Before you begin
In this section, you’ll prepare your host computer and identify the hardware you need for two Zephyr shell examples. You’ll use the shell over two transports:
  • MQTT over Ethernet
  • UART over a USB serial connection
Make sure that you have a working Zephyr development environment set up in Visual Studio Code with:
  • The Workbench for Zephyr extension installed
  • A Zephyr SDK toolchain imported in Workbench
  • A West workspace initialized
Before working through this Learning Path, complete Build Zephyr projects with Workbench for Zephyr in VS Code .
The two examples in this Learning Path have additional requirements:
  • MQTT shell example: Docker Desktop, Docker Engine, or another Docker-compatible runtime on your host computer, if you’re not installing Mosquitto on host. The board communicates with a Mosquitto broker running in a container.
  • UART shell example: A USB cable to connect the development board to your host computer. The board exposes a shell prompt over the USB serial interface.
Hardware requirements
Both examples use the FRDM-MCXN947 as the development board (Zephyr identifier frdm_mcxn947/mcxn947/cpu0). The FRDM-MCXN947 includes an Ethernet port for the MQTT shell example and a USB UART interface for the UART shell example. This allows both examples to run on the same board.
To check whether another board is supported by Zephyr, see the Zephyr supported boards list .
Set up UART terminal tools
For the UART shell example, you’ll need a serial terminal application on your host computer. You’ll use the terminal application to connect to the Zephyr shell over the board’s UART interface.
You can complete this Learning Path on Windows, macOS, and Linux host computers.
Windows
Install PuTTY , which provides a lightweight serial terminal for UART communication on Windows.
macOS
macOS includes a built-in UART terminal utility through the screen command, so you don’t need additional software to connect to the shell.
Linux
Linux includes screen in most distributions, so you don’t need additional software to connect to the shell. If screen isn’t installed, use your package manager to install it:
sudo apt install screen
Note
Workbench for Zephyr supports multiple debug runners depending on the connected board. The FRDM-MCXN947 board uses the onboard CMSIS-DAP/LinkServer interface for flashing and debugging, and UART over USB for shell access.
Network requirements for the MQTT shell example
For the MQTT shell example, the board needs access to an MQTT broker over Ethernet. You’ll run Mosquitto locally and use the Mosquitto command-line tools to send and receive shell messages.
Make sure that:
  • The board is connected to the same network as the host computer.
  • The network provides DHCP, or you configure a static IPv4 address in prj.conf.
  • The board can reach the MQTT broker on port 1883.
Note
The example configuration uses IPv4. If your network doesn’t provide DHCP, use the static IPv4 settings shown in the next section.
You’ve now learned which boards to use, which host tools to install, and how the Zephyr shell fits into an embedded application.
In the next section, you’ll learn about the Zephyr shell subsystem and the two transports used in this Learning Path.
