Boot a signed Zephyr image with U-Boot on Arm Cortex-A
Understand where U-Boot verifies Zephyr in the Cortex-A boot chain
Set up the host tools for your target
Build a Zephyr image that U-Boot can start
Create signing keys and sign the Zephyr image into a FIT
Build U-Boot with the public key and a boot command that fails closed
Boot the signed Zephyr FIT with U-Boot on QEMU or the TI AM62L EVM
(Optional) Test that U-Boot refuses a wrong key and a tampered image
Review the Zephyr FIT verification boundary and production needs
No. You can use QEMU without hardware. If you have an AM62L EVM, follow its target-specific setup and boot-media instructions instead.
No. You’ll generate a public-key node in
signature.dtsi and include it when you build U-Boot. For the AM62L EVM, use CONFIG_DEVICE_TREE_INCLUDES. For QEMU, add the node to the control device tree supplied with EXT_DTB. You don’t need to change the U-Boot source files.Use the U-Boot
fit_check_sign tool with your signed FIT and built u-boot.dtb. This checks the FIT against the public key in the control device tree before you prepare the boot media.Look for
sha256,rsa2048:key-a+ OK in the U-Boot output, followed by the Zephyr image A banner. You can also run the optional wrong-key and tampered-image tests to check that U-Boot refuses to start either image.No. In QEMU, you’ll run U-Boot without an earlier stage that authenticates it. On the AM62L EVM, you’ll leave the device in High Security, Field Securable (HS-FS) development state, where earlier stages accept boot files signed with any key. To extend trust to U-Boot in production, you need to provision your key, move the device to High Security, Security Enforced (HS-SE), and sign the earlier boot files.
