Boot a signed Zephyr image with U-Boot on Arm Cortex-A
Understand where U-Boot verifies Zephyr in the Cortex-A boot chain
Set up the host tools for your target
Build a Zephyr image that U-Boot can start
Create signing keys and sign the Zephyr image into a FIT
Build U-Boot with the public key and a boot command that fails closed
Boot the signed Zephyr FIT with U-Boot on QEMU or the TI AM62L EVM
(Optional) Test that U-Boot refuses a wrong key and a tampered image
Review the Zephyr FIT verification boundary and production needs
Check that U-Boot can verify signatures
Open a terminal and load the environment file for your target:
- QEMU:
source $HOME/zephyr-secure-boot/env-qemu.sh - AM62L evaluation module (EVM):
source $HOME/zephyr-secure-boot/env-am62l.sh
Both target default configurations enable Flattened Image Tree (FIT) signature verification. Check the relevant settings in $UBOOT_OUT/.config, generated when you built the host tools:
grep -E '^CONFIG_(FIT|FIT_SIGNATURE|RSA|OF_SEPARATE)=|LEGACY_IMAGE_FORMAT' $UBOOT_OUT/.config
For the AM62L EVM, the expected output is:
CONFIG_FIT=y
CONFIG_FIT_SIGNATURE=y
# CONFIG_LEGACY_IMAGE_FORMAT is not set
CONFIG_OF_SEPARATE=y
CONFIG_RSA=y
CONFIG_FIT_SIGNATURE and CONFIG_RSA enable the verifier. CONFIG_OF_SEPARATE provides a separate control device tree blob (DTB), which will hold your public key. Legacy images, which carry no signature, are disabled in this configuration.
You’ll add the public key and boot command through build configuration, without patching U-Boot source.
For QEMU, qemu_arm64_defconfig enables the unsigned legacy image format with CONFIG_LEGACY_IMAGE_FORMAT=y. The QEMU configuration fragment disables it and configures a control device tree containing your key.
Generate the public-key device-tree node
Use a temporary FIT to make mkimage write the public key into a scratch DTB. You’ll convert the key node to source for the U-Boot build.
First, create an empty DTB and a placeholder payload in $WORK:
printf '/dts-v1/;\n/ { };\n' | dtc -I dts -O dtb -o $WORK/scratch.dtb
printf 'payload' > $WORK/payload.bin
Create key.its using the same layout as zephyr-a.its, with the placeholder payload:
cat > $WORK/key.its <<'EOF'
/dts-v1/;
description = "carrier used only to emit the public key for key-a";
#address-cells = <1>;
images {
kernel-1 {
description = "placeholder payload";
data = /incbin/("payload.bin");
type = "kernel"; arch = "arm64"; os = "u-boot"; compression = "none";
load = <0>; entry = <0>;
hash-1 { algo = "sha256"; };
configurations {
default = "conf-1";
conf-1 {
kernel = "kernel-1";
signature-1 { algo = "sha256,rsa2048"; key-name-hint = "key-a"; sign-images = "kernel"; };
EOF
mkimage refuses the file without its two description properties, and dtc looks for payload.bin next to key.its.
Sign the temporary FIT and convert the scratch DTB to signature.dtsi:
$UBOOT_OUT/tools/mkimage -f $WORK/key.its -k $KEYS -K $WORK/scratch.dtb -r $WORK/key.itb
dtc -I dtb -O dts -q $WORK/scratch.dtb | sed '/^\/dts-v1\/;/d' > $WORK/signature.dtsi
-K writes the public key into scratch.dtb, and -r marks the key as required. The sed command removes the /dts-v1/; header so that the resulting .dtsi can be included after the main .dts header.
Check the key name and required-signature setting:
grep -E 'key-name-hint|required' $WORK/signature.dtsi
The expected output is:
required = "conf";
Confirm that key-name-hint is key-a and required is conf. Leave out key-b so that U-Boot doesn’t trust its signatures.
