With your environment and FVP now set up, you’re ready to deploy and run a real TinyML model using ExecuTorch.
This example deploys the MobileNet V2 computer vision model. The model is a convolutional neural network (CNN) that extracts visual features from an image. It is used for image classification and object detection.
The Python code for the MobileNet V2 model is in your local executorch repo:
executorch/examples/models/mobilenet_v2/model.py
. You can deploy it using
run.sh
, just like you did in the previous step, with some extra parameters:
On macOS, make sure Docker is running. FVPs execute inside a Docker container.
./examples/arm/run.sh \
--aot_arm_compiler_flags="--delegate --quantize --intermediates mv2_u85/ --debug --evaluate" \
--output=mv2_u85 \
--target=ethos-u85-128 \
--model_name=mv2
The --model_name=mv2 flag tells run.sh to use the Mobilenet V2 model defined in examples/models/mobilenet_v2/model.py.
Explanation of run.sh Parameters
| run.sh Parameter | Meaning / Context |
| –aot_arm_compiler_flags | Passes a string of compiler options to the ExecuTorch Ahead-of-Time (AOT) compiler |
| –delegate | Enables backend delegation |
| –quantize | Converts the floating-point model to int8 quantized format using post-training quantization Essential for running on NPUs |
| –intermediates mv2_u85/ | Directory where intermediate files (e.g., TOSA, YAMLs, debug graphs) will be saved Useful output files for manual debugging |
| –debug | Verbose debugging logging |
| –evaluate | Validates model output, provides timing estimates |
ExecuTorch will:
You should see output like:
Batch Inference time 4.94 ms, 202.34 inferences/s
Total delegated subgraphs: 1
Number of delegated nodes: 419
A high number of delegated nodes means the majority of model execution was successfully offloaded to the Ethos-U NPU for acceleration. This confirms that the model was successfully compiled, deployed, and run with NPU acceleration.
If you’d like to visualize instruction counts and performance using the GUI, continue to the next (optional) section.
