Boot a signed Zephyr image with U-Boot on Arm Cortex-A
Understand where U-Boot verifies Zephyr in the Cortex-A boot chain
Set up the host tools for your target
Build a Zephyr image that U-Boot can start
Create signing keys and sign the Zephyr image into a FIT
Build U-Boot with the public key and a boot command that fails closed
Boot the signed Zephyr FIT with U-Boot on QEMU or the TI AM62L EVM
(Optional) Test that U-Boot refuses a wrong key and a tampered image
Review the Zephyr FIT verification boundary and production needs
What your target boots from
Open a terminal and load the environment file for your target:
- QEMU:
source $HOME/zephyr-secure-boot/env-qemu.sh - AM62L evaluation module (EVM):
source $HOME/zephyr-secure-boot/env-am62l.sh
The AM62L boot ROM reads the first-stage file from a File Allocation Table (FAT) partition on the SD card. Start with TI’s card image to preserve the expected layout. QEMU loads u-boot.bin from the command line, so its disk image needs only the signed Flattened Image Tree (FIT).
On either target, the fatload of U-Boot reads zephyr-a.itb from the partition selected by BOOT_DEV.
Build the boot media
Follow the instructions for your target to build the boot media.
Create a 64 MiB disk image with one FAT16 partition starting at sector 2048. Use a master boot record (MBR) partition table and partition type 0x0e, which specifies FAT16 with logical block addressing (LBA). These commands don’t need root privileges:
truncate -s 64M $WORK/disk.img
printf 'label: dos\nstart=2048, size=129024, type=e\n' | sfdisk $WORK/disk.img
mkfs.vfat --offset 2048 -F 16 -n ZEPHYRFIT $WORK/disk.img
Copy the signed FIT into the partition and list its contents. BOOT_IMG includes @@1048576, telling mtools that the volume starts 1 MiB into the image. :: identifies the root directory of the volume:
mcopy -o -i $BOOT_IMG $FIT/zephyr-a.itb ::
mdir -i $BOOT_IMG ::
The output is similar to:
Volume in drive : is ZEPHYRFIT
Volume Serial Number is B4EA-EA2A
Directory for ::/
zephyr-a itb 38742 2026-09-17 22:11
1 file 38 742 bytes
65 871 872 bytes free
Confirm that the volume contains zephyr-a.itb. The partition is accessed as virtio 0:1, matching BOOT_DEV in env-qemu.sh.
The boot ROM reads tiboot3.bin from the first FAT partition on the card. Preserve TI’s FAT16 partition layout and replace its files. The supplied partition starts at sector 2048 and spans 262144 sectors. These values determine the extraction size in the command.
Start from the .wic.xz that you downloaded. Extract the first 1 MiB, which holds the partition table, plus the 128 MiB partition into a new image file:
xz -dc $WORK/tisdk-default-image.wic.xz | head -c $(( (2048+262144)*512 )) > $WORK/sdcard.img
The result is a 129 MiB image. Its partition table still lists TI’s second partition, which points past the end of the extracted image. Remove that partition-table entry:
sfdisk --delete $WORK/sdcard.img 2
The output ends with:
The partition table has been altered.
Syncing disks.
Use mtools to remove TI’s Linux files and copy your boot files and signed FIT into the FAT volume. BOOT_IMG includes @@1048576, selecting the volume 1 MiB into the image. :: identifies its root directory:
mdeltree -i $BOOT_IMG ::EFI
mdel -i $BOOT_IMG ::Image ::uEnv.txt
mcopy -o -i $BOOT_IMG $UBOOT_OUT/tiboot3.bin $UBOOT_OUT/tispl.bin $UBOOT_OUT/u-boot.img ::
Volume in drive : is boot
Volume Serial Number is 40D2-DF89
Directory for ::/
tiboot3 bin 216538 2026-09-15 16:49
tispl bin 1467919 2026-09-15 16:49
u-boot img 1422787 2026-09-15 16:49
zephyr-a itb 60198 2026-09-15 16:49
4 files 3 167 442 bytes
130 766 848 bytes free
Confirm that the volume contains the three boot files and zephyr-a.itb.
Start the target
Follow the instructions for your target to start the target.
The AM62L EVM steps write to a whole disk with dd. Replace /dev/sdX with your card – for example, /dev/sdb — rather than a partition such as /dev/sdb1. dd erases everything on the target, so a wrong device name erases the wrong disk.
