# Understand the Zephyr shell subsystem and backends
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/)
- [Set up the Zephyr shell development environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/1_installation/)
- [Understand the Zephyr shell subsystem and backends](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/2_overview/)
- [Build and run the Zephyr MQTT shell on Arm Cortex-M](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/3_mqtt_shell/)
- [Build and run the Zephyr UART shell on Arm Cortex-M](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/4_uart_shell/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_shell/_next-steps/)
## How the Zephyr shell subsystem works
The Zephyr shell subsystem (`CONFIG_SHELL=y`) adds an interactive command-line interface to your firmware. After you enable the shell, you can inspect system state, run subsystem commands, and trigger application behavior at runtime without rebuilding or reflashing the application.
Several Zephyr subsystems register shell commands automatically. Common built-in modules include:
| Module  | Example commands                                   |
| `kernel`| `version`, `uptime`, `thread list`, `thread stacks` |
| `net`   | `iface`, `ping`, `dns`, `tcp`                     |
| `device`| `list`                                            |
| `log`   | `enable`, `disable`, `levels`                     |
| `shell` | `help`, `history`, `resize`                       |
For more information on the shell subsystem, see the [Zephyr shell documentation](https://docs.zephyrproject.org/latest/services/shell/index.html).
## How shell backends work
The shell command tree is independent of the transport. The same commands can run over UART, RTT, MQTT, or another enabled backend. You can select a transport by setting a single Kconfig option, with no code changes in `main.c`.
You can enable multiple backends at the same time in a single application when the board has the required peripherals and memory.
A minimal shell build with only the kernel and device modules adds roughly 10 to 15 KB to flash and a few hundred bytes to RAM on a Cortex-M target. The exact footprint depends on the modules enabled and the toolchain optimization level.
In this Learning Path, you’ll work with two transports:
### MQTT backend
Enable the MQTT backend with `CONFIG_SHELL_BACKEND_MQTT=y`. The MQTT backend routes shell commands and responses over MQTT topics. The board subscribes to `<device_id>/sh/rx` for inbound commands and publishes responses to `<device_id>/sh/tx`. The backend is IPv4-only and connects automatically when the board has an IPv4 address.
### UART backend
Enable the UART backend with `CONFIG_SHELL_BACKEND_SERIAL=y`. The UART backend routes shell commands and responses over the board’s UART interface, accessible through a USB serial connection. Use PuTTY on Windows, or `screen` on macOS and Linux. This backend works on a wide range of Zephyr-supported development boards without the need for additional debug hardware.
## What you’ve accomplished and what’s next
You’ve now learned how the Zephyr shell subsystem and shell backends work.
Next, you’ll build a small Zephyr application that enables the MQTT shell on the NXP FRDM-MCXN947, with a local Mosquitto broker running in Docker. You’ll send commands and read responses with the `mosquitto_pub` and `mosquitto_sub` command-line tools.
