# Build and run the Zephyr MQTT shell on Arm Cortex-M
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/)
- [Set up the Zephyr shell development environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/1_installation/)
- [Understand the Zephyr shell subsystem and backends](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/2_overview/)
- [Build and run the Zephyr MQTT shell on Arm Cortex-M](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/3_mqtt_shell/)
- [Build and run the Zephyr UART shell on Arm Cortex-M](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/4_uart_shell/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/_next-steps/)
## Build a Zephyr application to enable the MQTT shell backend
Start by building a minimal Zephyr application that enables the MQTT shell backend.
The application doesn’t need networking code in `main.c`. Zephyr starts the shell, network stack, DHCP client, and MQTT shell backend from configuration options in `prj.conf`.
### How the MQTT shell backend works
When `CONFIG_SHELL_BACKEND_MQTT=y` is enabled, Zephyr’s MQTT shell backend connects to a broker and uses MQTT topics to carry shell traffic.
The default topic pattern is:
| Direction                              | Topic                      |
| Commands sent to the board             | `<device_id>/sh/rx`       |
| Responses sent from the board          | `<device_id>/sh/tx`       |
The backend derives `<device_id>` from the hardware device ID, so each board uses a unique topic prefix. You’ll read this ID from the broker after the board connects for the first time.
### Create an application project in Workbench for Zephyr
To create an application project in Workbench for Zephyr:
1. Open the **Workbench for Zephyr** panel.
2. In the panel, select **New Application** to open the **Create a new Zephyr Application Project** wizard.
3. After opening the wizard, fill in the following fields:
   - For **Select West Workspace**, select your initialized West workspace for Zephyr v4.4.0 (for example, `zephyr`).
   - For **Select Toolchain**, select `zephyr-sdk-1.0.1`.
   - For **Select Board**, select **NXP FRDM-MCXN947 (CPU0)** (Zephyr identifier `frdm_mcxn947/mcxn947/cpu0`).
   - For **Application type**, select **Create new application**.
   - For **Select Sample project**, select `hello_world`.
   - For **Project Name**, enter `mqtt_shell_backend`.
   - For **Project Location**, select the directory where you want to create the project (for example, `zephyr/apps`).
   - Leave **Debug preset** checked.
   - Leave **Advanced options** as the defaults.
4. Select **Create** to generate the project.
![Workbench for Zephyr application project wizard](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/images/wz_new_project.webp)
### Configure the application
The `hello_world` sample provides a working `CMakeLists.txt`, `prj.conf`, and `src/main.c`. Leave `CMakeLists.txt` unchanged, and replace `prj.conf` and `src/main.c`.
Replace the contents of `prj.conf` with the following text:
# Shell and MQTT backend
CONFIG_SHELL=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_IPV4=y
CONFIG_NET_TCP=y
CONFIG_NET_DHCPV4=y
CONFIG_NET_CONFIG_SETTINGS=y
# MQTT broker address
CONFIG_SHELL_MQTT_SERVER_ADDR="192.168.1.233"
# Optional shell modules and logging
CONFIG_NET_SHELL=y
CONFIG_LOG=y
# Resource tuning
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_NET_PKT_RX_COUNT=16
CONFIG_NET_BUF_RX_COUNT=32
Replace `192.168.1.233` with the IP address of the host running Mosquitto, as seen from the board’s Ethernet network.
The values under `# Resource tuning` keep the shell footprint small on Cortex-M and allow the network stack and MQTT client to operate reliably.
**Use a static IPv4 address**
DHCP is convenient, but it’s not required. To use a static address, remove:
CONFIG_NET_DHCPV4=y
Then, add values that match your network:
CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.50"
CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.255.0"
CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
Keep `CONFIG_NET_CONFIG_SETTINGS=y` enabled so Zephyr applies the network configuration at boot.
**Update the main function**
The shell and MQTT backend start from Zephyr initialization hooks.
