What you've learned
You should now know how to:
  • Deploy a containerized embedded application onto an Arm Cortex-M core from an Arm Cortex-A core using containerd and K3s.
  • Build a firmware container image.
  • Build the hybrid-runtime components.
Knowledge Check
The firmware is deployed as a container running on Linux on a Cortex-A.
Can you run multiple hybrid containers on the same Cortex-M?
Which command is used to interact with the hybrid-runtime from `containerd`?
