Deploy a Zephyr ML app on Corstone-320 MPS4 with ExecuTorch
Set up the Zephyr and ExecuTorch development environment
Build and run an ML app on Corstone-320 MPS4
Confirm the board is running the SSE-320 FI101 image that includes Cortex-M85 and Ethos-U85 by following the application note and board documentation. Proceed only after verifying the image matches the FI101 release you downloaded.
Use the
mps4/corstone320/fpga board target with Zephyr version V4.3.0.Override the weak
ethosu_config_select() function in ethosu_device_u85.c to set the QCONFIG and REGIONCFG registers for Ethos-U85. Your override must keep the command stream, weights, and scratch data in SRAM for the SRAM-only model.After quantization and export, you should have the
.pte model artifact add_u85_1024_sram_only.pte. Pass it to the Zephyr build with the -DET_PTE_FILE_PATH flag, as shown in the build command.You should see the
hello-executorch model delegate flow and inference output over UART, followed by SUCCESS: Program complete, exiting.
