Boot a signed Zephyr image with U-Boot on Arm Cortex-A
Understand where U-Boot verifies Zephyr in the Cortex-A boot chain
Set up the host tools for your target
Build a Zephyr image that U-Boot can start
Create signing keys and sign the Zephyr image into a FIT
Build U-Boot with the public key and a boot command that fails closed
Boot the signed Zephyr FIT with U-Boot on QEMU or the TI AM62L EVM
(Optional) Test that U-Boot refuses a wrong key and a tampered image
Review the Zephyr FIT verification boundary and production needs
Test rejection of untrusted and tampered images
The following tests are optional. Create one Flattened Image Tree (FIT) signed with an untrusted key and another modified after signing. Check both on the host, then confirm that U-Boot refuses to start them on your target. The b and t commands are already built into U-Boot to select these images.
Open a terminal and load the environment file for your target:
- QEMU:
source $HOME/zephyr-secure-boot/env-qemu.sh - AM62L evaluation module (EVM):
source $HOME/zephyr-secure-boot/env-am62l.sh
Build a second Zephyr image
Give the wrong-key image a distinct banner so that you can identify it if it unexpectedly starts.
In Workbench for Zephyr, select Add Application. Use the same workspace, toolchain, board, and sample as the
trusted image
. Enter hello_b as the Project Name. Copy prj.conf and src/main.c from hello, then replace these two banner lines:
printk("# Hello from ZEPHYR IMAGE B #\n");
printk("# signed with key-b (NOT trusted by U-Boot) #\n");
In the Applications view, open the context menu for hello_b and select Build. The resulting binary is $WORK/zephyrproject/applications/hello_b/build/primary/zephyr/zephyr.bin.
Sign the second image with the untrusted key
Use key-b, the second key pair that you created during
FIT signing
. Copy the FIT source with sed, replacing key-a with key-b and the hello application path with hello_b.
Then, sign the new FIT:
sed 's/key-a/key-b/g; s#/hello/#/hello_b/#' $FIT/zephyr-a.its > $FIT/zephyr-b.its
$UBOOT_OUT/tools/mkimage -f $FIT/zephyr-b.its -k $KEYS $FIT/zephyr-b.itb
The output is similar to:
FIT description: Zephyr RTOS, signed with key-b
Created: Fri Sep 11 19:14:00 2026
Image 0 (kernel-1)
Description: Zephyr RTOS image
Type: Kernel Image
Compression: uncompressed
Data Size: 58340 Bytes = 56.97 KiB = 0.06 MiB
Architecture: AArch64
OS: U-Boot
Load Address: 0x82000000
Entry Point: 0x82000000
Hash algo: sha256
Hash value: 42bf9a7ae3d4fe62f6acc09a1ca7abbd803d26c4b12f0dff717acce06e2b6a9b
Default Configuration: 'conf-1'
Configuration 0 (conf-1)
Description: Zephyr on Cortex-A
Kernel: kernel-1
Sign algo: sha256,rsa2048:key-b
Sign value: 6137633e965eee69ee2cc27b1a904330cf056e1b9ec2371abaf26865763117ed...
Timestamp: Fri Sep 11 19:14:00 2026
Signature written to '/home/user/zephyr-secure-boot/fit/zephyr-b.itb', node '/configurations/conf-1/signature-1'
Check for Sign algo: sha256,rsa2048:key-b. The Hash value differs from that of image A because the application banner changed. This FIT has a signature from key-b, but U-Boot trusts only key-a and must reject it.
Make a tampered copy of the trusted image
Copy the trusted .itb and overwrite one byte inside the payload:
cp $FIT/zephyr-a.itb $FIT/zephyr-tampered.itb
printf '\xff' | dd of=$FIT/zephyr-tampered.itb bs=1 seek=32768 conv=notrunc 2>/dev/null
In the example FITs, offset 32768 (0x8000) falls inside the Zephyr payload rather than the FIT metadata. The payload begins a few hundred bytes into the file and is tens of kilobytes long.
Check that the copy now differs from the original:
cmp $FIT/zephyr-a.itb $FIT/zephyr-tampered.itb
/home/user/zephyr-secure-boot/fit/zephyr-a.itb /home/user/zephyr-secure-boot/fit/zephyr-tampered.itb differ: byte 32769, line 94
If cmp prints nothing, the selected byte was already 0xff. Choose another offset inside the payload, such as seek=32800, then repeat the dd and cmp commands.
Expect the signature check to pass and the payload hash check to fail. The signature covers the unchanged configuration and hash-1 node. The hash covers the payload bytes that you modified.
Check both images on the host
Your timings, hash values, and FIT Image at addresses will differ from these examples. Run fit_check_sign with the control device tree from your
U-Boot build
. Check the wrong-key image first:
$UBOOT_OUT/tools/fit_check_sign -f $FIT/zephyr-b.itb -k $UBOOT_OUT/u-boot.dtb
Verifying Hash Integrity for node 'conf-1'... sha256,rsa2048:key-b-
error!
