Explore related resources
Give feedback
AI-assisted
Close
How do I know the Blinky project built correctly before I start debugging?
Select Build (F7) and verify it completes without errors. When the build succeeds, select Start a Debug Session (Ctrl+F5) and Run (F5) the application.
What should I check if I don't see any SWV data?
SWV isn’t supported in simulation mode. Connect a debug adapter to real target hardware and use SWV there.
Where do Event Recorder printf messages appear, and what does my project need?
Event Recorder text appears in the Debug (printf) Viewer window. Your code must call the Event Recorder API or use components already annotated (such as MDK‑Middleware, Keil RTX5, or CMSIS‑FreeRTOS). Event Recorder requires some system RAM.
How do I limit ETM trace capture to a specific code region?
In the Disassembly window or C source, add a TraceRun (ETM) tracepoint where capture should start and a TraceSuspend (ETM) tracepoint where it should stop. µVision records instructions, branches, exceptions, and interrupts between those tracepoints.
How do I configure ULINKplus to capture power measurements?
ULINKplus adds core clock measurement and power measurement that you can use with Event Event Statistics to profile code sections. Configure the adapter with a debug initialization script that runs when debug mode starts. For board connections, refer to the ULINKplus documentation.
Return to Embedded and Microcontrollers
