# Build and run the hello_world sample on Arm Corstone-320 MPS4
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/)
- [Set up the Zephyr build environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/how-to-1/)
- [Add Zephyr board support for the Arm Corstone-320 MPS4 platform](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/how-to-2/)
- [Build and run the hello_world sample on Arm Corstone-320 MPS4](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/how-to-3/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/_next-steps/)
## Build the hello_world example for MPS4
The Zephyr `hello_world` example prints “Hello World” to the console. Use it to validate that your board support and toolchain configuration work correctly.
Activate your Python virtual environment:
source ~/zephyrproject/.venv/bin/activate
If you haven’t set the toolchain environment variables in your current terminal, set them now. For full setup steps, see [Set up the Zephyr build environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/how-to-1/):
export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
export GNUARMEMB_TOOLCHAIN_PATH=$HOME/arm-gnu-toolchain-13.2.Rel1-aarch64-arm-none-eabi
Replace the path with the path to your toolchain directory. On x86_64, the directory name starts with `x86_64` instead of `aarch64`.
From the `~/zephyrproject/zephyr` directory, build the `hello_world` example for the Corstone-320 FPGA variant:
west build -p always -b mps4/corstone320/fpga zephyr/samples/hello_world -- -DCONFIG_ROMSTART_RELOCATION_ROM=y
The output is similar to:
__output__ [xxx/xxx] Linking C executable zephyr/zephyr.elf
__output__ Memory region         Used Size  Region Size  %age Used
__output__ ROMSTART_REGION:         xxx B       128 KB      x.xx%
__output__           FLASH:       xxxxx B         4 MB      x.xx%
__output__             RAM:        xxxx B         2 MB      x.xx%
Verify that the ELF image was created:
ls build/zephyr/zephyr.elf
__output__ build/zephyr/zephyr.elf
The ELF image contains the application and the Zephyr kernel libraries. You can now load it onto the MPS4 board.
## Run the hello_world application on the MPS4 board
To run the application on the MPS4 board, follow these steps:
1. Download the board files from [FI101](https://developer.arm.com/downloads/view/FI101?sortBy=availableBy&revision=r1p0-00eac0-2).
2. Set up the MPS4 platform according to the [Using the FI101 on MPS4 board](https://developer.arm.com/documentation/109762/0100/?lang=en).
3. For the hello_world application, place the vector table in the FPGA boot ROM at address `0x11000000`, and place the remaining code and data in SRAM at address `0x31000000`. Use `arm-none-eabi-objcopy` to extract these two regions from `build/zephyr/zephyr.elf`:
arm-none-eabi-objcopy -O binary --only-section=rom_start zephyr.elf vector.bin
arm-none-eabi-objcopy -O binary --remove-section=rom_start zephyr.elf app.bin
4. Update `images.txt` under `/MB/HBI0376B/FI101` to load the two images. The paths use the `\SOFTWARE\` folder on the MPS4 SD card, which is where you will copy the binary files:
IMAGE0PORT: 2
IMAGE0ADDRESS: 0x00_1100_0000           ; Address to load into
IMAGE0UPDATE: RAM
IMAGE0FILE: \SOFTWARE\vector.bin        ; Image/data to be loaded
IMAGE1PORT: 1
IMAGE1ADDRESS: 0x31000000               ; Address to load into
IMAGE1UPDATE: RAM
IMAGE1FILE: \SOFTWARE\app.bin           ; Image/data to be loaded
5. Copy `vector.bin` and `app.bin` to the `\SOFTWARE\` folder on the MPS4 SD card, then power on the board. If the setup is correct, the UART console prints the “Hello World” message, similar to the following example:
![UART console output showing “Hello World! arm” from Zephyr running on the Corstone-320 MPS4 board](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/image.png)
## What you’ve accomplished
You’ve now built and run the Zephyr `hello_world` example on the MPS4 board.
You can use the workflow outlined in this Learning Path as a foundation to further customize Zephyr on the Corstone-320 MPS4 platform and validate a complete build-and-run workflow.
