Explore related resources
Give feedback
AI-assisted
Close
Does Arm Runtime use the Raspberry Pi 5 CPU or GPU?
Inference runs on the Raspberry Pi 5 CPU. The runtime uses Cortex-A76 cores, a fixed schedule, planned memory reuse, and fused operations.
How do I run detection on my own video or a PiCamera feed?
For a video with at least 200 frames, run make example-video VIDEO=/path/to/your-video.mp4. For a live PiCamera feed, install the camera packages and run make example-camera.
What happens when I create the detector?
When you create the detector, the Python session checks the model manifest and binary, then loads the shared library. The runtime loads the converted model and prepares XNNPACK operations. The example reuses the detector across frames.
Which settings should I match for a fair NCNN comparison?
Use Ultralytics 8.4.108 and the same YOLO26n checkpoint, coco-128-by-sa dataset, 640 × 640 input, and batch size one. Stop other CPU workloads and use the same power, cooling, and CPU settings.
What should I check if the runtimes report different latency or accuracy?
Confirm both runs use the same checkpoint, dataset, input size, and batch size. Stop other CPU workloads and use matching power, cooling, and CPU settings. Internal precision and operation fusion can still differ between runtimes.
Return to Embedded and Microcontrollers
