# Using the command line
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/uvprojx-conversion/)
- [Using Keil Studio](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/uvprojx-conversion/how-to-1/)
- [Using µVision](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/uvprojx-conversion/how-to-mdk/)
- [Using the command line](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/uvprojx-conversion/how-to-2/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/uvprojx-conversion/_next-steps/)
## Project conversion on the command line
Follow the [instructions](https://arm-software.github.io/MDK-Toolbox/01_installation/) to install the `uv2csolution` tool on your local machine. The tool is available for all major host operating systems (macOS, Linux, Windows).
Follow the [command line usage instructions](https://arm-software.github.io/MDK-Toolbox/04_uv2csolution/) to convert µVision projects to CMSIS solution projects.
