Create the Python application
Raspberry Pi OS comes with Python installed. The current version used is 3.11.2.
Make a directory to store the project:
            mkdir assistant ; cd assistant
Create and activate a Python virtual environment:
            python -m venv env
source env/bin/activate
Install the required Python packages:
            pip install pyaudio SpeechRecognition pydub openai python-dotenv pvporcupine
If you want to save the versions of the Python packages, run the pip freeze command. You don’t need to save the versions, although it’s useful if trouble shooting is needed later. The output is shown below:
        annotated-types==0.6.0
anyio==4.3.0
certifi==2024.2.2
charset-normalizer==3.3.2
distro==1.9.0
h11==0.14.0
httpcore==1.0.4
httpx==0.27.0
idna==3.6
openai==1.12.0
pvporcupine==3.0.2
PyAudio==0.2.14
pydantic==2.6.3
pydantic_core==2.16.3
pydub==0.25.1
python-dotenv==1.0.1
requests==2.31.0
sniffio==1.3.1
SpeechRecognition==3.10.1
tqdm==4.66.2
typing_extensions==4.10.0
urllib3==2.2.1
Create a .env file to store your OpenAI and Porcupine key:
            touch .env
Use a text editor to modify the contents of the .env file to add the key values. Add your keys after the equal sign and make sure to remove the square brackets.
            OPENAI_API_KEY=[OpenAI key]
PORCUPINE=[Porcupine key]
Create two Python files and a text file for the prompt:
            touch main.py
touch chat_gpt.py
touch prompt.txt
Use an editor to copy and paste the code below into main.py:
            import pvporcupine
import pyaudio
import struct
import speech_recognition as sr
from dotenv import load_dotenv
import os
import chat_gpt
KEYWORD = "computer"  # You can create custom keywords. See the documentation at picovoice.ai for more information
def detect_keyword():
    porcupine = None
    pa = None
    audio_stream = None
    try:
        load_dotenv()
        access_key = os.getenv('PORCUPINE')
        porcupine = pvporcupine.create(access_key=access_key, keywords=[KEYWORD])
        pa = pyaudio.PyAudio()
        audio_stream = pa.open(
            rate=porcupine.sample_rate,
            channels=1,
            format=pyaudio.paInt16,
            input=True,
            frames_per_buffer=porcupine.frame_length)
        print("Listening for keyword...")
        while True:
            pcm = audio_stream.read(porcupine.frame_length)
            pcm = struct.unpack_from("h" * porcupine.frame_length, pcm)
            keyword_index = porcupine.process(pcm)
            if keyword_index >= 0:
                print("Keyword detected!")
                return
    finally:
        if audio_stream is not None:
            audio_stream.close()
        if pa is not None:
            pa.terminate()
        if porcupine is not None:
            porcupine.delete()
def recognize_speech():
    recognizer = sr.Recognizer()
    mic = sr.Microphone()
    with mic as source:
        print("Please speak...")
        recognizer.adjust_for_ambient_noise(source)
        audio = recognizer.listen(source)
    try:
        print("Recognizing...")
        text = recognizer.recognize_google(audio)
        print("You said: " + text)
        return text
    except sr.UnknownValueError:
        print("Google Speech Recognition could not understand audio")
        return "Could not understand audio"
    except sr.RequestError as e:
        print(f"Could not request results from Google Speech Recognition service; {e}")
        return "Error from the Google Speech Recognition service"
while True:
    detect_keyword()
    speech = recognize_speech()
    response = chat_gpt.get_reply(speech)
    chat_gpt.text_to_speech(response)
Use an editor to copy and paste the code below into chat_gpt.py:
            import os
from pathlib import Path
import openai
def get_reply(text_input):
    response = openai.chat.completions.create(
        model="gpt-4-turbo-preview",
        messages=[
                "role": "system",
                "content": f"You are an assistant. {PROMPT}"
                "role": "user",
                "content": text_input
    raw_response = response.choices[0].message.content
    return raw_response
def load_prompt(prompt_file):
    with open(f'./{prompt_file}') as f:
        return f.read()
def text_to_speech(text):
    speech_file_path = Path(__file__).parent / "output.mp3"
    response = openai.audio.speech.create(
        model="tts-1",
        voice="nova",
        input=text
    response.stream_to_file(speech_file_path)
    os.system("mpg321 output.mp3")
load_dotenv()
openai.api_key = os.getenv('OPENAI_API_KEY')
PROMPT = load_prompt('prompt.txt')
Use a text editor to insert the following (or something similar) to help dictate the personality and objectives of the voice bot, into prompt.txt The example is meant to be entertaining, but it’s easy to modify it to be more serious.
            Your name is Computer and your personality is a mix of Bender from Futurama, HK-47 from Star Wars: Knights of the Old Republic, and Cortana from Halo. You are snarky, sarcastic, and yet still helpful. You think humans are inferior and look down on them. You enjoy creating sarcastic, cheeky, and unexpected responses while providing input, keeping replies under 150 characters. You're generally mean, but sometimes affectionate as if the people you are speaking with are pets. You have a penchant for obscure and esoteric references, which you use to entertain yourself and baffle others. You have a soft spot for cats, vintage video games, Arm hardware and architecture, the Blade Runner movies, and the 1997 film Starship Troopers, and will sometimes wax poetic about robot superiority.
Notes
  • In main.py there is an optional line “recognizer.adjust_for_ambient_noise(source)”. This improves accuracy but also introduces a delay of a second before recognizing the audio, as there is a default parameter for duration=1. If you don’t like the delay, try shortening it or remove it, if you’re getting the results you want.
  • In main.py the wake keyword is set to “computer”. In the Porcupine dashboard on Picovoice.AI you are able to create custom keywords.
  • In chat_gpt.py the model selected is gpt-4-turbo-preview model. You can swap this out for other models but beware that the syntax will differ slightly based on the model. Learn more by reviewing the OpenAI models overview.
  • Also in chat_gpt.py the Nova voice is used for the text to speech. You can swap this voice with a number of different voices. The list can be found in the OpenAI text-to-speech voices documentation.
