# [Create a custom AXI4 Peripheral](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/creating_peripheral/)
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/)
- [Setup a Workspace in Xilinx Vivado](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/setup/)
- [Create a custom AXI4 Peripheral](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/creating_peripheral/)
- [Connect AXI4 Peripheral to ZYNQ Processing System](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/connecting_peripheral/)
- [Generate the bitstream and write your application using Vitis IDE](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/generating_bitstream/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/advanced_soc/_next-steps/)
The Xilinx Vivado tools provide a simplified way to create an AXI4 peripheral. You can follow the steps outlined below to create the peripheral.
1. Start by clicking “Tools” -> “Create and Package New IP”. Click “Next” and choose the following option:
   ![Screenshot of Vivado’s Create and Package New IP wizard showing the Create a new AXI4 peripheral option selected, which generates template files for an AXI-compliant custom IP block](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture7.png)
   _Figure 2.1. Creating AXI4 peripheral_
2. Give the following name to the IP (you may keep the IP location path as provided by default):
   ![Screenshot of the peripheral details dialog showing the Name field set to AUP_advanced_SoC and fields for Version, Display name, and Description where you configure the custom IP metadata](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture8.jpg)
   _Figure 2.2. Adding peripheral details_
3. You need a Subordinate interface and four 32-bit registers for the switches and LEDs.
   ![Screenshot of the Add Interfaces wizard showing the Subordinate interface type selected with Number of Registers set to 4 and Data Width set to 32, configuring the AXI-Lite register bank for GPIO control](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture9.png)
   _Figure 2.3. Peripheral settings for Subordinate interface_
4. On the last page, choose “Edit IP” and click “Finish”. In the “Sources” window, you will see two Verilog files in Design Sources:
   - A top file, i.e., `AUP_advanced_SoC_v1_0.v`
   - A filename that ends with “S00_AXI”, i.e., `AUP_advanced_SoC_v1_0_S00_AXI.v`
These are the basic template files generated for an AXI-Lite peripheral. You can now implement custom GPIO logic by making some changes to these template files.
1. Double-click to open the top-level Verilog file called “AUP_advanced_SoC_v1_0.v”:
   ![Screenshot of Vivado Sources panel showing the Design Sources hierarchy with AUP_advanced_SoC_v1_0.v file highlighted, which is the top-level module that needs custom GPIO port declarations added](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture10.png)
   _Figure 2.4. Editing top-level Verilog file_
2. Add the following lines of code below the comment “// Users to add ports here”:
   ```verilog
   input wire [3:0] sw,
   output wire [3:0] led,
3. Also, add `sw` and `led` when instantiating the AXI Bus Interface `S00_AXI`, so the code looks like the following:
   ```verilog
   // Instantiation of Axi Bus Interface S00_AXI
       AUP_advanced_SoC_v1_0_S00_AXI # (
           .C_S_AXI_DATA_WIDTH(C_S00_AXI_DATA_WIDTH),
           .C_S_AXI_ADDR_WIDTH(C_S00_AXI_ADDR_WIDTH)
       ) AUP_advanced_SoC_v1_0_S00_AXI_inst (
               .sw(sw),
               .led(led),
           .S_AXI_ACLK(s00_axi_aclk),
4. Save the changes in the file (Ctrl+S). Next, expand and open the other Verilog file (`AUP_advanced_SoC_v1_0_S00_AXI.v`) shown below:
   ![Screenshot of Vivado Sources panel showing the AUP_advanced_SoC_v1_0_S00_AXI.v file which implements the AXI-Lite slave interface logic and needs modifications for GPIO register mapping](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture11.png)
   _Figure 2.5. Edit the second Verilog file_
5. Add the following lines of code below the comment “// Users to add ports here”:
   ```verilog
6. Scroll down the file and search (Ctrl+F) for “// Address decoding for reading registers”. Then update the code so that it looks like the following:
   ```verilog
   case ( axi_araddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB] )
   2'h0   : reg_data_out <= {slv_reg0[C_S_AXI_DATA_WIDTH-1:4], sw[3:0]};
7. Scroll down the file and search (Ctrl+F) for “// Add user logic here”. Then update the code so that it looks like the following:
   ```verilog
   assign led[3:0] = slv_reg1[3:0];
8. Save the changes in the file (Ctrl+S). Next, go to the “Package IP – AUP_advanced_SoC” tab, choose the “Customization Parameters” option on the left and click “Merge Changes from Customization Parameters Wizard” to update the IP package with the changes made in HDL files:
   ![Screenshot of Vivado Package IP window showing the Customization Parameters page with the Merge changes from Customization Parameters Wizard link highlighted to synchronize HDL code changes with IP packaging](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture12.png)
   _Figure 2.6. Saving all the changes_
9. Click “Review and Package” on the left and select “Re-Package IP” at the bottom of the page. A prompt will appear – select “Yes” to close the project.
10. Go to the AXI4 peripheral folder you created earlier `<ip>\drivers<AUP_advanced_SoC_v1_0>\src` and locate a `Makefile`. In that `Makefile`, update the contents so that it is the following:
    ```makefile
    COMPILER=
    ARCHIVER=
    CP=cp
    COMPILER_FLAGS=
    EXTRA_COMPILER_FLAGS=
    LIB=libxil.a
    RELEASEDIR=../../../lib
    INCLUDEDIR=../../../include
    INCLUDES=-I./. -I${INCLUDEDIR}
    INCLUDEFILES=*.h
    LIBSOURCES= $(wildcard *.c)
    OUTS = *.o
    OBJECTS = $(addsuffix .o, $(basename $(wildcard *.c)))
    ASSEMBLY_OBJECTS = $(addsuffix .o, $(basename $(wildcard *.S)))
    libs:
        echo "Compiling axi_gpio_asoc..."
        $(COMPILER) $(COMPILER_FLAGS) $(EXTRA_COMPILER_FLAGS) $(INCLUDES) $(LIBSOURCES)
        $(ARCHIVER) -r ${RELEASEDIR}/${LIB} ${OBJECTS} ${ASSEMBLY_OBJECTS}
        make clean
    include:
        ${CP} $(INCLUDEFILES) $(INCLUDEDIR)
    clean:
        rm -rf ${OBJECTS} ${ASSEMBLY_OBJECTS}
11. Then, click on “Settings” (under “Project Manager”) in the “Flow Navigator” menu on the left. Expand the “IP” section in the new window that appears:
    ![Screenshot of Vivado Project Settings showing the IP section expanded with Repository selected, where you add the custom IP location so Vivado can find and use the AXI peripheral you created](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture13.png)
    _Figure 2.7. Adding IP Repository_
12. Click the “+” option under “IP Repositories” on the right and choose the AXI4 peripheral folder you created earlier (if it hasn’t already appeared) and click “Ok”. Right-click in the empty space of the “Diagram” box again and choose “Add IP”. Type “custom” in the search box and choose “custom_axi_gpio_asoc_v1_0” from the options.
13. Click “Run Connection Automation” and then click “OK” to connect the AXI-Lite Subordinate interface on GPIO peripheral to the AXI Manager interface on Arm processor.
    ![Screenshot of Vivado block diagram showing the Run Connection Automation dialog with the S_AXI interface of the custom GPIO peripheral ready to be automatically connected to the Zynq processing system’s M_AXI_GP0 master port](/learning-paths/embedded-and-microcontrollers/advanced_soc/images/picture14.png)
    _Figure 2.8. Connect AXI-Lite Subordinate interface (Custom IP) to AXI Manager interface_
Now that you have created the custom AXI4 peripheral which will control the GPIO, you will connect it up to the ZYNQ Processing System in the next section.