Start QEMU with the U-Boot binary and disk image that you prepared. -bios selects the binary, and -nographic displays the serial console in your terminal. The -drive and -device options attach disk.img as the virtio device containing virtio 0:1:
qemu-system-aarch64 -machine virt,gic-version=3 -cpu cortex-a53 -m 1G -nographic -no-reboot \
-bios $UBOOT_OUT/u-boot.bin \
-drive if=none,file=$WORK/disk.img,format=raw,id=hd0 \
-device virtio-blk-device,drive=hd0
Use the same -machine, -cpu, and -m settings as the device-tree export used to
build U-Boot
. U-Boot should begin printing in the terminal. To exit QEMU, press Ctrl+A, then X.
Run lsblk before and after inserting the micro-SD card. Identify the newly listed disk and confirm its size matches the card. Replace /dev/sdX with the device name of that disk and write the image to the whole card:
sudo dd if=$WORK/sdcard.img of=/dev/sdX bs=4M conv=fsync status=progress
If you transfer the prepared image to Windows or macOS, you can write sdcard.img with balenaEtcher. Alternatively, write TI’s unchanged .wic.xz image to the card. Open its first partition, remove Image, uEnv.txt, and the EFI directory, then copy in the three boot files and zephyr-a.itb.
Set SW3 using the table. This is the reduced pin-count setting from the AM62L EVM user guide , where the ROM ignores SW2 and SW4. The ON position is toward the ON label on the switch bank.
| Switch | 1 | 2 | 3 | 4 |
| SW3 | OFF | ON | OFF | ON |
Connect the micro-USB port J7 to your host. It creates four serial ports. The console is usually /dev/ttyUSB0 and uses 115200 baud. Open the console:
picocom -b 115200 /dev/ttyUSB0
If picocom reports a permission error, add your user to the dialout group with sudo usermod -aG dialout $USER, then log out and back in. To leave picocom later, press Ctrl+A, then Ctrl+X.
Move the SD card to the board, then connect a USB-C Power Delivery (PD) supply to J17 or J19. Boot messages should appear in the console.
In QEMU, the log starts with U-Boot because no TF-A or Secondary Program Loader (SPL) stage runs first. The messages Bloblist at 0 not found (err=-2) and Warning: Unexpected devicetree source (not from a prior stage) are consistent with this setup. Loading Environment from nowhere... OK indicates that U-Boot is using its built-in environment.
The AM62L EVM also prints messages from its early firmware stages. Its log up to the autoboot countdown is similar to the following example. Your dates, version strings, and countdown will differ:
NOTICE: Booting Trusted Firmware
NOTICE: BL1: v2.14.0(release):12.00.00.06-28-gb54338ab6
NOTICE: BL1: Built : 09:15:06, Jul 8 2026
NOTICE: BL1: dram_class: 11
NOTICE: BL1: dram_size: 0x80000000
NOTICE: DDR init done
NOTICE: ENTERING WFI - end of bl1
NOTICE: BL31: v2.14.0(release):12.00.00.06-28-gb54338ab6
NOTICE: BL31: Built : 09:15:06, Jul 8 2026
NOTICE: SYSFW ABI: 4.0 (firmware rev 0x000c '12.1.2--v12.01.02 (Clever Cat)')
ERROR: Agent 0 Protocol 0x10 Message 0x7: not supported
U-Boot SPL 2026.01-ti-g5fb294342321 (Jul 09 2026 - 22:23:09 +0000)
SPL initial stack usage: 1920 bytes
Trying to boot from MMC2
Authentication passed
U-Boot 2026.01-g5fb294342321 (Sep 11 2026 - 18:13:32 +0200)
SoC: AM62LX SR1.1 HS-FS
Model: Texas Instruments AM62L3 Evaluation Module
DRAM: 2 GiB
Core: 89 devices, 34 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1, eth1: ethernet@8000000port@2
Hit any key to stop autoboot: 3
Use the following messages to identify the boot stages and selected devices:
NOTICE: BL1:andBL31:identify TF-A running fromtiboot3.binandtispl.bin.Authentication passedreports successful authentication by TI’s security firmware.SoC: AM62LX SR1.1 HS-FSidentifies the development state of the system on chip (SoC).MMC:lists the eMMC as device zero and the SD card as device one.
The Agent 0 Protocol 0x10 Message 0x7: not supported errors appear in this successful boot log. They don’t prevent Zephyr from starting.
