Run a computer vision model on a Himax microcontroller
Overview
Set up the environment
Build the firmware
Flash firmware onto the microcontroller
Run additional models in the web toolkit
Run
git clone --recursive https://github.com/HimaxWiseEyePlus/Seeed_Grove_Vision_AI_Module_V2.git, then change into the new directory. The --recursive option pulls the required third-party subrepositories.Go to
Seeed_Grove_Vision_AI_Module_V2/EPII_CM55M_APP_S and open the makefile. Set APP_TYPE to a value from the provided table. For object detection, use tflm_yolov8_od. Then, pass the corresponding model argument with the --model option when flashing.From the repository root, run
pip install -r xmodem/requirements.txt. This installs an Xmodem file transfer utility used by the flashing scripts.Insert the flexible printed circuit (FPC) cable into the module’s connector and lift the dark grey latch, then secure the cable. Connect the board to the host with a USB-C cable.
You should be able to view a live camera feed with the computer vision application active. If you selected the YOLO option, expect object detection to appear in the feed.
