Arm Runtime for YOLO26 on Raspberry Pi 5
Arm Runtime for YOLO26 on Raspberry Pi 5 is optimized to run YOLO26n inference on the CPU of the Pi. It uses a fixed inference schedule, planned memory reuse, and fused operations on the Arm Cortex-A76 cores of the Pi.
You’ll run object detection on a supplied video example with the optimized runtime. You can also use your own video or a live feed from a PiCamera.
You’ll then understand how the Python example works, and how it uses the optimized runtime. You’ll also learn more about why this runtime is so performant.
Finally, you’ll export the same YOLO26n checkpoint to NCNN, a general-purpose runtime, on your Pi. You’ll use the Ultralytics validation harness to compare inference latency for both runtimes.
Prepare your Raspberry Pi
Connect to your Raspberry Pi. You can connect directly or over SSH.
Use 64-bit Raspberry Pi OS Trixie, and Python 3.13.
Install the following prerequisites on your Pi:
sudo apt update
sudo apt install --yes --no-install-recommends \
  build-essential ca-certificates cmake curl git libgl1 libglib2.0-0t64 \
  make patch python3 python3-venv tar gzip
Clone the Arm Runtime for YOLO26 on Raspberry Pi 5 repository:
git clone https://github.com/arm/Optimized-Runtimes.git
cd Optimized-Runtimes/yolo26-raspberry-pi-5
Run the remaining commands from this yolo26-raspberry-pi-5 directory. Build the runtime from the same source checkout:
make runtime
The build downloads its dependencies and installs the library under dist/runtime/.
The Python examples use this library automatically.
Run object detection
Run object detection on the supplied sample:
make example-video
The first example run downloads and checks the YOLO26n checkpoint and sample video. It converts the checkpoint and prepares a Python environment. It then runs detection on 200 frames at a model input size of 640 × 640. Later runs reuse the prepared files.
The output is similar to the following run on an 8GB Raspberry Pi 5 (no heatsink or cooling):
        Detection performance:
  throughput: 26.27 FPS
  detection time: 38.07 ms/frame
  frames: 200
  mean timing: preprocess 1.09 ms, inference 36.08 ms, postprocess 0.87 ms
  video decode and resize: 2010.36 ms total
Your timings will vary.
The frames per second (FPS) figure measures how quickly the detector processes frames that are already decoded and resized in memory. The figure includes preparing the model input, running inference, and converting predictions into detections. It excludes reading and decoding the video, resizing frames, saving the detection JSON, and drawing and encoding the output video.
The runtime accelerates model inference. It doesn’t accelerate video decoding, resizing, drawing boxes, or encoding the output video. This example therefore reports detection FPS separately from those video-processing steps. It lists inference time separately from preprocessing and postprocessing.
Check your results
The command writes detections.json and rendered.mp4 under examples/video/output/. Check the frame count and print the first detected object:
python3 - <<'PY'
import json
from pathlib import Path
data = json.loads(Path("examples/video/output/detections.json").read_text())
assert len(data["frames"]) == 200
detection = next(
    detection
    for frame in data["frames"]
    for detection in frame["detections"]
print("Frames:", len(data["frames"]))
print("First detection:", detection)
PY
The output is similar to this example, which reports 200 frames and shows a class name, confidence, and bounding box for the first detection:
        Frames: 200
First detection: {'box': [10.625, 275.125, 131.625, 358.875], 'class_id': 64, 'class_name': 'mouse', 'confidence': 0.91943359375}
Open examples/video/output/rendered.mp4 in a video player to inspect the boxes and labels.
If you’re connected over SSH, use scp to copy the video back to your local machine for viewing.
(Optional) Bring your own video, or use live feed from PiCamera
To use your own video, provide a file on the Pi with at least 200 frames:
make example-video VIDEO=/path/to/your-video.mp4
For a connected Raspberry Pi Camera, install the camera packages and run live detection without a preview:
sudo apt install --yes python3-picamera2 rpicam-apps
make example-camera
Press Ctrl+C to stop. For a live preview, see the camera example instructions .
What you’ve accomplished
You’ve run YOLO26n on the CPU of the Pi using the Arm Runtime.
Next, you’ll understand how the example works, and learn how and why the runtime is optimized for Arm CPUs.
