What you've learned
You should now know how to:
  • Install a Raspberry Pi OS file system on an Arm server
  • Reduce compile time for a Linux application, the MXNet machine learning framework
  • Transfer the compiled MXNet application to a Raspberry Pi and test it
  • Utilize an Arm server to reduce compile time for your own embedded Linux projects
Knowledge Check
Which command is used to change the root directory to make the file system appear to be another Linux installation?
Arm servers can be used to reduce compile time for application which take a long time to build
