Get started with Yocto Linux on Qemu
How do I get started with Yocto Linux on Qemu?
Use Poky, the Yocto Project reference distribution. You’ll build a minimal image from Poky before running it under QEMU.
In
conf/local.conf, uncomment MACHINE ?= "qemuarm64". This selects the 64-bit Arm machine that you’ll build and run with QEMU.You’ll know the build finished correctly when you have a generated image, and the build completes without errors.
You’ll find the images in
build-qemu-arm64/tmp/deploy/images/qemuarm64.Run
runqemu qemuarm64 nographic. Linux boots in your console, where you can log in as root.