Replace the contents of `main.c` with the following code:
int main(void)
    return 0;
### Build and flash
In the **Workbench for Zephyr** panel, select your project and build configuration. Select **Build**, then select **Flash**.
The FRDM-MCXN947 uses NXP LinkServer as the debug runner. If LinkServer isn’t installed, follow the **Workbench for Zephyr** prompt to install or configure it.
## Create the Mosquitto Docker Compose project
After building the Zephyr application, you’ll run an Eclipse Mosquitto broker in Docker.
Create a directory named `mosquitto_shell` on your host computer with the following structure:
mosquitto_shell/
|-- docker-compose.yml
`-- mosquitto/
    `-- config/
        `-- mosquitto.conf
Edit the `docker-compose.yml` file and add the following text:
services:
  mosquitto:
    image: eclipse-mosquitto:latest
    container_name: mosquitto-mqtt
    ports:
      - "1883:1883"
    volumes:
      - ./mosquitto/config:/mosquitto/config:ro
      - ./mosquitto/data:/mosquitto/data
      - ./mosquitto/log:/mosquitto/log
    restart: unless-stopped
Edit the `mosquitto.conf` file and add the following text:
listener 1883 0.0.0.0
allow_anonymous true
persistence true
persistence_location /mosquitto/data/
log_dest file /mosquitto/log/mosquitto.log
log_dest stdout
log_type all
From the `mosquitto_shell` directory, start the broker:
docker compose up -d
Check that the container is running:
docker compose ps
The output is similar to:
NAME                  IMAGE                        STATUS
mosquitto-mqtt        eclipse-mosquitto:latest     Up
The `eclipse-mosquitto` image includes `mosquitto_pub` and `mosquitto_sub`, so you can run both tools from inside the container with `docker exec`.
### (Optional) Install Mosquitto directly on host machine
If you prefer not to use Docker, you can install Mosquitto directly on your host computer. This gives you the `mosquitto` broker, `mosquitto_pub`, and `mosquitto_sub` commands locally.
Install Mosquitto with your operating system package manager.
On Linux (Debian or Ubuntu):
sudo apt install mosquitto mosquitto-clients
On macOS, use Homebrew:
brew install mosquitto
On Windows, use winget:
winget install EclipseFoundation.Mosquitto
After installation on Windows, add the Mosquitto install directory (typically `C:\Program Files\mosquitto`) to your `PATH` environment variable so that `mosquitto_pub` and `mosquitto_sub` are available from the command prompt.
After installing Mosquitto directly, start the broker using your operating system’s service manager, or run it manually with a local configuration file.
The remaining commands in this section use `docker exec` to run `mosquitto_sub` and `mosquitto_pub` inside the container. If you installed Mosquitto directly, drop the `docker exec -it mosquitto-mqtt` prefix and run the tools directly instead.
For example, this container command:
docker exec -it mosquitto-mqtt mosquitto_sub -h localhost -t "1a2b3c/sh/tx" -v
becomes:
The same substitution applies to every `mosquitto_pub` command later in this section.
## Find the device ID
The MQTT shell backend derives its client ID from the board’s hardware UID, so each board connects with topics under `<device_id>/sh/rx` and `<device_id>/sh/tx`.
There are two ways to read this ID:
### Read from the board’s serial console
If you have a serial terminal open on the board’s UART, the MQTT backend logs the topics it subscribes to and publishes from at boot.
