Explore related resources
Give feedback
AI-assisted
Close
How do I know the Ubuntu container started correctly?
Run lxc list to confirm the container appears with Status set to RUNNING. Use lxc info for details such as Architecture, PID, and creation time that match the example output.
How do I share a ChromeOS folder with the Ubuntu container?
In the ChromeOS Files app, right-click a folder and choose Share with Linux. The folder becomes available to Linux apps and the command line inside the container. If the folder doesn’t appear, ensure the container is running.
How do I launch and verify a Linux GUI app from the container?
After enabling Sommelier and installing the minimal desktop packages, start a test application such as terminator from the container shell. A window should open on the ChromeOS desktop. If a window doesn’t open, revisit the display configuration steps.
Which command opens a shell inside the container for installs and configuration?
From the Termina shell, run lxc exec <container> -- bash (for example, lxc exec u1 -- bash). This places you in the container’s shell to install packages and run commands.
How do I stop and remove the container when I am done?
Use lxc stop <container> to stop the container, then lxc delete <container> to remove it. Deletion is permanent, so run the delete command only when you no longer need the container.
Return to Laptops and Desktops
