Understand the Arm Corstone-320 MPS4 platform
The Arm Corstone SSE-320 FPGA Image for MPS4 (FI101) provides an FPGA implementation that runs on the MPS4 board. The image includes an Arm Cortex-M85 processor, an Arm Ethos-U85 NPU, and an Arm CoreLink DMA-350 direct memory access (DMA) controller. With this setup, you get a practical environment for developing and evaluating embedded applications, including machine learning workloads.
Download the latest Corstone-320 FPGA image and review the platform documentation:
- Arm Corstone SSE-320 with Cortex-M85 and Ethos-U85: Example FPGA (FI101)
- SSE-320 FPGA Image for MPS4 Application Note
- Arm MPS4 FPGA Prototyping Board Technical Reference Manual
- Arm Corstone SSE-320 Example Subsystem Software Programmers Guide
Understand Zephyr board support architecture
Zephyr organizes hardware support in the following hierarchy:
Board → SoC → CPU Cluster → CPU Core → Architecture
For Corstone-320 MPS4, this hierarchy maps as follows:
| Level | Value | Description |
| Board | mps4 | Board name used with west build -b |
| SoC | corstone320 | Corstone-320 subsystem |
| CPU Cluster | m85 | Cortex-M85 cluster |
| CPU Core | — | Single Cortex-M85 core |
| Architecture | — | ARMv8.1-M with Helium |
Add files to the existing board directory
The boards/arm/mps4/ directory already exists in the Zephyr tree with support for the Corstone-315 and Corstone-320 FVP variants. In this section, you’ll add the Corstone-320 FPGA variant by modifying three existing files and creating three new ones.
Navigate to the MPS4 board directory:
cd ~/zephyrproject/zephyr/boards/arm/mps4
You’ll modify or create the following files:
boards/arm/mps4/
├── board.yml # Board metadata (modify)
├── Kconfig.mps4 # Board Kconfig entry (modify)
├── Kconfig.defconfig # Default Kconfig settings (modify)
├── mps4_corstone320_fpga_defconfig # Board defconfig fragment (new)
├── mps4_corstone320_fpga.dts # Device tree source (new)
└── mps4_common_soc_peripheral_fpga.dtsi # SoC peripheral definitions (new)
board.yml
board.yml describes the board name, vendor, SoC, and supported variants. Zephyr reads this file to recognize the board target that you pass to west build.
The existing board.yml already defines the FVP variants. Add the fpga variant under the corstone320 SoC entry so the file looks like this:
board:
full_name: MPS4
vendor: arm
socs:
- name: 'corstone315'
variants:
- name: 'fvp'
variants:
- name: 'ns'
- name: 'corstone320'
variants:
- name: 'fvp'
variants:
- name: 'ns'
- name: 'fpga'
The device tree source file describes the Corstone-320 MPS4 hardware: memory regions, CPU configuration, peripherals, and how Zephyr should use them. Use the SSE-320 FPGA Image for MPS4 Application Note as the reference for the memory map and peripheral addresses, and tailor the file to the peripherals your application needs.
Create boards/arm/mps4/mps4_corstone320_fpga.dts with the following content:
/dts-v1/;
#include <arm/armv8.1-m.dtsi>
#include <zephyr/dt-bindings/i2c/i2c.h>
#include <zephyr/dt-bindings/input/input-event-codes.h>
#include <mem.h>
compatible = "arm,mps4-fpga";
#address-cells = <1>;
#size-cells = <1>;
chosen {
zephyr,console = &uart0;
zephyr,shell-uart = &uart0;
zephyr,sram = &sram;
zephyr,flash = &isram;
cpus {
#size-cells = <0>;
cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-m85";
reg = <0>;
#size-cells = <1>;
mpu: mpu@e000ed90 {
compatible = "arm,armv8.1m-mpu";
reg = <0xe000ed90 0x40>;
ethosu {
#size-cells = <0>;
interrupt-parent = <&nvic>;
ethosu0: ethosu@50004000 {
compatible = "arm,ethos-u";
reg = <0x50004000>;
interrupts = <16 3>;
secure-enable;
privilege-enable;
status = "okay";
itcm: itcm@10000000 {
compatible = "zephyr,memory-region";
reg = <0x10000000 DT_SIZE_K(32)>;
zephyr,memory-region = "ITCM";
sram: sram@12000000 {
compatible = "zephyr,memory-region", "mmio-sram";
reg = <0x12000000 DT_SIZE_M(2)>;
zephyr,memory-region = "SRAM";
rom: rom@11000000 {
reg = <0x11000000 DT_SIZE_K(128)>;
zephyr,memory-region = "ROM";
dtcm: dtcm@30000000 {
reg = <0x30000000 DT_SIZE_K(32)>;
zephyr,memory-region = "DTCM";
isram: sram@31000000 {
reg = <0x31000000 DT_SIZE_M(4)>;
zephyr,memory-region = "ISRAM";
soc {
peripheral@50000000 {
#size-cells = <1>;
ranges = <0x0 0x50000000 0x10000000>;
#include "mps4_common_soc_peripheral_fpga.dtsi"
#include "mps4_common.dtsi"
This file defines the SoC peripherals for the MPS4 FPGA build and is included by mps4_corstone320_fpga.dts. It’s not a standalone file — the .dts file pulls it in during compilation with #include.