A typical FRDM-MCXN947 boot log looks like this:
*** Booting Zephyr OS build v4.4.0 ***
[00:00:01.654,000] <inf> phy_mii: PHY (0) Link speed 100 Mb, full duplex
[00:00:01.654,000] <inf> eth_nxp_enet_qos_mac: Link is up
[00:00:01.656,000] <wrn> shell_mqtt: Network connected
[00:00:01.656,000] <inf> app_main: MQTT shell backend demo on frdm_mcxn947
[00:00:02.656,000] <inf> shell_mqtt: DNS resolved for 192.168.1.31:1883
[00:00:02.656,000] <err> shell_mqtt: mqtt_connect error: -22
[00:00:03.656,000] <inf> shell_mqtt: DNS resolved for 192.168.1.31:1883
[00:00:03.656,000] <err> shell_mqtt: mqtt_connect error: -22
[00:00:04.656,000] <inf> shell_mqtt: DNS resolved for 192.168.1.31:1883
[00:00:04.656,000] <err> shell_mqtt: mqtt_connect error: -22
[00:00:05.656,000] <inf> shell_mqtt: DNS resolved for 192.168.1.31:1883
[00:00:05.656,000] <err> shell_mqtt: mqtt_connect error: -22
[00:00:06.656,000] <inf> shell_mqtt: DNS resolved for 192.168.1.31:1883
[00:00:06.818,000] <wrn> shell_mqtt: MQTT client connected!
[00:00:07.823,000] <wrn> shell_mqtt: MQTT subscribe: ok
[00:00:07.823,000] <inf> shell_mqtt: Logs will be published to: 1a2b3c/sh/tx
[00:00:07.823,000] <inf> shell_mqtt: Subscribing shell cmds from: 1a2b3c/sh/rx
The two `<inf> shell_mqtt:` lines in the last two lines of the log give you the device ID directly. In this example, it’s `1a2b3c`.
> **Note**
> The `mqtt_connect error: -22` lines you see during the first few seconds are expected. The Zephyr MQTT client retries the connect handshake until the broker accepts it, usually within a few attempts. The connection completes when you see `MQTT client connected!`, followed by `MQTT subscribe: ok`.
### Read from the broker side
If you don’t have a serial terminal open, watch every shell-output topic with a wildcard:
docker exec -it mosquitto-mqtt mosquitto_sub -h localhost -t "+/sh/tx" -v
When the board connects, it publishes its shell prompt to `<device_id>/sh/tx`. The topic prefix on the first message is the device ID:
1a2b3c/sh/tx mqtt:~$
You can also confirm the same value from the broker’s connection log:
docker logs mosquitto-mqtt | grep "New client connected"
The device ID appears in the client connection entry:
New client connected from 192.168.65.1:65496 as 1a2b3c (p4, c0, k60).
## Subscribe to shell output
Narrow the subscription to your board’s response topic only. Replace `1a2b3c` with your device ID:
Keep this terminal open. Every shell response from the board will print here.
## Send shell commands using Mosquitto
You’ll now send shell commands to the board using the Mosquitto command-line tools.
Open a second terminal to publish commands to the board:
printf 'kernel version\n' | docker exec -i mosquitto-mqtt mosquitto_pub -h localhost -t "1a2b3c/sh/rx" -s
The command is published to Mosquitto and the board executes it.
The response appears in the first terminal:
1a2b3c/sh/tx Zephyr version 4.4.0
Try the following commands:
| Command                   | Description                                              |
| `kernel version`          | Print the Zephyr version string.                        |
| `kernel uptime`          | Print the time since boot.                             |
| `kernel thread list`      | Print the thread list and stack usage.                 |
| `net iface`              | Print network interface configuration, including the assigned IPv4 address. |
| `net ping <ip>`          | Send ICMP echo requests to a reachable host (for example, your gateway). |
| `device list`            | Print registered Zephyr devices.                        |
| `help`                   | Print available shell modules and commands.            |
The `net` commands are available because you set `CONFIG_NET_SHELL=y` in `prj.conf`. Without that option, only the `kernel`, `device`, and `shell` modules are exposed.
