Deploy a Zephyr ML app on Corstone-320 MPS4 with ExecuTorch
Set up the Zephyr and ExecuTorch development environment
Build and run an ML app on Corstone-320 MPS4
Set up the platform and software
The Arm Corstone SSE-320 FPGA image for MPS4 (FI101) is an FPGA implementation that runs on the MPS4 board. The image includes an Arm Cortex-M85 processor, an Arm Ethos-U85 NPU, and a range of peripheral components. It provides a practical hardware platform for developing and evaluating machine learning applications.
Download the latest Corstone-320 FPGA image and review the platform documentation:
- Arm Corstone SSE-320 with Cortex-M85 and Ethos-U85: Example FPGA (FI101)
- SSE-320 FPGA Image for MPS4 Application Note
- Arm MPS4 FPGA Prototyping Board Technical Reference Manual
- Arm Corstone SSE-320 Example Subsystem Software Programmers Guide
Set up a Zephyr workspace and board target
To set up the Zephyr workspace for the Arm Corstone-320 MPS4 platform, complete the steps in Port Zephyr RTOS and run applications on the Arm Corstone-320 MPS4 platform . Use Zephyr version V4.3.0.
ExecuTorch integration in the Zephyr tree
ExecuTorch is integrated into the Zephyr workspace as an external module located in modules/lib/executorch. The module provides the ExecuTorch runtime, the Arm backend, the Ethos-U delegate, build scripts, and sample applications. You can build the sample applications using the Zephyr build system.
To add ExecuTorch as a Zephyr module, create executorch.yaml in zephyr/submanifests with the following content:
manifest:
projects:
- name: executorch
url: https://github.com/pytorch/executorch
revision: main
path: modules/lib/executorch
Run the following commands to fetch the ExecuTorch repository and its submodules. The commands place the ExecuTorch source tree in modules/lib/executorch:
west update
cd modules/lib/executorch
git submodule sync
git submodule update --init --recursive
./install_executorch.sh
Set up the Arm and Ethos-U toolchain
ExecuTorch includes a setup script that downloads the Arm GNU Toolchain, the Tensor Operator Set Architecture (TOSA) Serialization Library, the Ethos-U Vela graph compiler, and other utilities.
Run the following commands to download, install, and configure these tools on your system:
./examples/arm/setup.sh --i-agree-to-the-contained-eula
source examples/arm/arm-scratch/setup_path.sh
With the development environment and toolchain configured, prepare the model for deployment.
Pre-process the PyTorch model for NPU delegation
The ExecuTorch
Ahead-of-Time (AOT)
pipeline takes a PyTorch model (a torch.nn.Module) and produces a .pte binary file. The ExecuTorch runtime uses this file for inference.
The following example shows a PyTorch model, add.py, that performs a single addition:
import torch
b = 2
class myModelAdd(torch.nn.Module):
def __init__(self):
super().__init__()
def forward(self, x):
return x + x + b
ModelUnderTest = myModelAdd()
ModelInputs = (torch.ones(5),)
Run the following commands from the modules/lib/executorch directory to quantize the model and export it through the AOT flow using the Ethos-U backend:
source ~/zephyrproject/.venv/bin/activate
python3 -m executorch.backends.arm.scripts.aot_arm_compiler \
--model_name=examples/arm/example_modules/add.py \
-t ethos-u85-1024 \
--delegate \
--quantize \
--memory_mode=Sram_Only \
-o add_u85_1024_sram_only.pte
The following are key parameters used in the commands:
| Parameter | Value | Notes |
--model_name | path to .py model file | Use absolute or workspace-relative path |
-t / --target | ethos-u85-1024 | Must match CONFIG_ETHOS_U85_1024=y in Kconfig |
--delegate | (flag) | Enables Ethos-U NPU delegation via ArmBackend |
--quantize | (flag) | Applies INT8 symmetric quantisation |
--memory_mode | Shared_Sram or Sram_Only | Vela memory layout that must match the runtime build |
--system_config | Ethos_U85_SYS_DRAM_Mid | (Optional) Selects Vela system config from vela.ini |
-o | output filename | Saved in the project root by default |
The add_u85_1024_sram_only.pte file contains the model graph, quantized weights, and a Vela-compiled command stream. The Ethos-U85 executes the command stream directly.
Verify the model file was created:
ls -la add_u85_1024_sram_only.pte
You now have a quantized .pte model file ready for deployment.
Next, you’ll port the hello-executorch sample application to the Corstone-320 MPS4 platform and run inference on the Ethos-U85 NPU.
