Explore related resources
Give feedback
AI-assisted
Close
How do I know the Zephyr shell is enabled and working after I flash the board?
You should see a shell prompt on the selected backend after boot. Run a built-in command such as kernel version to confirm the shell responds.
Do I need to add networking code in main.c for the MQTT shell example?
No. The MQTT example starts the shell, network stack, DHCP client, and MQTT shell backend from configuration options in prj.conf.
Which backend should I use if I want to interact locally during bring-up?
Use the UART shell backend. It maps shell input and output to the active UART console over the board’s USB serial interface and doesn’t require network connectivity.
What should I check if I don’t see any shell output over UART?
Verify that the UART shell backend is enabled in prj.conf and that you’re connected to the board’s USB serial interface selected as the active console. Use a serial terminal application supported on your host OS to view the console.
What should I check if the MQTT shell doesn't connect to the broker?
Confirm CONFIG_SHELL_BACKEND_MQTT is enabled and that required networking options are set in prj.conf so the device can obtain network connectivity. Ensure the MQTT broker is reachable from the board over Ethernet.
Return to Embedded and Microcontrollers
