.5:7b.
The runtime can now store memory and reason over it through the local /workspace/query.txt workflow.
Next, you’ll add autonomous workspace cognition.
Before moving to the next section, press Ctrl+C in the first terminal running Hermes logs to stop the Hermes log stream. In the next section, you’ll rebuild the Hermes container and run docker logs -f hermes again.