The build incorporates signature.dtsi into the U-Boot control device tree. Use mkimage -K only with the scratch DTB. Adding the key directly to a finished u-boot.dtb would lose it when make rebuilds that file.
Write a boot command that fails closed
An unverified boot command loads zephyr.bin and jumps to it. With your QEMU target values, the command looks like the following:
=> fatload virtio 0:1 0x40000000 zephyr.bin; dcache flush; icache flush; dcache off; icache off; go 0x40000000
On the AM62L EVM, the same line reads fatload mmc 1:1 0x82000000 zephyr.bin and ends go 0x82000000.
The command doesn’t verify the image between fatload and go. Add bootm verification before the handover. The verified command chain uses the same QEMU target values and is split into lines for readability:
fatload virtio 0:1 0x48000000 ${fit} &&
bootm start 0x48000000 &&
bootm loados &&
dcache flush && icache flush && dcache off && icache off &&
go 0x40000000;
echo "*** REFUSED: Zephyr was NOT started ***"
The command chain loads, verifies, and starts Zephyr:
fatload virtio 0:1 0x48000000 ${fit}reads the FIT named in${fit}fromBOOT_DEVtoFIT_ADDR.FIT_ADDRis separate fromZEPHYR_ADDR, so copying the payload won’t overwrite the FIT being read.bootm start 0x48000000parses the FIT, picksconf-1, verifies the RSA signature against/signature/key-key-a, then verifies the image hash.bootm loadoscopies the verified payload to itsloadaddress,ZEPHYR_ADDR.- The cache commands flush and disable the caches. On arm64,
dcache offalso disables the memory management unit (MMU), preparing the state Zephyr expects at entry. go 0x40000000jumps toZEPHYR_ADDRwithout performing verification. Usingbootm startandbootm loadosstops before the OS-specific boot code that a plainbootmwould run.
For QEMU, BOOT_DEV is virtio 0:1, the File Allocation Table (FAT) partition in the disk image. On the AM62L EVM, it’s mmc 1:1, the first partition on the SD card. The board loads the FIT at 0x90000000 and copies Zephyr to 0x82000000.
Failing closed means stopping before Zephyr starts if any command fails. The && operators enforce this condition: a && b runs b only if a succeeds. Separating the commands with ; would allow execution to continue after a failed check. In this application, go doesn’t return, so the refusal message prints only when an earlier command fails.
Store the chain in the environment variable zboot. Three wrapper commands select which FIT it loads:
| Variable | Definition |
zboot | The chain, with ${fit} as the file name |
a | setenv fit zephyr-a.itb; run zboot |
b | setenv fit zephyr-b.itb; run zboot |
t | setenv fit zephyr-tampered.itb; run zboot |
a boots the trusted image. b and t select the images that you’ll create during the optional
wrong-key and tampered-image tests
Autoboot runs bootcmd after a countdown. CONFIG_PREBOOT defines zboot and its wrappers before the countdown, making them available if you interrupt it. CONFIG_BOOTCOMMAND="run a" selects the trusted image by default. CONFIG_BOOTDELAY=3 gives you three seconds to interrupt autoboot.
The commands are compiled into U-Boot rather than stored on the card, where anyone could edit a boot script to skip the check.
Configure U-Boot
Reset to the default configuration for your target before adding the custom settings:
make -C $UBOOT_SRC O=$UBOOT_OUT CROSS_COMPILE=$CROSS CC="$UBOOT_CC" $UBOOT_DEFCONFIG
Append the boot-command settings to .config. The unquoted EOF delimiter lets the shell expand $BOOT_DEV, $FIT_ADDR, and $ZEPHYR_ADDR. Escaping \${fit} preserves ${fit} for U-Boot to expand at runtime:
cat >> $UBOOT_OUT/.config <<EOF
CONFIG_USE_PREBOOT=y
CONFIG_PREBOOT="setenv zboot 'fatload $BOOT_DEV $FIT_ADDR \${fit} && bootm start $FIT_ADDR && bootm loados && dcache flush && icache flush && dcache off && icache off && go $ZEPHYR_ADDR; echo \"*** REFUSED: Zephyr was NOT started ***\"'; setenv a 'setenv fit zephyr-a.itb; run zboot'; setenv b 'setenv fit zephyr-b.itb; run zboot'; setenv t 'setenv fit zephyr-tampered.itb; run zboot'"
CONFIG_USE_BOOTCOMMAND=y
CONFIG_BOOTDELAY=3
EOF
Keep the \" sequences around the echo text. The sequences represent literal quotes inside the Kconfig string. Run grep ^CONFIG_PREBOOT $UBOOT_OUT/.config and check that the device and addresses for your target appear in the command.