The boards/arm/mps4/mps4_common_soc_peripheral_fpga.dtsi file is used to configure the 50 MHz peripheral clock, two UART instances, GPIO controllers, and pin control using the MPS4 peripheral addresses from the
. Create the file with the following content:
sysclk: system-clock {
compatible = "fixed-clock";
clock-frequency = <50000000>;
#clock-cells = <0>;
uart0: uart@9303000 {
compatible = "arm,cmsdk-uart";
reg = <0x9303000 0x1000>;
interrupts = <34 3 49 3>;
interrupt-names = "tx", "rx";
clocks = <&sysclk>;
current-speed = <115200>;
uart1: uart@9304000 {
reg = <0x9304000 0x1000>;
interrupts = <36 3 35 3>;
clocks = <&sysclk>;
gpio0: gpio@1100000 {
compatible = "arm,cmsdk-gpio";
reg = <0x1100000 0x1000>;
interrupts = <69 3>;
gpio-controller;
#gpio-cells = <2>;
gpio1: gpio@1101000 {
reg = <0x1101000 0x1000>;
interrupts = <70 3>;
gpio-controller;
#gpio-cells = <2>;
gpio_led0: mps4_fpgaio@9302000 {
compatible = "arm,mmio32-gpio";
reg = <0x9302000 0x4>;
gpio-controller;
#gpio-cells = <1>;
ngpios = <8>;
gpio_button: mps4_fpgaio@9302008 {
reg = <0x9302008 0x4>;
gpio-controller;
#gpio-cells = <1>;
ngpios = <2>;
direction-input;
pinctrl: pinctrl {
compatible = "arm,mps4-pinctrl";
status = "okay";
Kconfig.defconfig
Kconfig.defconfig sets default values for drivers and features your board needs. Zephyr merges this file with the rest of the Kconfig configuration at build time, so these values apply automatically without requiring manual configuration.
The existing boards/arm/mps4/Kconfig.defconfig handles the FVP variants. Replace it with the following content to add FPGA support:
if BOARD_MPS4_CORSTONE315_FVP || BOARD_MPS4_CORSTONE320_FVP || BOARD_MPS4_CORSTONE320_FPGA
if SERIAL
config UART_INTERRUPT_DRIVEN
default y
endif # SERIAL
if ROMSTART_RELOCATION_ROM && (BOARD_MPS4_CORSTONE315_FVP || BOARD_MPS4_CORSTONE320_FVP)
config ROMSTART_REGION_ADDRESS
default $(dt_nodelabel_reg_addr_hex,itcm)
config ROMSTART_REGION_SIZE
default $(dt_nodelabel_reg_size_hex,itcm,0,k)
endif
if ROMSTART_RELOCATION_ROM && BOARD_MPS4_CORSTONE320_FPGA
default $(dt_nodelabel_reg_addr_hex,rom)
default $(dt_nodelabel_reg_size_hex,rom,0,k)
endif
endif
Kconfig.mps4
Kconfig.mps4 is the base software configuration for selecting SoC and other board and SoC related settings. Add the FPGA support in the file:
config BOARD_MPS4
select SOC_SERIES_MPS4
select SOC_MPS4_CORSTONE315 if BOARD_MPS4_CORSTONE315_FVP || BOARD_MPS4_CORSTONE315_FVP_NS
select SOC_MPS4_CORSTONE320 if BOARD_MPS4_CORSTONE320_FVP || BOARD_MPS4_CORSTONE320_FVP_NS || BOARD_MPS4_CORSTONE320_FPGA
mps4_corstone320_fpga_defconfig is a Kconfig fragment that Zephyr merges into the final .config when building for this board target. The fragment enables TrustZone, MPU support, GPIO, and console over UART. It configures the build as a secure image with ROM-region relocation.
Create boards/arm/mps4/mps4_corstone320_fpga_defconfig with the following content:
CONFIG_RUNTIME_NMI=y
CONFIG_ARM_TRUSTZONE_M=y
CONFIG_ARM_MPU=y
# GPIO
CONFIG_GPIO=y
# Serial
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_SERIAL=y
# Build a Secure firmware image
CONFIG_TRUSTED_EXECUTION_SECURE=y
# ROMSTART_REGION address and size are defined in Kconfig.defconfig
CONFIG_ROMSTART_RELOCATION_ROM=y
You’ve now created and updated board support files, including device tree and Kconfig configuration, to port Zephyr RTOS to the Corstone-320 MPS4 platform.
Next, you’ll build the hello_world sample for your new board target.
