# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/)
- [Overview](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/2-overview/)
- [Understand the ExecuTorch workflow](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/3-executorch-workflow/)
- [Set up your ExecuTorch environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/4-env-setup-execut/)
- [Set up the Corstone-320 Fixed Virtual Platform](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/5-env-setup-fvp/)
- [Deploy and run Mobilenet V2 on the Corstone-320 FVP](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/6-run-model/)
- [Enable GUI and deploy a model on Corstone-320 FVP](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/7-configure-fvp-gui/)
- [Evaluate Ethos-U Performance](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/8-evaluate-output/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/visualizing-ethos-u-performance/_next-steps/)
## Explore related resources
- [TinyML Brings AI to Smallest Arm Devices](https://newsroom.arm.com/blog/tinyml)
- [Arm Machine Learning Resources](https://www.arm.com/developer-hub/embedded-and-microcontrollers/ml-solutions/getting-started)
- [Arm Developers Guide for Cortex-M Processors and Ethos-U NPU](https://developer.arm.com/documentation/109267/0101)
## Review frequently asked questions
**What additional setup do I need before running the FV on macOS?**
Follow the guidance in the [FVPs-on-Mac GitHub repository](https://github.com/Arm-Examples/FVPs-on-Mac/) before launching the Corstone-320 FVP.
**Where is the MobileNet V2 example located in the ExecuTorch repository?**
The Python code for MobileNet V2 is in `executorch/examples/models/mobilenet_v2/model.py`. Use this example when deploying the model to the Corstone-320 FVP.
**How do I run the MobileNet V2 example on the Corstone-320 FVP?**
Use the provided `run.sh` script with the additional parameters shown in the steps after completing the environment and FVP setup. Run the script from the `executorch` repository.
**How do I know the Corstone-320 FVP installed and started correctly?**
The FVP should launch without errors and present its graphical interface.
**How do I verify that execution uses the simulated Ethos-U NPU?**
Use the FVP graphical interface to visualize model execution and look for activity corresponding to CPU and NPU components.