This log comes from a board running TI’s prebuilt first two stages, so its U-Boot SPL line shows TI’s build date instead of yours.
Watch the trusted image boot
After the three-second countdown, autoboot runs run a, the trusted-image command built into U-Boot. The following example output shows the AM62L EVM. Your timings and hash values will differ. The output is similar to:
60198 bytes read in 1 ms (57.4 MiB/s)
## Loading kernel (any) from FIT Image at 90000000 ...
Using 'conf-1' configuration
Verifying Hash Integrity ... sha256,rsa2048:key-a+ OK
Trying 'kernel-1' kernel subimage
Description: Zephyr RTOS image
Created: 2026-09-11 16:14:00 UTC
Type: Kernel Image
Compression: uncompressed
Data Start: 0x900000e8
Data Size: 58340 Bytes = 57 KiB
Architecture: AArch64
OS: U-Boot
Load Address: 0x82000000
Entry Point: 0x82000000
Hash algo: sha256
Hash value: 1d1d375f14c3354579e9e5310986a69b831bcd1944cd6b35aa8e83632b658166
Verifying Hash Integrity ... sha256+ OK
Loading Kernel Image to 82000000
## Starting application at 0x82000000 ...
*** Booting Zephyr OS build 4.4.2 ***
Secondary CPU core 1 (MPID:0x1) is up
# Hello from ZEPHYR IMAGE A #
# signed with key-a (TRUSTED by U-Boot) #
board : am62l_evm/am62l3/a53
arch : arm64
started by : U-Boot 'go' after FIT signature verification
this image was verified by U-Boot before it ran.
Confirm verification and startup using the following messages:
sha256,rsa2048:key-a+ OKconfirms that the signature verifies with the public key embedded in U-Boot.sha256+ OKconfirms that the payload hash matches.Loading Kernel Image to 82000000showsbootm loadoscopying Zephyr to its link address.## Starting application at 0x82000000 ...showsgohanding control to Zephyr.
Zephyr then prints its boot banner and Hello from ZEPHYR IMAGE A. On the AM62L EVM, Secondary CPU core 1 (MPID:0x1) is up also reports startup of the second core.
QEMU uses different load addresses and image sizes. For QEMU, expect FIT Image at 48000000, Data Size: 37040 Bytes, Loading Kernel Image to 40000000, and board : qemu_cortex_a53/qemu_cortex_a53. Its board configuration starts one core, so there’s no secondary-core startup message.
Troubleshoot boot and console output
Consider the following guidance to troubleshoot issues with your target.
Check the symptom and try the corresponding step:
- Nothing prints, or startup hangs after the banner: Check that the control device tree matches the machine. Rebuild it from a fresh
dumpdtbwith the same-machine,-cpu, and-mused to start QEMU. Failed to load 'zephyr-a.itb': U-Boot found the volume but not the file. List it on the host withmdir -i $BOOT_IMG ::.** Bad device specification virtio 0 **: Check the partition type withsfdisk -l $WORK/disk.img. If it isn’t0x0e, rebuild the disk image with the specified type.Unknown command 'dcache':CONFIG_CMD_CACHEdidn’t make it into.config. Add it and build U-Boot again.
If the terminal stays empty, check the console connection and whether the ROM loads tiboot3.bin:
- Try all four serial ports that J7 creates. The console isn’t always the first one.
- Check SW3, or switch to the full pin-count setting, which uses all three switch banks. See BOOTMODE
0x0E43in the AM62L EVM User Guide. - Check that the first partition of the card is still TI’s FAT16 partition, not reformatted.
- Flash TI’s unchanged
.wic.xzto a card and boot it. If that also produces no output, check the boot switches, serial port, and power supply before investigating your custom boot files. - If TI’s card boots but yours never shows the SPL banner, copy TI’s prebuilt first two stages over yours with
mcopy -o -i $BOOT_IMG $PREBUILT/tiboot3.bin $PREBUILT/tispl.bin ::. Then, write the card again with the samedd.u-boot.imgstill carries the key and the boot command.
If Zephyr prints its boot banner but no application output, check that the
Zephyr build configuration
includes CONFIG_ARMV8_A_NS=y.
You’ve prepared the boot media and watched U-Boot verify the FIT signed with key-a before starting Zephyr.
Next, you can run the optional wrong-key and tampered-image tests to confirm that verification failures prevent startup. You can also skip to review the trust boundary and the additional work needed for production .
