# Overview
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/yolo-on-himax/)
- [Overview](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/yolo-on-himax/overview/)
- [Set up the environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/yolo-on-himax/dev-env/)
- [Build the firmware](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/yolo-on-himax/build-firmware/)
- [Flash firmware onto the microcontroller](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/yolo-on-himax/flash-and-run/)
- [Run additional models in the web toolkit](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/yolo-on-himax/web-toolkit/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/yolo-on-himax/_next-steps/)
## What are the benefits of the Himax WiseEye2 Module?
- The Himax WiseEye2 implements the Arm-based Cortex M55 CPU and Ethos U55 NPU, and is one of the first “off-the-shelf” platforms of its type.
- The Himax WiseEye2 Module is an ultra-low power device that is energy-saving.
- It fully integrates with an existing Open Source AI framework (TFLite).
## What is a You-Only-Look-Once (YOLO) object detection model?
YOLO is a technology used in computer vision for identifying and locating objects in images and videos.
It is Open Source, fast, and has good detection accuracy.
To learn more about YOLO, see [Where to Start](https://docs.ultralytics.com/#where-to-start).
