Install tools on the command line using vcpkg
Install vcpkg
Initialize vcpkg
Create a vcpkg-configuration.json file
Use vcpkg
Activate a license
Remove vcpkg
Yes. Run the appropriate script from
~/.vcpkg for your shell (vcpkg-init.cmd on Windows cmd, vcpkg-init.ps1 in PowerShell, or vcpkg-init on Linux and macOS). Initialization is required in every new terminal window before using vcpkg.The configuration ensures consistent installation across platforms and selects the correct binaries for the host OS and architecture. Create it first so activation installs and exposes the tools defined for your environment.
After running
vcpkg-shell activate, you should see a summary of artifacts with their Version and Status, such as installed. The listed tools come from your vcpkg-configuration.json.The activation output can include a warning that
vcpkg-artifacts is experimental and might change at any time. This is expected, and no action is necessary.Activate it using
armlm activate -product KEMDK-COM0 -server https://mdk-preview.keil.arm.com, then optionally run armlm inspect to confirm an active product entry such as Keil MDK Community. Use of Arm tools is subject to the End User License Agreement located in the license_terms folder of the downloaded archive.
