What you've learned
You should now know how to:
  • Install the Python version of llama.cpp on your Raspberry Pi 5.
  • Download an LLM from Hugging Face.
  • Assess LLM memory size and performance.
  • Run the LLM on your Raspberry Pi 5 using Python bindings for llama.cpp.
Knowledge Check
Is it possible to run LLMs on edge devices such as a Raspberry Pi?
Does llama.cpp require skills to build and run C++ applications?
Can you estimate memory usage without loading an LLM?
