Overview
Create Azure IoT Hub
Build a Python-based IoT telemetry simulator
Process IoT telemetry in real time with Azure Stream Analytics
Store data in Azure Cosmos DB with Azure Stream Analytics
Set up data monitoring and alerts with Azure Functions
Sensor Data Aggregation Using Azure Functions
IoT Portal
Azure IoT Hub is a fully managed cloud service that acts as a secure, scalable communication gateway for connecting IoT devices to cloud-hosted applications and analytics systems. It’s the core element of Azure-based IoT solutions, supporting reliable two-way communication between millions of IoT devices and the cloud.
IoT Hub supports bi-directional messaging, enabling not only device-to-cloud telemetry data transfer but also cloud-to-device commands, configuration updates, and remote device management.
A key advantage of Azure IoT Hub is its built-in device provisioning, authentication, and management capabilities, which allow you to securely onboard, register, and manage IoT devices at scale. It supports multiple communication protocols, including MQTT, AMQP, and HTTPS, making it versatile and compatible with a broad range of devices. IoT Hub integrates seamlessly with other Azure services, such as Azure Stream Analytics, Azure Cosmos DB, Azure Functions, and Azure Blob Storage, facilitating the development of sophisticated IoT solutions with minimal complexity.
Additionally, Azure IoT Hub provides monitoring and diagnostics capabilities, making it easier to identify connectivity issues, analyze device performance, and maintain operational efficiency. Its built-in security features, such as per-device authentication and secure device identity management, ensure that sensitive data remains protected throughout its lifecycle.
In the following sections of this Learning Path, you’ll learn how to:
Start by creating an Azure IoT Hub by following these steps:
Sign in to the Azure Portal:
Create a new Azure IoT Hub resource:
On the Azure portal home page, select Create a resource at the top left as shown below:
Create a resource on the Azure IoT Hub portal.
In the Search resources, services, and docs search box, type “iot hub” and press Enter.
From the search results, select the IoT Hub icon, as shown below:
Select IoT Hub icon.
Click the Create button:
Select the Create button.
Configure the Basics IoT Hub settings:
Configure the IoT Hub settings.
Verify IoT Hub overviewNow that your Azure IoT Hub is ready, you can proceed to register and configure your IoT devices. In the next step, you’ll learn how to register an Arm64-based IoT device and start streaming data using Python and Azure IoT SDK.
