In VS Code, go to File - Open Folder and select the folder containing the uvprojx file (here Blinky.uvprojx).
Once the folder is open in VS Code, right-click the uvprojx file and select Convert µVision project to csolution:
The following files (and more) are generated:
Blinky.csolution.yamlBlinky.cproject.yamlvcpkg-configuration.jsonThe Output window shows a successful conversion:
The vcpkg configuration file is automatically activated. You notice a couple of “Arm Tools” available in the Status Bar at the bottom:
Click on the CMSIS icon in the Activity Bar to open the CMSIS View. At the top, click on the hammer icon to build the project:
The cbuild task starts. A successful project build will end with:
        Program size: Code=... RO-data=... RW-data=... ZI-data=...
info cbuild: build finished successfully!
Build complete
