# Set up the Zephyr build environment
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/)
- [Set up the Zephyr build environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/how-to-1/)
- [Add Zephyr board support for the Arm Corstone-320 MPS4 platform](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/how-to-2/)
- [Build and run the hello_world sample on Arm Corstone-320 MPS4](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/how-to-3/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/zephyr_cs320_mps4/_next-steps/)
## Prepare the development environment
Before you can build Zephyr for the Arm Corstone-320 MPS4 platform, you’ll need to install the required host packages, initialize a Zephyr workspace, and configure the Arm GNU Toolchain.
### Install host dependencies
Update your package list and install the packages that Zephyr requires. Select the tab for your host architecture:
```bash
sudo apt update && sudo apt upgrade -y
sudo apt install -y --no-install-recommends git cmake ninja-build gperf \
  ccache dfu-util device-tree-compiler wget python3-dev python3-venv python3-tk \
  xz-utils file make gcc g++ libsdl2-dev libmagic1
```bash
  xz-utils file make gcc gcc-multilib g++-multilib libsdl2-dev libmagic1
Verify that the installed versions meet Zephyr’s minimum requirements (CMake 3.20.5, Python 3.12, dtc 1.4.6):
```bash
cmake --version
python3 --version
dtc --version
### Set up the Zephyr workspace
Create a Python virtual environment and use `west` to initialize the Zephyr workspace. The following commands place the workspace in `~/zephyrproject`, but you can choose a different location.
Create and activate the virtual environment:
```bash
python3 -m venv ~/zephyrproject/.venv
source ~/zephyrproject/.venv/bin/activate
After activation, your shell prompt is prefixed with `(.venv)`. Run `source ~/zephyrproject/.venv/bin/activate` each time you open a new terminal before working with Zephyr.
Install `west` and download the Zephyr source code:
```bash
pip install west
west init -m [https://github.com/zephyrproject-rtos/zephyr](https://github.com/zephyrproject-rtos/zephyr) --mr v4.3.0 ~/zephyrproject
cd ~/zephyrproject
west update
Install the Python packages that Zephyr requires:
```bash
pip install -r zephyr/scripts/requirements.txt
Export the Zephyr CMake package so that CMake can automatically load the boilerplate required for Zephyr builds:
```bash
west zephyr-export
### Install the Arm GNU Toolchain
The Corstone-320 target uses the Cortex-M85 processor, so you need the `arm-none-eabi` bare-metal toolchain from the Arm GNU Toolchain. For a detailed installation guide covering all platforms, see the [Arm GNU Toolchain install guide](https://learn.arm.com/install-guides/gcc/arm-gnu/).
> **Note**
> The following commands use Arm GNU Toolchain version 13.2.Rel1. The same commands work with other versions. Replace the file used in these steps with the file for your version of choice. To find the latest version, see [Arm GNU Toolchain downloads](https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads).
Download, unpack, and add the Arm GNU Toolchain to your `PATH` for your host architecture:
```bash
wget [https://developer.arm.com/-/media/Files/downloads/gnu/13.2.rel1/binrel/arm-gnu-toolchain-13.2.rel1-aarch64-arm-none-eabi.tar.xz](https://developer.arm.com/-/media/Files/downloads/gnu/13.2.rel1/binrel/arm-gnu-toolchain-13.2.rel1-aarch64-arm-none-eabi.tar.xz)
tar xJf arm-gnu-toolchain-13.2.rel1-aarch64-arm-none-eabi.tar.xz -C $HOME
echo 'export PATH="$PATH:$HOME/arm-gnu-toolchain-13.2.Rel1-aarch64-arm-none-eabi/bin"' >> ~/.bashrc
source ~/.bashrc
```bash
wget [https://developer.arm.com/-/media/Files/downloads/gnu/13.2.rel1/binrel/arm-gnu-toolchain-13.2.rel1-x86_64-arm-none-eabi.tar.xz](https://developer.arm.com/-/media/Files/downloads/gnu/13.2.rel1/binrel/arm-gnu-toolchain-13.2.rel1-x86_64-arm-none-eabi.tar.xz)
tar xJf arm-gnu-toolchain-13.2.rel1-x86_64-arm-none-eabi.tar.xz -C $HOME
echo 'export PATH="$PATH:$HOME/arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi/bin"' >> ~/.bashrc
source ~/.bashrc
Verify the installation:
```bash
arm-none-eabi-gcc --version
The output is similar to:
```bash
__output__arm-none-eabi-gcc (Arm GNU Toolchain 13.2.Rel1 (Build arm-13.7)) 13.2.1 20231009
__output__Copyright (C) 2023 Free Software Foundation, Inc.
__output__This is free software; see the source for copying conditions.  There is NO
__output__warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
### Configure the Arm GNU Toolchain for Zephyr
Zephyr uses two environment variables to locate the Arm GNU Toolchain. Set these each time you open a new terminal, or add them to your shell configuration file:
```bash
export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
export GNUARMEMB_TOOLCHAIN_PATH=$HOME/arm-gnu-toolchain-13.2.Rel1-aarch64-arm-none-eabi
```bash
export GNUARMEMB_TOOLCHAIN_PATH=$HOME/arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi
## What you’ve accomplished and what’s next
You’ve now set up a development environment to build Zephyr.
Next, you’ll add board support files to port Zephyr to the Corstone-320 MPS4 platform.