Follow the instructions for your target to add its device-tree and boot settings:
QEMU normally supplies the U-Boot device tree at runtime, so CONFIG_DEVICE_TREE_INCLUDES has no source tree to modify. Instead, you’ll create a control device tree containing your key and pass it to the build.
Add the following settings to enable that approach and disable unsigned legacy images. The settings also enable cache commands and keep the environment from being saved to flash:
cat >> $UBOOT_OUT/.config <<'EOF'
# CONFIG_OF_BOARD is not set
# CONFIG_OF_OMIT_DTB is not set
CONFIG_CMD_CACHE=y
# CONFIG_ENV_IS_IN_FLASH is not set
CONFIG_ENV_IS_NOWHERE=y
EOF
CONFIG_OF_BOARD and CONFIG_OF_OMIT_DTB off make U-Boot carry a control device tree of its own, the one your key goes into. CONFIG_LEGACY_IMAGE_FORMAT off closes the older image format, which carries no signature. CONFIG_CMD_CACHE adds the dcache and icache commands that the boot command uses. CONFIG_ENV_IS_NOWHERE keeps the environment out of flash, so nothing saved at the prompt can replace your boot command.
TI’s U-Boot tree builds its control device tree from source. Set CONFIG_DEVICE_TREE_INCLUDES to include your public-key node in that build:
CONFIG_DEVICE_TREE_INCLUDES="$WORK/signature.dtsi"
EOF
Run olddefconfig to resolve the configuration settings:
make -C $UBOOT_SRC O=$UBOOT_OUT CROSS_COMPILE=$CROSS CC="$UBOOT_CC" olddefconfig
The output is similar to:
.config:2355:warning: override: reassigning to symbol DEVICE_TREE_INCLUDES
.config:2356:warning: override: reassigning to symbol USE_PREBOOT
.config:2358:warning: override: reassigning to symbol USE_BOOTCOMMAND
.config:2359:warning: override: reassigning to symbol BOOTCOMMAND
.config:2360:warning: override: reassigning to symbol BOOTDELAY
These override warnings are expected because your settings replace default values. The QEMU configuration can produce additional warnings for its target-specific overrides.
Build U-Boot
Follow the instructions for your target to build U-Boot.
Export the device tree for the QEMU machine that you’ll boot later:
qemu-system-aarch64 -machine virt,gic-version=3,dumpdtb=$WORK/qemu-virt.dtb -cpu cortex-a53 -m 1G -nographic
This keeps the U-Boot drivers, console, and memory sizing consistent with the machine. QEMU writes the file and exits.
Add your public-key node by decompiling the tree, appending signature.dtsi, and recompiling it:
dtc -I dtb -O dts -q $WORK/qemu-virt.dtb > $WORK/uboot-control.dts
cat $WORK/signature.dtsi >> $WORK/uboot-control.dts
dtc -I dts -O dtb -q -o $WORK/uboot-control.dtb $WORK/uboot-control.dts
The device tree compiler (dtc) merges the repeated root nodes, adding /signature to the exported tree.
Build U-Boot with EXT_DTB pointing to your control device tree. Specify u-boot.bin and u-boot.dtb as the build targets:
make -C $UBOOT_SRC O=$UBOOT_OUT CROSS_COMPILE=$CROSS CC="$UBOOT_CC" -j$(nproc) \
EXT_DTB=$WORK/uboot-control.dtb u-boot.bin u-boot.dtb
The scripts/check-of.sh script in U-Boot rejects the default all target for this machine, which normally receives its device tree from a prior stage.