Example output for `kernel uptime`:
1a2b3c/sh/tx Uptime: 55310 ms
Truncated example output for `kernel thread list` on the FRDM-MCXN947 (the full list shows the network and Ethernet driver threads):
Scheduler: 1046 since last call
Threads:
*0x300015d0 shell_mqtt
	options: 0x0, priority: 14 timeout: 0
	state: queued, entry: 0x100069e5
	stack size 2048, unused 1096, usage 952 / 2048 (46 %)
0x30001c30 sh_mqtt_workq
	options: 0x0, priority: -9 timeout: 800
	state: pending, entry: 0x100223cd
	stack size 2048, unused 1160, usage 888 / 2048 (43 %)
0x30002688 conn_mgr_monitor
	options: 0x0, priority: -1 timeout: 0
	state: pending, entry: 0x1001ea0d
	stack size 512, unused 264, usage 248 / 512 (48 %)
0x300027c0 ENETQOS_RX
	options: 0x0, priority: -13 timeout: 0
	stack size 1024, unused 752, usage 272 / 1024 (26 %)
0x300028b0 idle
	options: 0x1, priority: 15 timeout: 0
	state: , entry: 0x1003a335
	stack size 320, unused 256, usage 64 / 320 (20 %)
The `*` next to `shell_mqtt` marks the running thread, which is the shell that executed the command. Note that responses larger than the MQTT buffer are split across multiple publishes. `mosquitto_sub -v` reassembles them sequentially under the `1a2b3c/sh/tx` topic prefix.
Example output for `net iface` on the FRDM-MCXN947, truncated to the IPv4 section:
1a2b3c/sh/tx Default interface: 1
Interface eth0 (0x30000c70) (Ethernet) [1]
Link addr : XX:XX:XX:XX:XX:XX
MTU       : 1500
Flags     : AUTO_START,IPv4,IPv6
Status    : oper=UP, admin=UP, carrier=ON
Ethernet link speed: 100 Mbits full-duplex
IPv4 unicast addresses (max 1):
	192.168.1.41/255.255.255.0 DHCP preferred
IPv4 gateway : 192.168.1.1
DHCPv4 state      : bound
DHCPv4 server     : 192.168.1.1
Next, run `net ping` with the gateway address shown by `net iface`. The board sends three ICMP echo requests by default.
Example output for `net ping 192.168.1.1` (board pinging its gateway):
1a2b3c/sh/tx PING 192.168.1.1
28 bytes from 192.168.1.1 to 192.168.1.41: icmp_seq=1 ttl=64 time=0 ms
28 bytes from 192.168.1.1 to 192.168.1.41: icmp_seq=2 ttl=64 time=0 ms
28 bytes from 192.168.1.1 to 192.168.1.41: icmp_seq=3 ttl=64 time=0 ms
> **Note**
> The MQTT shell backend executes a command after it receives a newline character. The `printf 'kernel version\n' | ... mosquitto_pub -s` form sends the command with the required newline.
## (Optional) Switch to a different board
The application is portable across any Zephyr-supported board with Ethernet, because the MQTT backend is selected through Kconfig and there’s no board-specific code in `main.c`. You don’t need to recreate the project to test it on another board.
To change the target board on an existing project:
1. Open the **Workbench for Zephyr** panel in the VS Code Activity Bar.
2. Expand the **Applications** section. The project you created appears with its current board name underneath.
3. Right-click the board name and select **Change board**. Pick a new board from the list (for example, an STM32 Nucleo-H743ZI or another Cortex-M board with Ethernet).
4. Right-click the application and select **Clean** to remove the previous build artifacts.
5. Right-click the application and select **Build (pristine)** to rebuild the project from scratch with the new board configuration.
After the pristine build completes, flash the board as before. The same `prj.conf` and `main.c` work without changes, and the MQTT backend connects as soon as the new board acquires an IPv4 address.
> **Note**
> You need a pristine build when you change the board because Workbench for Zephyr caches board-specific generated files (device tree, Kconfig, linker script) in the build directory. Without a clean rebuild, the previous board’s configuration leaks into the new build and produces incorrect binaries.
## What you’ve accomplished and what’s next
You now have a working Zephyr shell over MQTT on the FRDM-MCXN947.
In the next section, you’ll enable the UART shell backend on the FRDM-MCXN947. You’ll interact with the shell through a USB serial connection.