Verification failed for '(null)' hash node in 'conf-1' config node
Failed to verify required signature 'key-key-a'
Signature check bad (error 1)
Check for sha256,rsa2048:key-b- and Failed to verify required signature 'key-key-a'. The final verdict, Signature check bad (error 1), confirms rejection. The exit code is one.
Then, check the tampered image:
$UBOOT_OUT/tools/fit_check_sign -f $FIT/zephyr-tampered.itb -k $UBOOT_OUT/u-boot.dtb
Verifying Hash Integrity for node 'conf-1'... sha256,rsa2048:key-a+
Verified OK, loading images
## Loading kernel (any) from FIT Image at 7ae29b84a000 ...
Using 'conf-1' configuration
Verifying Hash Integrity ...
OK
Trying 'kernel-1' kernel subimage
Type: Kernel Image
OS: U-Boot
Hash algo: sha256
Hash value: 1d1d375f14c3354579e9e5310986a69b831bcd1944cd6b35aa8e83632b658166
sha256 error!
Bad hash value for 'hash-1' hash node in 'kernel-1' image node
Bad Data Hash
## Loading fdt (any) from FIT Image at 7ae29b84a000 ...
OK
Could not find subimage node type 'fdt'
## Loading ramdisk (any) from FIT Image at 7ae29b84a000 ...
OK
Could not find subimage node type 'ramdisk'
Check that sha256,rsa2048:key-a+ reports a valid signature, followed by sha256 error! and Bad hash value for 'hash-1'. The final verdict is Signature check bad (error 1), and the exit code is one. The modified payload fails verification even though the configuration signature passes.
Add the two images to the boot media
Copy both test FITs into the BOOT_IMG volume used to
prepare the boot media
, then list its contents:
mcopy -o -i $BOOT_IMG $FIT/zephyr-b.itb $FIT/zephyr-tampered.itb ::
mdir -i $BOOT_IMG ::
Volume in drive : is boot
Volume Serial Number is 40D2-DF89
Directory for ::/
tiboot3 bin 216538 2026-09-15 16:49
tispl bin 1467919 2026-09-15 16:49
u-boot img 1422787 2026-09-15 16:49
zephyr-a itb 60198 2026-09-15 16:49
zephyr-b itb 60198 2026-09-15 16:49
ZEPHYR~1 ITB 60198 2026-09-15 16:49 zephyr-tampered.itb
6 files 3 287 838 bytes
130 643 968 bytes free
This example lists the six files of the AM62L EVM: three boot files and three FITs. The QEMU disk image contains only the three FITs.
disk.img directly. No physical media needs to be written.Write the updated image to the card. Confirm the device name of the card before replacing /dev/sdX. dd overwrites the entire selected disk:
sudo dd if=$WORK/sdcard.img of=/dev/sdX bs=4M conv=fsync status=progress
Move the card to the board, open the console with picocom, and power the board on.
Run the wrong-key test
Press a key during the three-second countdown to stop autoboot. If you miss the countdown, U-Boot starts image A. Start the target again and try again. At the prompt, run the wrong-key test:
=> run b
The expected output is:
60198 bytes read in 1 ms (57.4 MiB/s)
## Loading kernel (any) from FIT Image at 90000000 ...
Verifying Hash Integrity ... sha256,rsa2048:key-b- error!
Verification failed for '<NULL>' hash node in 'conf-1' config node
Bad Data Hash
ERROR -2: can't get kernel image!
*** REFUSED: Zephyr was NOT started ***
Check for sha256,rsa2048:key-b- error! and Failed to verify required signature 'key-key-a'. The - indicates failure, because the signature of the image doesn’t satisfy the required key-a check.
When bootm start fails, the && chain skips go and prints *** REFUSED: Zephyr was NOT started ***. Confirm that no Zephyr banner appears. Bad Data Hash and ERROR -2: can't get kernel image! can appear for either rejection test. Use the preceding messages to identify which check failed.
Run the tampered-image test
At the U-Boot prompt, run the tampered-image test:
=> run t
60198 bytes read in 2 ms (28.7 MiB/s)
Verifying Hash Integrity ... sha256,rsa2048:key-a+ OK
Created: 2026-09-11 16:14:00 UTC
Type: Kernel Image
Data Start: 0x900000e8
Data Size: 58340 Bytes = 57 KiB
OS: U-Boot
Hash algo: sha256
Verifying Hash Integrity ... sha256 error!
Bad Data Hash
Check that sha256,rsa2048:key-a+ OK reports a valid signature. sha256 error! and Bad hash value for 'hash-1' indicate that the payload no longer matches its stored hash. Confirm that *** REFUSED: Zephyr was NOT started *** appears without a Zephyr banner.
If run b or run t starts Zephyr, verification isn’t preventing startup. Check for a ; where && belongs in CONFIG_PREBOOT, and confirm that signature.dtsi includes required = "conf". Compare both with the
U-Boot build settings
, rebuild, and update the boot media.
To boot the trusted image again, type run a.
You’ve confirmed that U-Boot rejects the wrong-key image at the signature check and the tampered image at the payload hash check. Neither reaches go or starts Zephyr.
Next, you’ll review what these tests establish and what a production device still needs.
