This section shows how you can build the hello world example on your Arm Linux host using a Docker container. Before getting started, you need to install Git, buildx and Docker on your Linux host. Follow the Docker Engine install guide .
Install Git by running the following:
sudo apt install git
Building the hybrid-runtime
Pull the hybrid runtime GitHub repository:
git clone https://github.com/smarter-project/hybrid-runtime.git
Navigate to the hybrid-runtime/docker directory and build the hybrid-runtime components:
cd hybrid-runtime/docker
make all
This builds the hybrid-runtime CLI and containerd hybrid-shim.
Navigate to the hybrid_runtime/cortexm_console directory and build the application:
cd ../cortexm_console
docker buildx build --platform linux/arm64 -o output -f Dockerfile .
Note
You may have to be root to run Docker. Try adding sudo to the beginning of the Docker commands.
This builds the helper application, cortexm_console, that can capture output from a Cortex-M application. The binary is created in the directory.
By default, containerd will look in /usr/local/bin to find the hybrid-runtime components. Therefore, copy the hybrid-runtime components and the cortexm_console application into /usr/local/bin on the AVH model.
Copy the containerd-shim-containerd-hybrid to the board under /usr/local/bin using SCP and the IP address from before.
If you are using a VPN configured setup then you can use SCP directly. For example:
scp runtime/hybrid-shim/target/aarch64-unknown-linux-musl/debug/containerd-shim-containerd-hybrid root@10.11.0.1:/usr/local/bin/
scp cortexm_console/output/cortexm_console  root@10.11.0.1:/usr/local/bin/
Otherwise you can use the information from the Quick Connect section (substituting your particular -J argument). For example:
scp -J 95757722-1eb3-4e69-8cad-54f0400aa3d2@proxy.app.avh.arm.com runtime/hybrid-shim/target/aarch64-unknown-linux-musl/debug/containerd-shim-containerd-hybrid root@10.11.0.1:/usr/local/bin/
scp  -J 95757722-1eb3-4e69-8cad-54f0400aa3d2@proxy.app.avh.arm.com cortexm_console/output/cortexm_console  root@10.11.0.1:/usr/local/bin/
Note
You’ll need to edit the above commands to fit your IP address and paths.
Building the hello-world firmware container image
Pull the runtime GitHub repository:
Then run the following:
make image
This should build a docker image with the name ghcr.io/smarter-project/hybrid-runtime/hello_world_imx8mp:latest.
The image.dockerfile file pulls the NXP SDK and builds the hello world example present in the NXP SDK. Finally, the Dockerfile creates a new image, copies the hello world binary into it, sets the entrypoint and adds the correct labels. You can use this Dockerfile to run the example as shown in the section Deploy firmware container using containerd .
