Arm Fast Models is a separate component, enabling you to build virtual representations of real hardware. The supplied FVPs are pre-built with Fast Model technology.
DSTREAM-PT supports 32-bit wide trace capture at up to 300 MHz DDR.
You must use the supplied compiler version with your Arm Development Studio installation?
Other compiler versions can be downloaded and installed for use with Development Studio.