The build takes a couple of minutes. Check the two files:
ls -l $UBOOT_OUT/u-boot.bin $UBOOT_OUT/u-boot.dtb
u-boot.bin is about 1.4 MB and ends with the bytes of u-boot.dtb, the control device tree with your key inside.
TI’s U-Boot tree uses binman, the U-Boot image packaging tool, to package the early stages. Point BL1, BL31, and TEE to the prebuilt TF-A and OP-TEE binaries in the SDK. Set BINMAN_INDIRS to the SDK directory containing TI’s system firmware:
BL1=$PREBUILT/bl1.bin BL31=$PREBUILT/bl31.bin TEE=$PREBUILT/bl32.bin BINMAN_INDIRS=$PREBUILT
The build takes a few minutes. Check the three boot files:
ls -l $UBOOT_OUT/tiboot3.bin $UBOOT_OUT/tispl.bin $UBOOT_OUT/u-boot.img
Expect sizes of about 0.2 MB for tiboot3.bin, 1.5 MB for tispl.bin, and 1.4 MB for u-boot.img. The build also writes the control device tree to u-boot.dtb in the same output directory.
Check the embedded key and verify the signed FIT
Decompile $UBOOT_OUT/u-boot.dtb, the control device tree that went into U-Boot, and print its /signature node:
dtc -I dtb -O dts -q $UBOOT_OUT/u-boot.dtb | sed -n '/signature {/,/^\t};/p'
With the long values shortened, the output is similar to:
signature {
key-key-a {
required = "conf";
rsa,r-squared = <...>;
rsa,modulus = <...>;
rsa,exponent = <0x00 0x10001>;
rsa,n0-inverse = <...>;
rsa,num-bits = <0x800>;
The rsa, properties contain the public key for key-a. Check that the node includes required = "conf", which makes U-Boot require a valid configuration signature.
Verify the trusted FIT on the host using the key in that DTB. fit_check_sign uses the verification code in U-Boot. -f selects the FIT, and -k selects the DTB containing the public key:
$UBOOT_OUT/tools/fit_check_sign -f $FIT/zephyr-a.itb -k $UBOOT_OUT/u-boot.dtb
Verifying Hash Integrity for node 'conf-1'... sha256,rsa2048:key-a+
Verified OK, loading images
## Loading kernel (any) from FIT Image at 7a44a7686000 ...
Using 'conf-1' configuration
Verifying Hash Integrity ...
OK
Trying 'kernel-1' kernel subimage
Description: Zephyr RTOS image
Created: Fri Sep 11 19:14:00 2026
Type: Kernel Image
Compression: uncompressed
Data Size: 58340 Bytes = 56.97 KiB = 0.06 MiB
Architecture: AArch64
OS: U-Boot
Load Address: 0x82000000
Entry Point: 0x82000000
Hash algo: sha256
Hash value: 1d1d375f14c3354579e9e5310986a69b831bcd1944cd6b35aa8e83632b658166
sha256+
OK
Decrypting Data ...
OK
Loading Kernel Image to 0
## Loading fdt (any) from FIT Image at 7a44a7686000 ...
OK
Could not find subimage node type 'fdt'
## Loading ramdisk (any) from FIT Image at 7a44a7686000 ...
OK
Could not find subimage node type 'ramdisk'
Signature check OK
Check for sha256,rsa2048:key-a+, which confirms that the configuration signature verifies with key-a. The + indicates success. The final verdict is Signature check OK, and the exit code is zero.
The tool also checks for device-tree and ramdisk subimages. The two Could not find subimage node type messages are expected because this FIT contains only Zephyr.
You’ve built U-Boot with the public key for key-a and a boot command that starts Zephyr only after verification succeeds. The trusted FIT passes the host check against the embedded key.
Next, you’ll prepare the boot media and watch U-Boot verify and start Zephyr on your chosen target.
