What you need to set up
You need Zephyr host tools, U-Boot source, and a cross compiler for your chosen target. For QEMU, download U-Boot source and install the emulator and compiler from Ubuntu packages. For the AM62L evaluation module (EVM), the TI Processor SDK supplies U-Boot source, the cross compiler, and prebuilt early firmware.
Install the Zephyr host tools
To install host tools on Visual Studio Code:
  1. Open Visual Studio Code and select Workbench for Zephyr in the Activity Bar.
  2. In its panel, select Install Host Tools to install the dependencies used to build Zephyr:
    • Python
    • CMake
    • Ninja
    • Git
    • Device Tree Compiler
    • West
  3. When installation finishes, select Verify Host Tools. Resolve any missing-tool errors before continuing.
You’ll import the AArch64 toolchain and create the West workspace later, before building Zephyr.
Install the host packages
Install the additional packages used to build U-Boot, sign images, and prepare the boot media:
sudo apt install -y build-essential bison flex swig python3-dev python3-setuptools libssl-dev libgnutls28-dev uuid-dev device-tree-compiler openssl mtools dosfstools xz-utils curl picocom
If you chose QEMU as your target, install the emulator and U-Boot cross compiler:
sudo apt install -y qemu-system-arm gcc-aarch64-linux-gnu
For the AM62L EVM, skip installing the emulator. You’ll get the cross compiler from the TI SDK.
Create the working directory and environment file
Keep your source, tools, and build outputs under $HOME/zephyr-secure-boot. An environment file stores the paths and target settings that you’ll reuse throughout the workflow.
Follow the instructions for your target to create and load its environment file, and create the signing-key and Flattened Image Tree (FIT) directories:
mkdir -p $HOME/zephyr-secure-boot
cat > $HOME/zephyr-secure-boot/env-qemu.sh <<'EOF'
export WORK=$HOME/zephyr-secure-boot
# Target values
export BOARD=qemu_cortex_a53                  # Zephyr board identifier
export ZEPHYR_ADDR=0x40000000                 # Zephyr link address, FIT load and go target
export FIT_ADDR=0x48000000                    # where U-Boot loads the FIT, clear of ZEPHYR_ADDR
export BOOT_DEV="virtio 0:1"                  # U-Boot device and partition that hold the files
export UBOOT_DEFCONFIG=qemu_arm64_defconfig   # U-Boot configuration for the target
# No vendor SDK: U-Boot from the U-Boot project, cross compiler from Ubuntu
export UBOOT_SRC=$WORK/u-boot-2025.07
export CROSS=aarch64-linux-gnu-
export UBOOT_CC="${CROSS}gcc"
# Your build outputs: U-Boot build, signing keys, signed FITs, and the boot volume
export UBOOT_OUT=$WORK/uboot-build
export KEYS=$WORK/keys
export FIT=$WORK/fit
export BOOT_IMG=$WORK/disk.img@@1048576
EOF
source $HOME/zephyr-secure-boot/env-qemu.sh
mkdir -p $KEYS $FIT
cat > $HOME/zephyr-secure-boot/env-am62l.sh <<'EOF'
# Target values
export BOARD=am62l_evm/am62l3/a53             # Zephyr board identifier
export ZEPHYR_ADDR=0x82000000                 # Zephyr link address, FIT load and go target
export FIT_ADDR=0x90000000                    # where U-Boot loads the FIT, clear of ZEPHYR_ADDR
export BOOT_DEV="mmc 1:1"                     # U-Boot device and partition that hold the files
export UBOOT_DEFCONFIG=am62lx_evm_defconfig   # U-Boot configuration for the target
# Vendor SDK: U-Boot source, firmware that runs before U-Boot, cross compiler and its libraries
export SDK=$WORK/tisdk
export UBOOT_SRC=$SDK/board-support/ti-u-boot-2026.01+git
export PREBUILT=$SDK/board-support/prebuilt-images/am62lxx-evm
export CROSS=$SDK/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-
export SYSROOT=$SDK/linux-devkit/sysroots/aarch64-oe-linux
export UBOOT_CC="${CROSS}gcc --sysroot=$SYSROOT"
export BOOT_IMG=$WORK/sdcard.img@@1048576
EOF
source $HOME/zephyr-secure-boot/env-am62l.sh
mkdir -p $KEYS $FIT
The variables are available only in the shell where you load the environment file. If you open a new terminal, you’ll have to load the environment file again. If you adapt the workflow to another board, you’ll learn how to choose its target values and paths in the optional board-adaptation guidance .
