Vector tables have a relatively small and fixed number of entries. A real system will likely require many different interrupts, triggered by different sources. An additional piece of hardware is needed to manage these interrupts. The Arm Generic Interrupt Controller, GIC does exactly this.
Create gic.s with the following code to initialize the GICv3 implemented in the FVP, and define the timer as a source of interrupts.
For detail on this code, see the GICv3 and GICv4 Software Overview .
.section GIC,"ax"
.global gicInit
.type gicInit, "function"
gicInit:
// Configure Distributor
MOV x0, #0x2f000000 // GIC Distributor, GICD
// Set ARE bits and group enables in the Distributor
ADD x1, x0, #0x0 // GICD_CTLROffset
MOV x2, #0x20 // GICD_CTLR.ARE_NS
ORR x2, x2, #0x10 // GICD_CTLR.ARE_S
STR w2, [x1]
ORR x2, x2, #0x01 // GICD_CTLR.EnableG0
ORR x2, x2, #0x04 // GICD_CTLR.EnableG1S
ORR x2, x2, #0x02 // GICD_CTLR.EnableG1NS
STR w2, [x1]
DSB SY
// Configure Redistributor
// Clearing ProcessorSleep signals core is awake
MOV x0, #0x2f100000 // GIC Redistributor, RD_base
MOV x1, #0x14 // GICR_WAKERoffset
ADD x1, x1, x0
STR wzr, [x1]
DSB SY
waiting: // Wait for ChildrenAsleep to read 0
LDR w0, [x1]
AND w0, w0, #0x6
CBNZ w0, waiting
// Configure CPU interface
// Set the SRE bits for each EL to enable
// access to the interrupt controller registers
MOV x0, #0x8 // ICC_SRE_ELn.Enable
ORR x0, x0, #0x1 // ICC_SRE_ELn.SRE
MSR ICC_SRE_EL3, x0
ISB
MSR ICC_SRE_EL1, x0
MRS x1, SCR_EL3
ORR x1, x1, #1 // Set NS bit, to access Non-secure registers
MSR SCR_EL3, x1
ISB
MSR ICC_SRE_EL2, x0
ISB
MSR ICC_SRE_EL1, x0
MOV w0, #0xFF
MSR ICC_PMR_EL1, x0 // Set PMR to lowest priority
MOV w0, #3
MSR ICC_IGRPEN1_EL3, x0
MSR ICC_IGRPEN0_EL1, x0
// Secure Physical Timer source defined
MOV x0, #0x2f110000 // GIC Redistributor, SGI_base
ADD x1, x0, #0x80 // GICR_IGROUPRoffset
STR wzr, [x1] // Mark INTIDs 0..31 as Secure
ADD x1, x0, #0xD00 // GICR_IGRPMODRoffset
STR wzr, [x1] // Mark INTIDs 0..31 as Secure Group 0
ADD x1, x0, #0x100 // GICR_ISENABLERoffset
MOV w2, #(1 << 29) // Enable INTID 29
STR w2, [x1] // Enable interrupt source
RET
Define these functions in your gic.s source:
readIAR0() reads the value of the
Interrupt Controller Interrupt Acknowledge Register 0, ICC_IAR0_EL1
. The lower 24 bits of this register give the interrupt identifier, INTID.writeEOIR0() writes INTID to the
Interrupt Controller End of Interrupt Register 0, ICC_EOIR0_EL1
, which tells the processor that that interrupt is complete.
.global readIAR0
.type readIAR0, "function"
readIAR0:
MRS x0, ICC_IAR0_EL1 // Read ICC_IAR0_EL1 into x0
RET
.global writeEOIR0
.type writeEOIR0, "function"
writeEOIR0:
MSR ICC_EOIR0_EL1, x0 // Write x0 to ICC_EOIR0_EL1
RET
These functions will be used in your fiqHandler() implementation (written in C).
A Generic Timer is present in all Armv8-A processors.
Create timer.s defining the following functions:
setTimerPeriod() which writes to
CNTPS_TVAL_EL1, Counter-timer Physical Secure Timer TimerValue register
.enableTimer() and disableTimer() which write to
CNTPS_CTL_EL1, Counter-timer Physical Secure Timer Control register
.section AArch64_GenericTimer,"ax"
.global setTimerPeriod
.type setTimerPeriod, "function"
setTimerPeriod:
MSR CNTPS_TVAL_EL1, x0
ISB
RET
.global enableTimer
.type enableTimer, "function"
enableTimer:
MOV x0, #0x1 // Set Enable bit, and clear Mask bit
MSR CNTPS_CTL_EL1, x0
ISB
RET
.global disableTimer
.type disableTimer, "function"
disableTimer:
MSR CNTPS_CTL_EL1, xzr // Clear the enable bit
ISB
RET
Modify hello.c to enable the GIC and timer, and create a simple test. You can use printf() statements to follow execution flow.
#include <stdio.h>
#include <stdint.h>
#include "uart.h"
__asm(".global __use_no_semihosting\n\t");
// defined in gic.s
extern void gicInit(void);
extern uint32_t readIAR0(void);
extern void writeEOIR0(uint32_t);
// defined in timer.s
extern void setTimerPeriod(uint32_t);
extern void enableTimer(void);
extern void disableTimer(void);
volatile uint32_t flag;
int main (void) {
uartInit((void*)(0x1C090000));
printf("Hello World!\n");
flag = 0;
gicInit();
setTimerPeriod(0x10000);
enableTimer();
printf("Waiting for interrupt...\n");
while(flag==0){};
printf("Returned from interrupt!\n");
return 0;
Create the fiqHandler() function in hello.c. It reads the INTID register when triggered, disables the timer, and sets flag.
void fiqHandler(void) {
uint32_t intid;
intid = readIAR0(); // Read the interrupt id
printf("Interrupt %d occurred\n", intid);
if (intid == 29) {
disableTimer();
flag = 1;
else
printf("Another interrupt occurred??\n");
writeEOIR0(intid); // Clear interrupt
return;
You are now ready to test the application. Build the project with:
armclang -c -g --target=aarch64-arm-none-eabi startup_el3.s
armclang -c -g --target=aarch64-arm-none-eabi uart.c
armclang -c -g --target=aarch64-arm-none-eabi vectors.s
armclang -c -g --target=aarch64-arm-none-eabi gic.s
armclang -c -g --target=aarch64-arm-none-eabi timer.s
armclang -c -g --target=aarch64-arm-none-eabi hello.c
armlink --scatter=scatter.txt --entry=el3_entry startup_el3.o uart.o vectors.o gic.o timer.o hello.o -o hello.axf
To enable the timer in the FVP, add the -C bp.refcounter.non_arch_start_at_default=1 option to the command line.
FVP_Base_AEMvA -C bp.refcounter.non_arch_start_at_default=1 -a hello.axf
Observe the application reporting that the exception occurred.
Hello World!
Interrupt 29 occurred
In _sys_exit. Use Ctrl+C to quit.