Note
Example output shows paths under /home/user/, the home directory of the account that produced it. The paths in your output will reflect your own username. For example, on a standard Ubuntu cloud instance, they appear under /home/ubuntu/. The commands use $HOME and $WORK, so they adapt to your account automatically. Only the printed paths in the example outputs differ.
Get the U-Boot source and the cross compiler
Follow the instructions for your target to download U-Boot and the cross compiler.
Download U-Boot 2025.07 and unpack it into your working directory. The archive is about 32 MB:
curl -L -o $WORK/u-boot-2025.07.tar.bz2 https://ftp.denx.de/pub/u-boot/u-boot-2025.07.tar.bz2
tar -xf $WORK/u-boot-2025.07.tar.bz2 -C $WORK
ls -d $UBOOT_SRC
The expected output is:
        /home/user/zephyr-secure-boot/u-boot-2025.07
You’ll add the public key and boot command through build configuration, without patching U-Boot source.
Check that the cross compiler runs:
${CROSS}gcc --version
The output is similar to:
        aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0
Check that the emulator is installed and report its version:
qemu-system-aarch64 --version
        QEMU emulator version 8.2.2 (Debian 1:8.2.2+ds-0ubuntu1.18)
You’ll create a 64 MiB disk image when you prepare the boot media. You don’t need to download one for QEMU.
The TI Processor SDK Linux for AM62Lx supplies U-Boot source, prebuilt early firmware, and the cross compiler. You’ll use these components to boot Zephyr. The installer is 4.5 GB and unpacks to 11 GB.
Download version 12.01.00.05.03 from the TI Processor SDK download page :
curl -L -o $WORK/ti-processor-sdk-linux-am62lxx-evm-12.01.00.05.03-Linux-x86-Install.bin https://dr-download.ti.com/software-development/software-development-kit-sdk/MD-YjEeNKJJjt/12.01.00.05.03/ti-processor-sdk-linux-am62lxx-evm-12.01.00.05.03-Linux-x86-Install.bin
Make the installer executable and run it. --mode unattended uses the default settings without opening the graphical wizard. --prefix selects $SDK as the installation directory, without root privileges:
chmod +x $WORK/ti-processor-sdk-linux-am62lxx-evm-12.01.00.05.03-Linux-x86-Install.bin
$WORK/ti-processor-sdk-linux-am62lxx-evm-12.01.00.05.03-Linux-x86-Install.bin --mode unattended --prefix $SDK
Check that the three paths exist and the compiler runs:
ls -d $UBOOT_SRC $PREBUILT $SYSROOT
        /home/user/zephyr-secure-boot/tisdk/board-support/prebuilt-images/am62lxx-evm
/home/user/zephyr-secure-boot/tisdk/board-support/ti-u-boot-2026.01+git
/home/user/zephyr-secure-boot/tisdk/linux-devkit/sysroots/aarch64-oe-linux
aarch64-oe-linux-gcc (GCC) 15.3.0
Download TI’s SD card image to preserve the boot partition layout expected by the AM62L boot ROM:
curl -L -o $WORK/tisdk-default-image.wic.xz https://dr-download.ti.com/software-development/software-development-kit-sdk/MD-YjEeNKJJjt/12.01.00.05.03/tisdk-default-image-am62lxx-evm-12.01.00.05.03.rootfs.wic.xz
The download is about 1.3 GB. Leave it compressed. When you prepare the boot media, you’ll extract the boot partition and replace its files.
You’ve installed the Zephyr host tools and U-Boot build packages. You’ve also obtained the U-Boot source and cross compiler for your target, and created a reusable environment file. For the AM62L EVM, you’ve additionally set up the early firmware and SD card image.
Next, you’ll import the AArch64 toolchain, create a West workspace, and build a small Zephyr application for your chosen target.
